    Updating MagicMirror from v2.1.3 to v2.5.0
    14 Posts 4 Posters 7.0k Views 4 Watching
      Mykle1 Project Sponsor Module Developer @el97
      @el97
      Oy! Ok, then perhaps he’ll see your comment and have some success
      • justjim1220J Offline
        justjim1220 Module Developer @el97
        @el97
        If you made any changes to the original MM2, you will need to move them, or delete them.
        If you could post a screen shot of the terminal errors, might be able to help you.
        Jim Hallock - 1995
        el97E 1 Reply Last reply Reply Quote 0
        • el97E Offline
          el97 @justjim1220
          @justjim1220 Uum… Im not the one that needs help :P @chetnaik is the one that made the post ;)
          justjim1220J 1 Reply Last reply Reply Quote 0
          • C Offline
            chetnaik
            Here what I did
            1. sudo apt-get update
            2. sudo apt-get full-upgrade
            3. sudo rpi-update
            4. sudo reboot
              pi@raspi:~ $ node -v
              v10.11.0
              pi@raspi:~ $ apt list nodejs
              Listing… Done
              nodejs/unknown,now 10.11.0-1nodesource1 armhf [installed]
              N: There are 2 additional versions. Please use the ‘-a’ switch to see them.
              pi@raspi:~ $ sudo apt update
              Hit:1 http://archive.raspberrypi.org/debian stretch InRelease
              Hit:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
              Hit:3 https://deb.nodesource.com/node_10.x stretch InRelease
              Reading package lists… Done
              Building dependency tree
              Reading state information… Done
              All packages are up to date.
              pi@raspi:~ $ sudo apt install nodejs
              nodejs is already the newest version (10.11.0-1nodesource1).
              The following packages were automatically installed and are no longer required:
              lxkeymap python-cairo python-gobject python-gobject-2 python-gtk2 python-xklavier
              Use ‘sudo apt autoremove’ to remove them.
              0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
              v10.11.0
            pi@raspi:~/MagicMirror $ npm run config:check
            magicmirror@2.1.3 config:check /home/pi/MagicMirror
            node tests/configs/check_config.js
            Checking file… /home/pi/MagicMirror/config/config.js
            Your configuration file don’t containt syntax error :)
            pi@raspi:~/MagicMirror $ ls -a
            . core .github js package.json splashscreen
            … css .gitignore jsconfig.json package-lock.json tests
            CHANGELOG.md .eslintignore Gruntfile.js LICENSE.md README.md translations
            clientonly .eslintrc.json index.html modules run-start.sh .travis.yml
            config fonts installers node_modules serveronly vendor
            pi@raspi:~/MagicMirror $ sudo git pull && npm install
            fatal: Not a git repository (or any of the parent directories): .git
            pi@raspi:~/MagicMirror $ git stash
            pi@raspi:~/MagicMirror $ fatal: Not a git repository (or any of the parent directories): .git
            -bash: syntax error near unexpected token `(’
            pi@raspi:~/MagicMirror $ ^C
            pi@raspi:~/MagicMirror $ git init
            Initialized empty Git repository in /home/pi/MagicMirror/.git/
            fatal: bad revision ‘HEAD’
            fatal: Needed a single revision
            You do not have the initial commit yet
            fatal: No remote repository specified. Please, specify either a URL or a
            remote name from which new revisions should be fetched.
            Reinitialized existing Git repository in /home/pi/MagicMirror/.git/
            pi@raspi:~/MagicMirror $ git remote add origin https://github.com/MichMich/MagicMirror.git
            remote: Enumerating objects: 25, done.
            remote: Counting objects: 100% (25/25), done.
            remote: Compressing objects: 100% (20/20), done.
            remote: Total 10389 (delta 7), reused 16 (delta 5), pack-reused 10364
            Receiving objects: 100% (10389/10389), 12.11 MiB | 5.68 MiB/s, done.
            Resolving deltas: 100% (5930/5930), done.
