    Modules with Images not Displaying
    10 Posts 3 Posters 3.5k Views 3 Watching
      StrIIker
      I have been trying to add a few modules which are supposed to display images to my mirror. Thus far, none of them have been loading the images. I have tried MMM-moon-phases, MMM-earth, and MMM-mars and none load their image. I get the header and some form of a spinning icon or a square outline etc. I saw that a couple people pointed out elsewhere that the moon phase module was not working for them either.
      I am running the latest build of Magic Mirror (2.5.0). Has anyone else who is using these modules or other similar modules which load an image from a remote site run into issues? If not, are you on an older build of Magic Mirror? Thanks!
        Mykle1 Project Sponsor Module Developer @StrIIker
        @striiker
        Did you run npm install in the MMM-EARTH directory first?
        Then, this should be your default config.js entry for MMM-EARTH:
            module: "MMM-EARTH",
            position: "bottom_center",
                mode: "Natural",
                rotateInterval: 15000,
                MaxWidth: "50%",
                MaxHeight: "50%",
        and the default config.js entry for MMM-MARS
            module: 'MMM-MARS',
            position: 'top_left',
                rover: "curiosity",              // which rover? curiosity, opportunity or spirit
                sol: "200",                      // sol date you want pictures from
                useHeader: false,                // true if you want a header
                header: "",                      // useHeader must be true
                maxWidth: "300px",
                rotateInterval: 5 * 60 * 1000,   // new image 5 minutes
          StrIIker @Mykle1
          @mykle1
          Yes, I did run the nom install command from the MMM-EARTH directory and it completed the install. I also have the config in place as listed. Please see a screen shot of the lower portion of my display… (and yes, that news headline is terrifying!) ;)
          Here’s my command summary from when I installed MMM-EARTH
          pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/mykle1/MMM-EARTH.git
          Cloning into 'MMM-EARTH'...
          remote: Enumerating objects: 361, done.
          remote: Total 361 (delta 0), reused 0 (delta 0), pack-reused 361
          Receiving objects: 100% (361/361), 1.73 MiB | 2.15 MiB/s, done.
          Resolving deltas: 100% (202/202), done.
          pi@raspberrypi:~/MagicMirror/modules $ cd MMM-EARTH/
          pi@raspberrypi:~/MagicMirror/modules/MMM-EARTH $ npm install
          npm notice created a lockfile as package-lock.json. You should commit this file.
          added 49 packages in 41.578s
          EDIT: Here’s a link to the other module which is having issues:
          https://github.com/spectroman/mmm-moon-phases/issues/11
            StrIIker @StrIIker
            Here are my config entries for the two modules…
                module: 'MMM-MARS',
                position: 'bottom_left',
                    maxWidth: "300px",
                    mode: "Natural",
                    MaxWidth: "50%",
                    MaxHeight: "50%",
            justjim1220J Mykle1M 2 Replies Last reply Reply Quote 0
            • justjim1220J Offline
              justjim1220 Module Developer @StrIIker
              @striiker
              Have your tried rebooting your system?
              Jim Hallock - 1995
                @striiker
                I just copy and pasted your config entry from above and both modules fired right up. Have you changed anything in the module files?
                  StrIIker @justjim1220
                  @justjim1220 said in Modules with Images not Displaying:
                  @striiker
                  Derp… No… I should have done that!! It’s all working now… Thank you for the advice!
                    StrIIker
                    @mykle1 said in Modules with Images not Displaying:
                    @striiker
                    Well, looks like I should have rebooted my system. I was going to and thought “nah, I shouldn’t have to do that”. Then it was suggested by @justjim1220 and so I tried it and now both are working… Thank you both for your help!!
                      @striiker said in Modules with Images not Displaying:
                      True, you should not have to do that but I’m glad you got them working. :thumbsup:
                      justjim1220J 1 Reply Last reply Reply Quote 1
                        justjim1220 Module Developer @Mykle1
                        @mykle1 @StrIIker
                        All I know is that with the new MM update that came out on the 1st of October, this is the only way I have been able to get some modules to work, including after the MM update. Was suggested to me by Michael Teeuw when I first updated to v2.5.0.
                        Jim Hallock - 1995
