    • Search
    MagicMirror² v2.25.0 is available! For more information about this release, check out this topic.
    SOLVED Rpi 3B+, can't install
    Troubleshooting
    4442
    • E
      epi last edited by
      I tried like 3 or 4 times to follow several guides. Can’t make it work, as I see errors during installation process. in short - is there anyone who can help me installing via SSH?
      • delightedCrow
        delightedCrow Project Sponsor Module Developer last edited by
        I was having a ton of errors installing on a new Rpi 3B+ too. Following @NoNameRo 's suggestion on uninstalling & reinstalling node from source fixed it for me: https://forum.magicmirror.builders/topic/8431/npm-install-is-giving-error/9?page=1
        What errors are you getting?
        • E
          epi last edited by
          There is a bounch of npm warn notice security, but error i get is
          • E
            epi last edited by
            Followed your advice and I got new error
            • E
              epi last edited by
              This post is deleted!
              Mykle1 A 2 Replies Last reply Reply Quote -1
              • Mykle1
                Mykle1 Project Sponsor Module Developer @epi last edited by
                @epi
                Personally, I would try a manual install of MM instead of the install script which seems to falter at times.
                • Rename your current MagicMirror folder (so you don’t lose it)
                • Download MagicMirror from the Repo
                • Rename the new MM folder to MagicMirror
                • Run npm install in the new MagicMirror directory
                • Run npm start in the new MagicMirror directory
                At this point you should get an error message to create a config. That’s a good thing. It means MM is installed correctly and running. You just need a working config.
                https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
                • E
                  epi last edited by epi
                  Would you please type correct commands? I’m not too good with commandline.
                  I used
                  mv MagicMirror MagicMirror2
                  bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
                  I see an error
                  • E
                    epi last edited by
                    so I did
                    mv MagicMirror MagicMirror3
                    git clone https://github.com/MichMich/MagicMirror
                    npm start
                    and I see
                    Segmentation fault
                    • M
                      MadScientist last edited by
                      Try git clone https://github.com/MichMich/MagicMirrorthen cd MagicMirrorfollowed by npm install.
                      Looks to me you tried to start the MagicMirror before installing it.
                      • E
                        epi last edited by
                        Segmentation fault
