    First MagicMirror
    28 Posts 13 Posters 31.3k Views 14 Watching
    • delightedCrowD Offline
      delightedCrow Project Sponsor Module Developer @flodus
      @flodus thanks for the comments, sorry for the wait in reply :)
      I’m using the Weather Icons class names for the DarkSky API (formerly Forecast.io), so you can add a CSS color rule for each of these icon classes (this listed taken from the API here):
      wi-forecast-io-clear-day: day-sunny
      wi-forecast-io-clear-night: night-clear
      wi-forecast-io-rain: rain
      wi-forecast-io-snow: snow
      wi-forecast-io-sleet: sleet
      wi-forecast-io-wind: strong-wind
      wi-forecast-io-fog: fog
      wi-forecast-io-cloudy: cloudy
      wi-forecast-io-partly-cloudy-day: day-cloudy
      wi-forecast-io-partly-cloudy-night: night-cloudy
      wi-forecast-io-hail: hail
      wi-forecast-io-thunderstorm: thunderstorm
      wi-forecast-io-tornado: tornado
      So for example, if you wanted to change the sunny day icon color you would add the following rule to your custom.css file:
      .wi-forecast-io-clear-day {
        color: #ffff00;
      If you want to target the forecast sunny day icon specifically you would add .forecast before the icon class name like this:
      .forecast .wi-forecast-io-clear-day {
        color: #ffff00;
      And if you want to target the current day’s sunny day icon specifically you would add .current__temperature before the icon class name like this:
      .current__temperature .wi-forecast-io-clear-day {
        color: #ffff00;
      Hope this helps!
      • WILLIAM_WANDIEW Offline
        WILLIAM_WANDIE
        This is really nice…
        delightedCrowD 1 Reply Last reply Reply Quote 0
          delightedCrow Project Sponsor Module Developer @WILLIAM_WANDIE
          @WILLIAM_WANDIE Thanks a ton :D
          • P Offline
            pnobrega
            Hi. Great look.
            By any change you took pics while mounting?
            Looking for ideias for the frame and how to put all together and secure…
            thanks
              delightedCrow Project Sponsor Module Developer @pnobrega
              @pnobrega Thanks, I did a couple of blog posts about the monitor tear down and the framing process which show some pics.
              This version of Wallberry is mostly a prototype held together with hope and electrical tape, so I don’t know how great a model it will be for you (others have done it much better with better tools), but it’s a fun example of doing a wall display with few resources.
              • HayyatAliH Offline
                HayyatAli
                well done…liked your work…i m interested to build this mirror but really don’t know how to start???from where should i start???any help???
                mumblebajM delightedCrowD 2 Replies Last reply Reply Quote 0
                • mumblebajM Offline
                  mumblebaj Module Developer @HayyatAli
                  @HayyatAli
                  In my opinion, get a Pi 3 B+, download the software and follow the instructions to install. Then play around with some of the modules and see how far you get. Took me only a few hours to get mine up an running and I explore different modules as often as I can.
                    delightedCrow Project Sponsor Module Developer @HayyatAli
                    @HayyatAli thanks!
                    Breaking the project into small steps is a good idea and @mumblebaj has really good advice in starting with the raspberry pi. If you don’t already have one I recommend taking a look at Adafruit. Once you have your pi set up you can look at getting a monitor, then you can decide how you want to frame it.
