    [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates
    76 Posts 13 Posters 73.8k Views 13 Watching
      mohace @Cr4z33
      @Cr4z33 said in [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates:
      @mohace huh?
      I don’t have those menu’s entries at all.
      Are you using a custom version of the module or? :confused_face:
      Not at all. You can see same pic in shbatm second post, after the first one you replyed.
      @shbatm said in [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates:
      Additional Features Added:
      • Dynamic Module Control menu – uses the new API to create a Module Control menu on the remote page to control other modules via notifications.
      • Custom Menu – ability to specify your own custom menu items from a file (for advanced users)
      • Use PM2 API to control restarts/stops of MM. Can also support starting/stopping other PM2 scripts by passing processName: “scriptToUse” in the query payload.
      Example Dynamic Menu for MMM-Carousel w/ Navigation
      It seems that you need activate some features in modules to show them in this menu. But I don’t know what needs Newsfeed, for to have active his entry.
      • Cr4z33C Offline
        Cr4z33 @mohace
        @mohace Oh yes you are correct I forgot that we can have custom entries indeed.
        Well in my case Newsfeed is showing up by default without having to enable manually something. :man_shrugging_light_skin_tone:
        • L Offline
          Lowis
          I don’t have these entries
          reinstalled twice the module without luck.
          when i first installed this module the entries was there .
          my config.js
                module: 'MMM-Remote-Control',
                position: 'bottom_left',
                  customCommand: {},
                  customMenu: 'custom_menu.json',
                  showModuleApiMenu: true,
                  apiKey: ''
          • swvalentiS Offline
            swvalenti Project Sponsor
            Any idea why my remote control looks like this? It’s lacking the right buttons etc…0_1557623899958_MM.PNG
            • Cr4z33C Offline
              Cr4z33
              I need to add some custom commands to control MMM-RTSPStream streams like if they were tv channel buttons, but I am not skilled enough to understand the interested readme section. :smiling_face_with_open_mouth_cold_sweat:
              @shbatm could you please help me adding one stream button (as example for all the others to add)?
              All I need is to run a combo of ‘RTSP-STOP all’ first (I am using OMXplayer therefore I prefer to kill any running stream first) and ‘RTSP-PLAY streamX’ immediately after.
              Cr4z33C 2 Replies Last reply Reply Quote 0
                When I press Restart MagicMirror it doesn’t restart…if I hit Refresh Browser the browser refreshes. Any idea why Restart MagicMirror command doesn’t work? Running latest updates on all platforms.
                  retroflex Project Sponsor Module Developer @swvalenti
                  @swvalenti Yeah, same here. Would really like to find an answer for this…
                  • Cr4z33C Offline
                    Cr4z33 @Cr4z33
                    @shbatm you there mate please? :smiling_face_with_halo:
                    • Cr4z33C Offline
                      Cr4z33 @Cr4z33
                      It looks like @shbatm is not following this forum since many months.
                      Therefore @bolish or someone else could you please post your custom menu entries code so that I can better figure out how to enter that MMM-RTSPStream code?
                      The related README section didn’t make so much sense to me. :man_shrugging_medium_skin_tone:
                        BD0G
                        Using Raspberry Pi Zero W with latest version of Buster. MM2 working . used command in first post to install MMM-RemoteControl. Used Master Branch and not Dev. Module directory created sucessfully. Edited config.js with appropriate entries. I dont have anything displaying on screen besides the clock and Holidays .
                        Its supposed to display the default webpage in the center of the screen. I dont see that . Just black in that area.
                        Here is the config.js
                        code_tvar config = {
                        	port: 8080,
                        	language: "en",
                        	timeFormat: 12,
                        	units: "imperial",
                        			     // false, default for all  NON-armv6l devices
                                		// uncomment the following line to show the URL of the remote control on the mirror
                                		// position: 'bottom_left',
                                		// you can hide this module afterwards from the remote control itself
                                    		apiKey: '56cab4b5d5e24cfea8c436ac591d722c'
                        			module: "alert",
                        			module: "updatenotification",
                        			position: "top_bar"
                        			module: "clock",
                        			position: "top_left"
                        			header: "US Holidays",
                        						symbol: "calendar-check",
                        						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
                        ext
                          sdetweil @BD0G
                          @BD0G gotta have a position setting
                            BD0G @sdetweil
                            @sdetweil Damn you are helpful!
                            I forgot to uncomment the position setting. Duh. Man little things just slip by. :)
                              BD0G
                              That works. Now I am struggling with understanding the IP Whitelist area . I want to open up access to all IP Addresses internally between 192.168.1.2 and 192.168.1.254 as I am unsure which of those IP addresses will be dynamically assigned to the device I use to access the MMM-Remote-Control app.
                                sdetweil @BD0G
                                @BD0G so, i just clear the whitelist, and allow anyone on my network to connect… (its only me,inside my house)
                                ipWhitelist: [],
                                you will also have to open up the address block
                                address: [] or [0.0.0.0]
                                otherwise it means ONLY the same machine can talk to the mirror…
                                  mohace
                                  Hi. There is a way to call, i.e, module controls/carousel/next slide from url?
                                  • N Offline
                                    Nneuland @shbatm
                                    This post is deleted!
                                    • 4 / 4
