    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 915.5k Views 74 Watching
    • N Offline
      nobita @j.e.f.f
      @j-e-f-f
      Thanks for your module,it 's very nice and useful
      I have problem ,this module not support my language
      because ,I am Thai peaple
      I would to know how to add support Thai language
      Thank for your help
        sdetweil @humdinger44
        @humdinger44 try pm2 list from the MagicMirror folder
        • N Offline
          nobita @nobita
          @j-e-f-f
          I try to adjust fontsize in custom.css but not work
          so I would like to know how to Enlarge fontsize and change color
          at position A,B,C,D,E (as photo)
          Thanks for hint
          • rudibaraniR Offline
            rudibarani Project Sponsor
            Dear @j-e-f-f ,
            thank you for this great module. I enjoy looking at it every morning :grinning_face:
            I would like to use real world data from a temperature sensor at our house instead of the “current temperature” data from the weather service.
            Would it be possible to optionally add an URL to the config that returns the temperature as plain value (e.g. 15.76) and replace the corresponding value from the weather service?
            Thanks for considering this,
            Phillip
              j.e.f.f Project Sponsor Module Developer @rudibarani
              @rudibarani it’s a great idea but not exactly as simple as enabling a second data source URL. As my module is designed to use the Dark Sky API, I would need a separate routine to handle the different data format, and it would be a one-off for just your sensor model. Of course others will want their sensors supported and so on… unfortunately I don’t have the time to support such variances in functionality, which all do what my module already does — provide you with real-time weather information.
              One of the major benefits of the Dark Sky API is how accurate it is, given you can put in your exact long/lat coordinates. The temperature you’ll get from the API should be very close to what your sensor is providing, maybe off by at most one or two degrees.
              That said, my module is very much open-source. You are free to fork it and try to add this functionality on your own. If your programming experience is limited, modifying someone else’s code is a good way to learn. My code is very well documented so you should have a good idea as to what each part does. Also JavaScript is very forgiving and makes for a great beginner’s language.
              I know this isn’t the answer you wanted to hear, but I hope you’ll be encouraged give modifying my module a shot. It’s very satisfying when you make something like this work for your exact needs. It’s how I got started, and I guess it’s just snowballed from there! :D
              rudibaraniR 1 Reply Last reply Reply Quote 0
                rudibarani Project Sponsor @j.e.f.f
                Dear @j-e-f-f,
                thanks for your feedback. I don’t have much coding skills (yet) - but I will try :slightly_smiling_face:
                Best,
                Phillip
                  Matman
                  • is it possible to hide the LINE under?
                    “Powered by Dark…”
                  • Is it possible to delete the Test after the current Wind?
                  • Is it possible to change the Time over the current Weather?
                    Matman @Matman
                    This post is deleted!
                    • N Offline
                      nobita @trividar
                      @trividar how to hide "Power by Darksky " I change custom.css like this
                      .MMM-DarkSkyForecast .attribution {
                      color:black; }
                      T 1 Reply Last reply Reply Quote 1
                      • T Offline
                        trividar @nobita
                        @nobita Thank you!
                        • T Offline
                          t.architecture99
                          i cant git clone and install , what can i do ?
                          S StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                            sdetweil @t.architecture99
                            @t-architecture99 hm… never asks for my username
                            • StoffbeuteluweS Offline
                              Stoffbeuteluwe Project Sponsor @t.architecture99
                              @t-architecture99
                              git clone https://github.com/jclarke0000/MMM-DarkSkyForecast.git. wrong
                              git clone https://github.com/jclarke0000/MMM-DarkSkyForecast.git right
                              the Point at the end is the Problem
                              S T 2 Replies Last reply Reply Quote 4
                                sdetweil @Stoffbeuteluwe
                                @Stoffbeuteluwe nice catch!
                                • T Offline
                                  t.architecture99 @Stoffbeuteluwe
                                  @Stoffbeuteluwe many thanks to you ^^
                                  • CynicC Offline
                                    Cynic
                                    Thanks for such a beautiful module! Looks great. Is it possible to position the module horizontally?
                                    I am not a wizard. I am just learning.
                                      Robtrowb
                                      I can’t figure out how to make the temperature row fonts bigger
                                      The 80/49 0% 6 mph
                                      RT
                                        BD0G
                                        Latest version of Magic Mirror on Raspberry Pi Zero W.
                                        Git cloned directory for MMM-DarkSkyForecast. Directory created under MagicMirror/Modules. Ran npm install. . Installed and mentioned 16 severe vulnerabilities.
                                        Whatever?
                                        Modified /config/config.js with entries from git hub repositiory instructions.
                                        Ran linter against config.js. No lint :)
                                        Restarted Magic Mirror. Module does not display. Here is my config.js
                                        /* Magic Mirror Config Sample
                                         * MIT Licensed.
                                        var config = {
                                        	address: "0.0.0.0", // Address to listen on, can be:
                                        	port: 8080,
                                        	ipWhitelist: [], // Set [] to allow all IP addresses
                                        	language: "en",
                                        	timeFormat: 12,
                                        	units: "imperial",
                                        			     // false, default for all  NON-armv6l devices
                                                		module: 'MMM-Remote-Control',
                                                		// uncomment the following line to show the URL of the remote control on the mirror
                                                		position: 'bottom_left',
                                                		// you can hide this module afterwards from the remote control itself
                                                    		apiKey: '56cab4b5d5e24cfea8c436ac591d722c'
                                          			module: "MMM-DarkSkyForecast",
                                          			header: "Weather",
                                          			classes: "default everyone",
                                          			disabled: false,
                                            			apikey: "not gonna share it :)",
                                            			latitude: "39.164581",
                                            			longitude: "-119.766922",
                                            			iconset: "4c",
                                            			concise: false,
                                            			forecastLayout: "table"
                                        			module: "alert",
                                        			module: "updatenotification",
                                        			position: "top_bar"
                                        			module: "clock",
                                        			position: "top_left"
                                        			header: "US Holidays",
                                        						symbol: "calendar-check",
                                        						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
                                          sdetweil @BD0G
                                          @BD0G open the developers window ctrl-shift-i on the keyboard. Select the console tab and scroll up to see any errors, usually red text.
                                            BD0G
                                            I press CTRL-SHIFT-I with Magic Mirror Running and no console is presented. Actually there is no change at all. Its as if I have not pressed any keys.
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 12 / 17
