    how to pull new element added to an array?
    57 Posts 4 Posters 25.3k Views 4 Watching
      sdetweil @justjim1220
      @justjim1220 you have to match up the feed definition (feeds array) with the element in the source response (newsItems array) somehow
      the source does not send the icon back
      justjim1220J 2 Replies Last reply Reply Quote 0
      • justjim1220J Offline
        justjim1220 Module Developer @sdetweil
        that’s because I don’t think the source has an icon to pull from it.
        So, is there a way to put the icons in an image folder in the newsfeed directory and pull from there for each corresponding newsfeed?
        Jim Hallock - 1995
          this is how I was able to modify the code to show a single icon and to get it to scroll across the screen
          https://forum.magicmirror.builders/assets/uploads/files/1539381868184-screenshot-146.png
          Jim Hallock - 1995
            sdetweil
            right… you hard coded it…
            justjim1220J 1 Reply Last reply Reply Quote 0
              So, is what I am wanting to do even possible?
              Jim Hallock - 1995
                @justjim1220 sure… just have to figure out how to find the feeds entry from the newsItem entry… you MAY/PROBABLY have to add something to the newsItem entries (every one) when they are placed in the newsItem array…
                i can’t look at any of the rss code til thursday sometime…
                  Is this what I am looking for?
                  Jim Hallock - 1995
                    sdetweil
                    Note that that data is not part of the item. What code moves the xml to the Json object you are accessing?
                      looking at the code on my phone, the fetcher.js needs another method to parse out the source icon.
                      parser.on("image", function(image){})
                      To set a variable with the icon url,
                      That u can use in the
                      parser.on("item", function(item)
                      To add the icon url to each item to be able to use it during the display process
                      • ? Offline
                        A Former User @justjim1220
                        @justjim1220
                        But not all RSS would have that channel.image. that is optional.
                        justjim1220J 1 Reply Last reply Reply Quote 1
                        • 6
                        • 2 / 6
