    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 933.2k Views 74 Watching
      sdetweil @humdinger44
      @humdinger44 can’t do that. Have to stop other 1st. Only one copy running at a time
      H 1 Reply Last reply
      • H
        humdinger44 @sdetweil
        @sdetweil Sorry, I’m wildly incompetent at this.
        My mirror launches in electrum automatically. When I kill it, it just relaunches itself seconds later. I don’t know how to launch that inspection tool without starting a second copy.
          @humdinger44 do
          pm2 show
          Find the name of the app
          Then do
          pm2 stop ????
          Where ??? Is the app name
          Then do the
          npm start dev
          from a terminal window
          • H
            @sdetweil Thanks for walking me through this. Unfortunately ive not been able to identify the process https://i.imgur.com/hgXS13T.png?1
            i tried doing it from different directory locations and with the ls command because show wasnt working.
            • N
              nobita @j.e.f.f
              @j-e-f-f
              Thanks for your module,it 's very nice and useful
              I have problem ,this module not support my language
              because ,I am Thai peaple
              I would to know how to add support Thai language
              Thank for your help
              N 1 Reply Last reply
                @humdinger44 try pm2 list from the MagicMirror folder
                • N
                  nobita @nobita
                  @j-e-f-f
                  I try to adjust fontsize in custom.css but not work
                  so I would like to know how to Enlarge fontsize and change color
                  at position A,B,C,D,E (as photo)
                  Thanks for hint
                  • rudibaraniR
                    rudibarani Project Sponsor
                    Dear @j-e-f-f ,
                    thank you for this great module. I enjoy looking at it every morning :grinning_face:
                    I would like to use real world data from a temperature sensor at our house instead of the “current temperature” data from the weather service.
                    Would it be possible to optionally add an URL to the config that returns the temperature as plain value (e.g. 15.76) and replace the corresponding value from the weather service?
                    Thanks for considering this,
                    Phillip
                    J 1 Reply Last reply
                      j.e.f.f Project Sponsor Module Developer @rudibarani
                      @rudibarani it’s a great idea but not exactly as simple as enabling a second data source URL. As my module is designed to use the Dark Sky API, I would need a separate routine to handle the different data format, and it would be a one-off for just your sensor model. Of course others will want their sensors supported and so on… unfortunately I don’t have the time to support such variances in functionality, which all do what my module already does — provide you with real-time weather information.
                      One of the major benefits of the Dark Sky API is how accurate it is, given you can put in your exact long/lat coordinates. The temperature you’ll get from the API should be very close to what your sensor is providing, maybe off by at most one or two degrees.
                      That said, my module is very much open-source. You are free to fork it and try to add this functionality on your own. If your programming experience is limited, modifying someone else’s code is a good way to learn. My code is very well documented so you should have a good idea as to what each part does. Also JavaScript is very forgiving and makes for a great beginner’s language.
                      I know this isn’t the answer you wanted to hear, but I hope you’ll be encouraged give modifying my module a shot. It’s very satisfying when you make something like this work for your exact needs. It’s how I got started, and I guess it’s just snowballed from there! :D
                      rudibaraniR 1 Reply Last reply
                      • rudibaraniR
                        rudibarani Project Sponsor @j.e.f.f
                        Dear @j-e-f-f,
                        thanks for your feedback. I don’t have much coding skills (yet) - but I will try :slightly_smiling_face:
                        Best,
                        Phillip
                          Matman
                          • is it possible to hide the LINE under?
                            “Powered by Dark…”
                          • Is it possible to delete the Test after the current Wind?
                          • Is it possible to change the Time over the current Weather?
                          M 1 Reply Last reply
                            Matman @Matman
                            • N
                              nobita @trividar
                              @trividar how to hide "Power by Darksky " I change custom.css like this
                              .MMM-DarkSkyForecast .attribution {
                              color:black; }
                              T 1 Reply Last reply
                              • T
                                trividar @nobita
                                @nobita Thank you!
                                • T
                                  t.architecture99
                                  i cant git clone and install , what can i do ?
                                  S StoffbeuteluweS 2 Replies Last reply
                                    sdetweil @t.architecture99
                                    @t-architecture99 hm… never asks for my username
                                    • StoffbeuteluweS
                                      Stoffbeuteluwe Project Sponsor @t.architecture99
                                      @t-architecture99
                                      git clone https://github.com/jclarke0000/MMM-DarkSkyForecast.git. wrong
                                      git clone https://github.com/jclarke0000/MMM-DarkSkyForecast.git right
                                      the Point at the end is the Problem
                                      S T 2 Replies Last reply
                                      Reply Quote 4
                                        sdetweil @Stoffbeuteluwe
                                        @Stoffbeuteluwe nice catch!
                                        • T
                                          t.architecture99 @Stoffbeuteluwe
                                          @Stoffbeuteluwe many thanks to you ^^
                                          • CynicC
                                            Cynic
                                            Thanks for such a beautiful module! Looks great. Is it possible to position the module horizontally?
                                            I am not a wizard. I am just learning.
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 12 / 17
