    MMM-NOAA3
    25 Posts 9 Posters 16.8k Views 9 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @Binog
      @Binog
      I pulled these from one of the css files that come with NOAA3. You can put them in your custom.css file and change the values. I’m not sure if this is all of them as I did not test.
       .MMM-NOAA3 .font {
           font-size: 23px;
      .MMM-NOAA3 .fontac {
           font-size: 23px;
           color:#e4ab5f;
      .MMM-NOAA3 .fontss {
           font-size: 23px;
           color: #e0e29a;
      .MMM-NOAA3 .fontauw {
           font-size: 23px;
           color:#51c7ca;
      .MMM-NOAA3 .fontfor {
           font-size: 23px;
           color: #000;
      • B
        Binog
        Thank You Mykle1
        changing these font sizes does not seem to change anything,… going to try more in a couple of days,…
        • Mykle1M
          @Binog
          I know that module uses several choices of css files. Look inside the css file that you have chosen and identify the fonts being employed. Or, if you are familiar with using the dev console you can identify the fonts there. In either case, you can take that info into your custom.css file and modify the font sizes, etc
          EDIT
          I just thought of something
          I don’t know if the table will expand to accommodate larger fonts even if you manage to make them bigger. Perhaps someone else will chime in here that knows css better than I.
          • justjim1220J
            justjim1220 Module Developer
            @cowboysdude
            This came up today:
            TypeError: Cannot read property 'pollution' of undefined
                at Object.parseAIR (C:\Users\jiman\MagicMirror\modules\MMM-NOAA3\providers\ds.js:179:35)
                at Request._callback (C:\Users\jiman\MagicMirror\modules\MMM-NOAA3\providers\ds.js:171:28)
                at Request.self.callback (C:\Users\jiman\MagicMirror\modules\MMM-NOAA3\node_modules\request\request.js:185:22)
                at Request.emit (events.js:182:13)
                at Request.<anonymous> (C:\Users\jiman\MagicMirror\modules\MMM-NOAA3\node_modules\request\request.js:1157:10)
                at IncomingMessage.<anonymous> (C:\Users\jiman\MagicMirror\modules\MMM-NOAA3\node_modules\request\request.js:1079:12)
                at Object.onceWrapper (events.js:273:13)
                at IncomingMessage.emit (events.js:187:15)
                at endReadableNT (_stream_readable.js:1090:12)
                at process._tickCallback (internal/process/next_tick.js:63:19)
            Any idea what it means?
            Any idea how to fix it?
            Thanks in advance! ;)
            “Life’s Too Short To Dance With Ugly People”
            Jim Hallock - 1995
              sdetweil @justjim1220
              @justjim1220 said in MMM-NOAA3:
              appears the api did not return the expected data
              data.pollution failed as data does not have a value
