    MMM-CalendarExt2
    486 Posts 83 Posters 949.3k Views 83 Watching
    • BKeyportB Offline
      This works. URL Blanked to prevent private data.
      			module: "MMM-CalendarExt2", // https://github.com/MMM-CalendarExt2/MMM-CalendarExt2
      				calendars : [
      						url: "",
      						name: "Main", // Optional, Recommended
      						maxItems: 1,
      						scanInterval: 1000*60*.5, // every 30 seconds, Appt Book, needs this speed
      						beforeDays: 0,
      						afterDays: 2,
      						forceLocalTZ: false,
      • F Offline
        fedale @sdetweil
        This post is deleted!
        • F Offline
          fedale @BKeyport
          @BKeyport This solved the problem. Thank you
          • F Offline
            fedale
            How can i have week numbers as an own colum?
            Showing the weeks separerat in its own colum?
            And the yellow marking accross the week for the current week?
            Like in this picture https://imgur.com/mwwPwEl
            Today i have it in the first day of the week. Due to a small screen its not showing all the calendar inputs as it takes up a row by itself. limiting the amount of events i could have
            • N Offline
              nschertz
              Great Module!! I started customizing a CSS file to enhance the display. I was able to do everything I wanted to do except one mod. I’m trying to make the calendar title font larger on each of 2 calendars, but can’t seem to find where this property is set. Looking for help with this.
              Thx Norb
                sdetweil @nschertz
                @nschertz I don’t know, but you can learn the css settings by using the developers window
                see
                https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1650761970911
                • N Offline
                  nschertz @sdetweil
                  @sdetweil Thanks. That redirect was very helpful. Problem solved.
                  • H Offline
                    hrmax23
                    I’ve added a border around today’s date in the month view but I can’t seem to figure out how to adjust the actual events to not overlap the left border. Anyone know how to do this?
                    • F Offline
                      fedale
                      How do i get an extra colium for week numbers? Today its in the field for monday in my calendar.How do i specify this in css?
                      I have the weeksmark added. But unsure how to resolve this into its own colum. Any one have a surgestion?
                        sdetweil @fedale
                        @fedale use MMM-CalendarExt3.
                        ext2 is no longer supported
                        • F Offline
                          fedale @sdetweil
                          @sdetweil okay thanks. I did not know that.
                            justbob
                            How can I make the calendar show more than two lines of text for each event?
                            I’ve had start and end times set up, but that would leave room for a few letters and it would look like:
                            ‘08:00-09:30 Ext…’
                            Then I’ve used this:
                            .CX2 .weekSlot .event:not(.fullday) .eventMain {
                            height: auto;
                            flex-wrap: wrap;
                            flex-grow: 0;
                            overflow: visible;
                            and it allowed me to have time in one row, and text in another, however if the text alone is more than what could be fit in a single row, again I get 3 dots instead of having the box adjust to the size of the text.
                            It would look like this:
                            ‘08:00-09:30
                            Extended line of t…’
                            Also, whenever I have two enlarged boxes in the same day, the second one would partially go over the previous one, as if the previous one wasn’t enlarged.
                            Any ideas how I could solve these two issues?
                            BKeyportB M 2 Replies Last reply Reply Quote 0
                            • BKeyportB Offline
                              BKeyport Module Developer @justbob
                              @justbob I’d switch to CX3agenda, to be honest. Much better.
                                MMRIZE @justbob
                                @justbob
                                That module doesn’t be designed like that. Of course, a heavy tweak of CSS could be the solution, but not recommended.
                                First, unpretty.
                                Second, The purpose of the module is to glance at outlines at once. Multi lines are not so easy to scan. I recommend transforming the title abbreviately or using color/symbol to distinguish the points rapidly.
                                Third, technically not so easy to align the event cells with different lines(heights) in the same row. To accomplish it, that will inevitably waste space. So I haven’t designed so.
                                  justbob
                                  @MMRIZE @BKeyport
                                  I prefer functionality over looks, and CX3agenda doesn’t satisfy my wants and needs.
                                  I want a calendar which shows a month and a half in advance, and which shows all the events in a single calendar. Having those in a list is both harder for me to follow-up on and find the gaps.
                                  I’ve given a thought to CalendarExt3, and while I like the idea behind it (to make it more simple for regular Joe, as Ext2 “is too complicated”), I’ve got a feeling that it has less features and because of it’s simplicity lacks all the customization options that Ext2 has. Am I right?
                                  As for space wasted, I assume you meant that if one day has, lets say 5 events, and other none, there would basically be a lot of space unused (as in, a lot of empty squares being “empty”, but taking the space anyway)? If so, I really don’t care about that, rather, I prefer it that way.
                                  I don’t want to just glance at it, I want it to be as informative as possible, to help me build my future schedules and plan events. Some events simply need explanation, because one word or shorting that one word won’t cut it.
                                  So, with all that said, does anyone knows of a way to make it work as I imagined?
                                  • G Offline
                                    gonzonia @Guest
                                    I know this module is inactive as @MMRIZE has moved on to CalendarExt3 but I’m hoping someone can point me where to look.
                                    I hadn’t swapped because I was using some functionality in CalendarExt2 that I’m not sure is available in CalendarExt3. (multiple views, weekly and daily calendars)
                                    With the latest update though my calendars aren’t loading. The module isn’t even appearing on screen despite no errors in the log.
                                      MMRIZE @gonzonia
                                      @gonzonia I’ll look inside tomorrow. Today I was in GNR live with my daughter so have no energy anymore. (Love & peace!)
                                        MMRIZE @gonzonia
                                        @gonzonia
                                        Can you send me the calendars and your config? (eouia0819@gmail.com)
                                        • G Offline
                                          gonzonia
                                          @MMRIZE said in MMM-CalendarExt2:
                                          I actually got it working. I needed to do
                                          npm install request
                                          It started working after that. I’m working on setting up another Pi and I’m going to see if I can get CalendarExt3 working in a way that works for what I want it to do. I saw @sdetweil had an CalendarExt3Agenda module that might help. I think I just need to figure out the Views and paging between to move forward to CalendarExt3.
                                          M S 2 Replies Last reply Reply Quote 0
                                            MMRIZE @gonzonia
                                            @gonzonia
                                            I think your transfer would be possible (even though not perfectly)
                                            • Daily/Upcoming/Current view => MMM-CalendarExt3Agenda would be an alternative.
                                            • Multiple views => You can just put the module multiple times in the config.js. No need to duplicate the module and rename it. You can put many times this CX3 module anywhere where you want. (CX3A Also be the same.)
                                            • Paging => So you can just put this month CX3 instance in page1 and +1 month CX3 instance in page2 under your favorite paging module. (PR: I also have my own paging modules. MMM-Scenes is that. If you have interests just check it.)
                                            • Or you can glance other periods (e.g. +3 weeks, -1 months) with notification.
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 24 / 25
