    Rpi 3B+, can't install
    19 Posts 6 Posters 9.7k Views 5 Watching
    • E Offline
      epi
      Followed your advice and I got new error
      • E Offline
        epi
        Mykle1M A 2 Replies Last reply Reply Quote -1
          Mykle1 Project Sponsor Module Developer @epi
          @epi
          Personally, I would try a manual install of MM instead of the install script which seems to falter at times.
          • Rename your current MagicMirror folder (so you don’t lose it)
          • Download MagicMirror from the Repo
          • Rename the new MM folder to MagicMirror
          • Run npm install in the new MagicMirror directory
          • Run npm start in the new MagicMirror directory
          At this point you should get an error message to create a config. That’s a good thing. It means MM is installed correctly and running. You just need a working config.
          https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
          • E Offline
            epi
            Would you please type correct commands? I’m not too good with commandline.
            I used
            mv MagicMirror MagicMirror2
            bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
            I see an error
            • E Offline
              epi
              so I did
              mv MagicMirror MagicMirror3
              git clone https://github.com/MichMich/MagicMirror
              npm start
              and I see
              Segmentation fault
                MadScientist
                Try git clone https://github.com/MichMich/MagicMirrorthen cd MagicMirrorfollowed by npm install.
                Looks to me you tried to start the MagicMirror before installing it.
                • E Offline
                  epi
                  Segmentation fault
                  • E Offline
                    epi
                    I have set up WAN Port Forwarding to RPi, if there is somebody willing to help me.
                    J 1 Reply Last reply Reply Quote -1
                      JRCelis @epi
                      @epi
                      I got the same issue and I installed manually.
                      1. install the latest Node.js version.
                      • Updates Debian apt package repository to include the NodeSource packages.
                        curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
                      • install Node.js
                        sudo apt install -y nodejs
                      • Check your node version ( should be V 10.10.0)
                        node -v
                      1. Clone the repository and check out the master branch: git clone https://github.com/MichMich/MagicMirror
                      2. Enter the repository: cd MagicMirror/
                      3. Install and run the app with: npm install && npm start
                      4. create a working config.
                        https://forum.magicmirror.builders/search?term=how to install mm manually&in=titlesposts
