    Dynamic Module change
    11 Posts 5 Posters 8.8k Views 5 Watching
      Sillec123
      Hello,
      it would be very cool if you could choose an area with a group of x modules, which will change between xx seconds. For example, you have module traffic and module hue. It will show the traffic and after xx seconds it will show the hue module. For me this should be a magic mirror default function. We could have areas like metro tiles.
      For example:
      metro tile top center
      metro tile top left
      metro tile top right
      metro tile middle center
      metro tile middle left
      metro tile middle right
      metro tile bottom center
      metro tile bottom left
      metro tile bottom right
      and then:
      metro tile middle left = module calendar x, module calendar y, module todois (duration 5 seconds)
      metro tile bottom left = module sonos, module hue (duration 5 seconds)
      metro tile middle right = module traffic me, module traffic girlfriend
      All metro tile would update between the duration. We could use more modules on the limited space and we could use modules more than one time with different informations.
      This would be amazing.
      • D
        done
        Maybe this is what you’re looking for?
        https://forum.magicmirror.builders/topic/516/display-modules-in-a-carousel
          Sillec123
          No this is only a module to change type. I mean a magic mirror main function with more than one area.
          • J
            Jopyth Moderator
            I think you can use this. Have a look at Scheduling Module Display.
            Example:
            hides and shows modules
            Helpful sticky: How to troubleshoot
              Sillec123
              Thanks but if i see it right, i have to build thousands of entries in my config for change the modules every xxx seconds. That’s not the goal.
              J I 2 Replies Last reply
              • J
                Jopyth Moderator @Sillec123
                @Sillec123 You have to create one (pair of?) entries per module, as I see it.But this is limited to a per minute schedule. What you want might be an extension of the Carousel, but configurable for areas. Or a per second scheduling of the Module Scheduler.
                S I 2 Replies Last reply
                  Sillec123 @Jopyth
                  @Jopyth Exactly but i think, it should be a main function and no module. It would make the smart mirror really smart. Please have a look on my example.
                  cowboysdudeC 1 Reply Last reply
                  • cowboysdudeC
                    cowboysdude Module Developer @Sillec123
                    @Sillec123 said in Dynamic Module change:
                    You could do it. Just build a ‘metro’ module and then add ‘classes’ to your modules config.js…
                    But there is also a carousel module and a module scheduler…
                    • I
                      ianperrin @Jopyth
                      @Jopyth said in Dynamic Module change:
                      I’ve not tried it but as the node cron module supports seconds, then MMM-ModuleScheduler may too. Feel free to try using a 6 part expression rather than the 5 part expressions in the examples for the module and report back
                      “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
                      Reply Quote 1
                      • I
                        ianperrin @Sillec123
                        Possibly, but the module now supports global, group and individual schedules so the configurations can be minimised which may help.
                        Reply Quote 1
                          Sillec123
                          Thanks i will try it later.
