    Rpi 3B+, can't install
    19 Posts 6 Posters 11.1k Views 5 Watching
      MadScientist
      Try git clone https://github.com/MichMich/MagicMirrorthen cd MagicMirrorfollowed by npm install.
      Looks to me you tried to start the MagicMirror before installing it.
      • E
        epi
        Segmentation fault
        • E
          epi
          I have set up WAN Port Forwarding to RPi, if there is somebody willing to help me.
          J 1 Reply Last reply
          Reply Quote -1
            JRCelis @epi
            @epi
            I got the same issue and I installed manually.
            1. install the latest Node.js version.
            • Updates Debian apt package repository to include the NodeSource packages.
              curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
            • install Node.js
              sudo apt install -y nodejs
            • Check your node version ( should be V 10.10.0)
              node -v
            1. Clone the repository and check out the master branch: git clone https://github.com/MichMich/MagicMirror
            2. Enter the repository: cd MagicMirror/
            3. Install and run the app with: npm install && npm start
            4. create a working config.
            • Mykle1M
              https://forum.magicmirror.builders/search?term=how to install mm manually&in=titlesposts
              • E
                epi
                Still doesn’t work for me.
                What I did is
                1. Install fresh RASPBIAN STRETCH WITH DESKTOP
                2. After install, configure wifi credentials and enable SSH access
                3. Connect via SSH and proceed with
                node -v
                (got answer “v10.10.0”)
                cd MagicMirror/
                • E
                  epi
                  any clue what to do next?
                    MadScientist
                    Not sure this will help but you could try npm install -g electron within your MagicMirror directory.
                    If that doesn’t work, try npm install electron@2.0.0 inside your MM directory.
                    • E
                      epi
                      Issue found, everything works now.
                      Problem was my SD card, it, is (becomes) corrupt at some point.
                        MadScientist
                        That’s why I run mine from a cheap SSD (Kingston A400, 120GB iirc). Much faster and no risk of corrupting it. I paid 27€ for my SSD. At this price I think it is worth considering buying one.
                        • A
                          Ajay1889 @epi
                          Please try the following
                          sudo apt-get remove nodejs nodejs-legacy nodered
                          after that
                          curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
                          sudo apt-get install -y nodejs
                          sudo npm install -g npm@latest
                          after that enter in the repository with
                          cd MagicMirror
                          If have not install MM, use this from github
                           bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
                          then install and run the app with
                          This method worked for me.
                          Credit: @NoNameRo