            From https://github.com/MichMich/MagicMirror
            • [new branch] develop -> origin/develop
            • [new branch] master -> origin/master
            • [new branch] snyk-fix-zrd9ko -> origin/snyk-fix-zrd9ko
            • [new branch] v1.0.0 -> origin/v1.0.0
            • [new branch] weather-refactor -> origin/weather-refactor
            • [new tag] v2.5.0 -> v2.5.0
            • [new tag] V2.2.1 -> V2.2.1
            • [new tag] v.2.1.3 -> v.2.1.3
            • [new tag] v2.0.0 -> v2.0.0
            • [new tag] v2.0.1 -> v2.0.1
            • [new tag] v2.0.2 -> v2.0.2
            • [new tag] v2.0.3 -> v2.0.3
            • [new tag] v2.0.4 -> v2.0.4
            • [new tag] v2.0.5 -> v2.0.5
            • [new tag] v2.1.0 -> v2.1.0
            • [new tag] v2.1.1 -> v2.1.1
            • [new tag] v2.1.2 -> v2.1.2
            • [new tag] v2.2.0 -> v2.2.0
            • [new tag] v2.2.2 -> v2.2.2
            • [new tag] v2.3.0 -> v2.3.0
            • [new tag] v2.3.1 -> v2.3.1
            • [new tag] v2.4.0 -> v2.4.0
            • [new tag] v2.4.1 -> v2.4.1
              There is no tracking information for the current branch.
              Please specify which branch you want to merge with.
              See git-pull(1) for details.
              git pull
            If you wish to set tracking information for this branch you can do so with:
            git branch --set-upstream-to=origin/<branch> master
            pi@raspi:~/MagicMirror $ npm install
            magicmirror@2.1.3 install /home/pi/MagicMirror
            cd vendor && npm install
            audited 5 packages in 2.014s
            found 2 low severity vulnerabilities
            run npm audit fix to fix them, or npm audit for details
            magicmirror@2.1.3 postinstall /home/pi/MagicMirror
            sh installers/postinstall/postinstall.sh && npm run install-fonts
            MagicMirror installation successful!
            magicmirror@2.1.3 install-fonts /home/pi/MagicMirror
            cd fonts && npm install
            audited 1 package in 1.909s
            found 0 vulnerabilities
            audited 2152 packages in 35.461s
            found 65 vulnerabilities (27 low, 27 moderate, 8 high, 3 critical)
            pi@raspi:~/MagicMirror $ npm audit
                               === npm audit security report ===
            				   found 65 vulnerabilities (27 low, 27 moderate, 8 high, 3 critical) in 2152 scanned packages
            run npm audit fix to fix 23 of them.
            41 vulnerabilities require semver-major dependency updates.
            1 vulnerability requires manual review. See the full report for details.
            pi@raspi:~/MagicMirror $ npm audit fix
            phantomjs-prebuilt@2.1.16 install /home/pi/MagicMirror/node_modules/phantomjs-prebuilt
            node install.js
            PhantomJS not found on PATH
            Unexpected platform or architecture: linux/arm
            It seems there is no binary available for your platform/architecture
            Try to install PhantomJS globally
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: phantomjs-prebuilt@2.1.16 (node_modules/phantomjs-prebuilt):
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: phantomjs-prebuilt@2.1.16 install: node install.js
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
            • grunt@1.0.3
            • request@2.88.0
            • jshint@2.9.6
            • mocha-logger@1.0.6
            • socket.io@2.1.1
            • moment@2.22.2
              added 55 packages from 547 contributors, removed 16 packages and updated 36 packages in 126.138s
              fixed 23 of 65 vulnerabilities in 2152 scanned packages
              1 vulnerability required manual review and could not be updated
              4 package updates for 41 vulns involved breaking changes
              (use npm audit fix --force to install breaking changes; or refer to npm audit for steps to fix these manually)
              pi@raspi:~/MagicMirror $ npm audit fix --force
              npm WARN using --force I sure hope you know what you are doing.
            node install.js
            electron-chromedriver@2.0.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
            node ./download-chromedriver.js
            successfully downloaded and extracted!
            electron@3.0.2 postinstall /home/pi/MagicMirror/node_modules/electron
            node install.js
            Downloading tmp-1923-1-SHASUMS256.txt-3.0.2
            [============================================>] 100.0% of 4.74 kB (4.74 kB/s)
            npm WARN grunt-stylelint@0.9.0 requires a peer of stylelint@^8.0.0 but none is installed. You must install peer dependencies yourself.
            npm WARN stylelint-config-recommended@1.0.0 requires a peer of stylelint@^8.0.0 but none is installed. You must install peer dependencies yourself.
            npm WARN stylelint-config-standard@17.0.0 requires a peer of stylelint@^8.0.0 but none is installed. You must install peer dependencies yourself.
