    Rpi 3B+, can't install
    19 Posts 6 Posters 11.1k Views 5 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @epi
      @epi
      Personally, I would try a manual install of MM instead of the install script which seems to falter at times.
      • Rename your current MagicMirror folder (so you don’t lose it)
      • Download MagicMirror from the Repo
      • Rename the new MM folder to MagicMirror
      • Run npm install in the new MagicMirror directory
      • Run npm start in the new MagicMirror directory
      At this point you should get an error message to create a config. That’s a good thing. It means MM is installed correctly and running. You just need a working config.
      https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
      • E
        epi
        Would you please type correct commands? I’m not too good with commandline.
        I used
        mv MagicMirror MagicMirror2
        bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
        I see an error
        • E
          epi
          so I did
          mv MagicMirror MagicMirror3
          git clone https://github.com/MichMich/MagicMirror
          npm start
          and I see
          Segmentation fault
            MadScientist
            Try git clone https://github.com/MichMich/MagicMirrorthen cd MagicMirrorfollowed by npm install.
            Looks to me you tried to start the MagicMirror before installing it.
            • E
              epi
              Segmentation fault
              • E
                epi
                I have set up WAN Port Forwarding to RPi, if there is somebody willing to help me.
                J 1 Reply Last reply
                Reply Quote -1
                  JRCelis @epi
                  @epi
                  I got the same issue and I installed manually.
                  1. install the latest Node.js version.
                  • Updates Debian apt package repository to include the NodeSource packages.
                    curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
                  • install Node.js
                    sudo apt install -y nodejs
                  • Check your node version ( should be V 10.10.0)
                    node -v
                  1. Clone the repository and check out the master branch: git clone https://github.com/MichMich/MagicMirror
                  2. Enter the repository: cd MagicMirror/
                  3. Install and run the app with: npm install && npm start
                  4. create a working config.
                  • Mykle1M
                    https://forum.magicmirror.builders/search?term=how to install mm manually&in=titlesposts
                    • E
                      epi
                      Still doesn’t work for me.
                      What I did is
                      1. Install fresh RASPBIAN STRETCH WITH DESKTOP
                      2. After install, configure wifi credentials and enable SSH access
                      3. Connect via SSH and proceed with
                      node -v
                      (got answer “v10.10.0”)
                      cd MagicMirror/
                      • E
                        epi
                        any clue what to do next?
                          MadScientist
                          Not sure this will help but you could try npm install -g electron within your MagicMirror directory.
                          If that doesn’t work, try npm install electron@2.0.0 inside your MM directory.
                          • E
                            epi
                            Issue found, everything works now.
                            Problem was my SD card, it, is (becomes) corrupt at some point.
                              MadScientist
                              That’s why I run mine from a cheap SSD (Kingston A400, 120GB iirc). Much faster and no risk of corrupting it. I paid 27€ for my SSD. At this price I think it is worth considering buying one.
                              • A
                                Ajay1889 @epi
                                Please try the following
                                sudo apt-get remove nodejs nodejs-legacy nodered
                                after that
                                curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
                                sudo apt-get install -y nodejs
                                sudo npm install -g npm@latest
                                after that enter in the repository with
                                cd MagicMirror
                                If have not install MM, use this from github
                                then install and run the app with
                                This method worked for me.
                                Credit: @NoNameRo
