    Rpi 3B+, can't install
    19 Posts 6 Posters 9.7k Views 5 Watching
    • E Offline
      epi
      I have set up WAN Port Forwarding to RPi, if there is somebody willing to help me.
      J 1 Reply Last reply Reply Quote -1
        JRCelis @epi
        @epi
        I got the same issue and I installed manually.
        1. install the latest Node.js version.
        • Updates Debian apt package repository to include the NodeSource packages.
          curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
        • install Node.js
          sudo apt install -y nodejs
        • Check your node version ( should be V 10.10.0)
          node -v
        1. Clone the repository and check out the master branch: git clone https://github.com/MichMich/MagicMirror
        2. Enter the repository: cd MagicMirror/
        3. Install and run the app with: npm install && npm start
        4. create a working config.
          https://forum.magicmirror.builders/search?term=how to install mm manually&in=titlesposts
          • E Offline
            epi
            Still doesn’t work for me.
            What I did is
            1. Install fresh RASPBIAN STRETCH WITH DESKTOP
            2. After install, configure wifi credentials and enable SSH access
            3. Connect via SSH and proceed with
            node -v
            (got answer “v10.10.0”)
            cd MagicMirror/
            • E Offline
              epi
              any clue what to do next?
                MadScientist
                Not sure this will help but you could try npm install -g electron within your MagicMirror directory.
                If that doesn’t work, try npm install electron@2.0.0 inside your MM directory.
                • E Offline
                  epi
                  Issue found, everything works now.
                  Problem was my SD card, it, is (becomes) corrupt at some point.
                    MadScientist
                    That’s why I run mine from a cheap SSD (Kingston A400, 120GB iirc). Much faster and no risk of corrupting it. I paid 27€ for my SSD. At this price I think it is worth considering buying one.
                      Ajay1889 @epi
                      Please try the following
                      sudo apt-get remove nodejs nodejs-legacy nodered
                      after that
                      curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
                      sudo apt-get install -y nodejs
                      sudo npm install -g npm@latest
                      after that enter in the repository with
                      cd MagicMirror
                      If have not install MM, use this from github
                       bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
                      then install and run the app with
                      This method worked for me.
                      Credit: @NoNameRo