            • mocha@5.2.0
            • spectron@4.0.0
            • electron@3.0.2
            • stylelint@9.6.0
              added 674 packages from 887 contributors, removed 60 packages, updated 125 packages and moved 4 packages in 214.794s
              fixed 37 of 38 vulnerabilities in 2324 scanned packages
              4 package updates for 29 vulns involved breaking changes
              (installed due to --force option)
              pi@raspi:~/MagicMirror $ git status
              On branch master
            Initial commit
            Untracked files:
            (use “git add …” to include in what will be committed)
                .eslintignore
                .eslintrc.json
                .github/
                .gitignore
                .travis.yml
                CHANGELOG.md
                Gruntfile.js
                LICENSE.md
                README.md
                clientonly/
                config/
                core
                css/
                fonts/
                index.html
                installers/
                js/
                jsconfig.json
                modules/
                package-lock.json
                package.json
                run-start.sh
                serveronly/
                splashscreen/
                tests/
                translations/
                vendor/
            nothing added to commit but untracked files present (use “git add” to track)
            • C Offline
              chetnaik
              after performing above steps still package.json says version": “2.1.3”
              so my question is did above process upgraded my magicmirror to v2.5.0? ??
              here are more info from package.json file.
              “name”: “magicmirror”,
              “version”: “2.1.3”,
              “description”: “The open source modular smart mirror platform.”,
              “main”: “js/electron.js”,
              “scripts”: {
              “start”: “sh run-start.sh”,
              “install”: “cd vendor && npm install”,
              “install-fonts”: “cd fonts && npm install”,
              “postinstall”: “sh installers/postinstall/postinstall.sh && npm run install-fonts”,
              “test”: “NODE_ENV=test ./node_modules/mocha/bin/mocha tests --recursive”,
              “test:unit”: “NODE_ENV=test ./node_modules/mocha/bin/mocha tests/unit --recursive”,
              “test:e2e”: “NODE_ENV=test ./node_modules/mocha/bin/mocha tests/e2e --recursive”,
              “config:check”: “node tests/configs/check_config.js”
              “repository”: {
              “type”: “git”,
              “url”: “git+https://github.com/MichMich/MagicMirror.git”
              “keywords”: [
              “magic mirror”,
              “smart mirror”,
              “mirror UI”,
              “modular”
              “author”: “Michael Teeuw”,
              “contributors”: [
              “https://github.com/MichMich/MagicMirror/graphs/contributors”
              “license”: “MIT”,
              “bugs”: {
              “url”: “https://github.com/MichMich/MagicMirror/issues”
              “homepage”: “https://magicmirror.builders”,
              “devDependencies”: {
              “chai”: “^3.5.0”,
              “chai-as-promised”: “^6.0.0”,
              “current-week-number”: “^1.0.7”,
              “grunt”: “^1.0.3”,
              “grunt-eslint”: “latest”,
              “grunt-jsonlint”: “latest”,
              “grunt-markdownlint”: “^1.0.39”,
              “grunt-stylelint”: “latest”,
              “grunt-yamllint”: “latest”,
              “http-auth”: “^3.1.3”,
              “jshint”: “^2.9.6”,
              “mocha”: “^5.2.0”,
              “mocha-each”: “^1.1.0”,
              “spectron”: “^4.0.0”,
              “stylelint”: “^9.6.0”,
              “stylelint-config-standard”: “latest”,
              “time-grunt”: “latest”
              “dependencies”: {
              “body-parser”: “^1.17.2”,
              “colors”: “^1.1.2”,
              “electron”: “^3.0.2”,
              “express”: “^4.15.3”,
              “express-ipfilter”: “0.3.1”,
              “feedme”: “latest”,
              “helmet”: “^3.6.1”,
              “iconv-lite”: “latest”,
              “mocha-logger”: “^1.0.6”,
              “moment”: “^2.22.2”,
              “request”: “^2.88.0”,
              “rrule-alt”: “^2.2.5”,
              “simple-git”: “^1.73.0”,
              “socket.io”: “^2.1.1”,
              “valid-url”: “latest”,
              “walk”: “latest”
                @el97 Apologies!
                Jim Hallock - 1995
                • el97E Offline
                  el97 @justjim1220
                  @justjim1220 Np. We all can read stuff wrong sometimes :P
                    justjim1220 Module Developer @chetnaik
                    @chetnaik
                    delete the package.json and the package lock.json
                    then retry git pull && npm install
                    Jim Hallock - 1995
                    • C Offline
                      chetnaik @justjim1220
                      @justjim1220 … still not working :(… I’m going to rename or move Current MM and install new version … thank you…;)
                        @chetnaik
                        that may be your best option
                        Jim Hallock - 1995
