    lcd from old notebook/laptop?
    8 Posts 4 Posters 3.6k Views 4 Watching
    • zdenekZ Offline
      zdenek
      hi all
      is it possible to use for MM LCD from old laptop (HP, DELL)? It has no input connector, the power comes from laptop…
      thanks
      Zdeněk
      • ? Offline
        A Former User @zdenek
        @zdenek
        You can buy controller board for your LCD from ebay or Amazon.
        zdenekZ 1 Reply Last reply Reply Quote 0
        • zdenekZ Offline
          zdenek @Guest
          @sean thx, so the “controller” is the only part I need? great, thanks
          Zdeněk
          • ? Offline
            @zdenek
            First, do you know your LCD parts no or id?
            By Example,
            Dell Inspiron 1545 has 15.6" LCD - LP156WH2 (by LG Display) as a screen.
            It can be controllable with this;
            https://www.amazon.de/Audioeingang-LCD-Controller-Karte-LP156WH2-LED-Hintergrundbeleuchtung-LCD-Panel/dp/B06XKD8FN4/ref=sr_1_3_sspa?s=computers&ie=UTF8&qid=1535541589&sr=1-3-spons&keywords=lcd+controller&psc=1
            You need HDMI cable and 12 V 3 A DC Power Adaptor additionally.
            That’s all.
              MadScientist
              Buy a V29/V59/V56. They are universal and the firmware can be flashed using USB. The board with remote control (w/o inverter -> an extra 1-2€) are less than 10€ on Aliexpress. I have multiple of them. Disadvantage is that the doesn’t wake up via HDMI. I am using a relay to power on/off the screen via PIR-sensor.
              • zdenekZ Offline
                zdenek
                thx all, I’ll try…
                  Why not use the laptop board? (Just a thought)
                  • zdenekZ Offline
                    zdenek @Mykle1
                    @mykle1 cause somne of the laptops are broken (water/juice/coffee). And some of the simply don’t start, but they are 5+ years and I don’t want to waste money to get them working
                    • to place MB from laptop you need additional space.
