    Rpi 3B+, can't install
    19 Posts 6 Posters 10.5k Views 5 Watching
    • E Offline
      epi
      Would you please type correct commands? I’m not too good with commandline.
      I used
      mv MagicMirror MagicMirror2
      bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
      I see an error
      • E Offline
        epi
        so I did
        mv MagicMirror MagicMirror3
        git clone https://github.com/MichMich/MagicMirror
        npm start
        and I see
        Segmentation fault
          MadScientist
          Try git clone https://github.com/MichMich/MagicMirrorthen cd MagicMirrorfollowed by npm install.
          Looks to me you tried to start the MagicMirror before installing it.
          • E Offline
            epi
            Segmentation fault
            • E Offline
              epi
              I have set up WAN Port Forwarding to RPi, if there is somebody willing to help me.
              J 1 Reply Last reply Reply Quote -1
                JRCelis @epi
                @epi
                I got the same issue and I installed manually.
                1. install the latest Node.js version.
                • Updates Debian apt package repository to include the NodeSource packages.
                  curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
                • install Node.js
                  sudo apt install -y nodejs
                • Check your node version ( should be V 10.10.0)
                  node -v
                1. Clone the repository and check out the master branch: git clone https://github.com/MichMich/MagicMirror
                2. Enter the repository: cd MagicMirror/
                3. Install and run the app with: npm install && npm start
                4. create a working config.
                  https://forum.magicmirror.builders/search?term=how to install mm manually&in=titlesposts
                  • E Offline
                    epi
                    Still doesn’t work for me.
                    What I did is
                    1. Install fresh RASPBIAN STRETCH WITH DESKTOP
                    2. After install, configure wifi credentials and enable SSH access
                    3. Connect via SSH and proceed with
                    node -v
                    (got answer “v10.10.0”)
                    cd MagicMirror/
                    • E Offline
                      epi
                      any clue what to do next?
                        MadScientist
                        Not sure this will help but you could try npm install -g electron within your MagicMirror directory.
                        If that doesn’t work, try npm install electron@2.0.0 inside your MM directory.
                        • E Offline
                          epi
                          Issue found, everything works now.
                          Problem was my SD card, it, is (becomes) corrupt at some point.
                            MadScientist
                            That’s why I run mine from a cheap SSD (Kingston A400, 120GB iirc). Much faster and no risk of corrupting it. I paid 27€ for my SSD. At this price I think it is worth considering buying one.
                              Ajay1889 @epi
                              Please try the following
                              sudo apt-get remove nodejs nodejs-legacy nodered
                              after that
                              curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
                              sudo apt-get install -y nodejs
                              sudo npm install -g npm@latest
                              after that enter in the repository with
                              cd MagicMirror
                              If have not install MM, use this from github
                              then install and run the app with
                              This method worked for me.
                              Credit: @NoNameRo
