    Followed wiki, but the screen does not rotate
    6 Posts 3 Posters 1.8k Views 3 Watching
    • K Offline
      Klinge
      Hello, I installed the latest version of MM.
      My problem, i cannot rotate my screen. I followed the wiki manual von MichMich.
      I added the following two lines to /boot/config.txt
      #Enable the Open GL driver to decrease Electron's CPU usage
      dtoverlay=vc4-kms-v3d
      and I added the following line to ~/.config/lxsession/LXDE-pi/autostart
      @xrandr --output HDMI-1 --rotate right
      But the screen does not rotate.
      Could it be a problem, that there is a Monitor/USB Switch between the raspberry and the monitor?
      I would be very grateful if someone could help me.
      Thank you in advance.
      Lars
        Mykle1 Project Sponsor Module Developer @Klinge
        @klinge said in Followed wiki, but the screen does not rotate:
        Try it without the Monitor/USB Switch. If it works, then it’s the switch. If it doesn’t, something else is amiss.
        • K Offline
          Klinge
          I tried it without the switch. But unfortunately it still doesn´t work.
          • cirdanC Offline
            cirdan
            With the risk of sounding like the helpdesk.“did you reboot between attemps”
            And to be sure, you are using the hdmi port?
            Modules MMM-rainfc, MMM-bustimes, MMM-Harmony, MMM-Rijks
            • K Offline
              Klinge
              My Monitor has a DVI Interface, so I am using an hdmi dvi adapter. Could it be that? What could I do to rotate with DVI?
              • cirdanC Offline
                cirdan
                Its about using the hdmi output of the pi. And it looks you’re doing that. But you can try hooking up the pi to another monitor, e.g. a tv to rule it out?
