    Rpi 3B+, can't install
    19 Posts 6 Posters 10.9k Views 5 Watching
    • E Offline
      epi
      Segmentation fault
      • E Offline
        epi
        I have set up WAN Port Forwarding to RPi, if there is somebody willing to help me.
        J 1 Reply Last reply Reply Quote -1
          JRCelis @epi
          @epi
          I got the same issue and I installed manually.
          1. install the latest Node.js version.
          • Updates Debian apt package repository to include the NodeSource packages.
            curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
          • install Node.js
            sudo apt install -y nodejs
          • Check your node version ( should be V 10.10.0)
            node -v
          1. Clone the repository and check out the master branch: git clone https://github.com/MichMich/MagicMirror
          2. Enter the repository: cd MagicMirror/
          3. Install and run the app with: npm install && npm start
          4. create a working config.
            https://forum.magicmirror.builders/search?term=how to install mm manually&in=titlesposts
            • E Offline
              epi
              Still doesn’t work for me.
              What I did is
              1. Install fresh RASPBIAN STRETCH WITH DESKTOP
              2. After install, configure wifi credentials and enable SSH access
              3. Connect via SSH and proceed with
              node -v
              (got answer “v10.10.0”)
              cd MagicMirror/
              • E Offline
                epi
                any clue what to do next?
                  MadScientist
                  Not sure this will help but you could try npm install -g electron within your MagicMirror directory.
                  If that doesn’t work, try npm install electron@2.0.0 inside your MM directory.
                  • E Offline
                    epi
                    Issue found, everything works now.
                    Problem was my SD card, it, is (becomes) corrupt at some point.
                      MadScientist
                      That’s why I run mine from a cheap SSD (Kingston A400, 120GB iirc). Much faster and no risk of corrupting it. I paid 27€ for my SSD. At this price I think it is worth considering buying one.
                        Ajay1889 @epi
                        Please try the following
                        sudo apt-get remove nodejs nodejs-legacy nodered
                        after that
                        curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
                        sudo apt-get install -y nodejs
                        sudo npm install -g npm@latest
                        after that enter in the repository with
                        cd MagicMirror
                        If have not install MM, use this from github
                         bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
                        then install and run the app with
                        This method worked for me.
                        Credit: @NoNameRo
