    [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer
    160 Posts 6 Posters 222.3k Views 6 Watching
    • evroomE
      evroom
      Okay, rebooted in order to start fresh.
      Now 1 stream.
      Looks like one actual omxplayer active:
      pi@MagicPi:~/MagicMirror/modules $ ps -eaf | grep omxplayer | grep -v grep
      pi       29320 29185  0 18:39 ?        00:00:00 /bin/sh -c omxplayer  --win 0,0,480,320  -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
      pi       29321 29320  0 18:39 ?        00:00:00 /bin/bash /usr/bin/omxplayer --win 0,0,480,320 -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
      pi       29344 29321 10 18:39 ?        00:00:01 /usr/bin/omxplayer.bin --win 0,0,480,320 -o both http://192.168.178.28:8001/1:0:16:177A:C82:3:EB0000:0:0:0:
      InfoBarTunerState also states there is one stream.
      The will do for today.
      Will do some more testing tomorrow.
      Thanks a lot AxLed for the support so far !!
      MagicMirror version: 2.37.0
      • A
        AxLed Module Developer
        @evroom
        Good to hear you had success and thanks for your challenge with more than one bouquet 😂, helped debugging the module.
        AxLED
        • evroomE
          evroom
          @AxLed
          I have opened 4 feature requests on GitHub.
          To be honest, my MM is hanging a meter or so away from the TV, so I most probably will not make use of the module.
          Navigating through the services list and starting & stopping a stream is not that comfortable
          Although it might be practical to see on my MM what is currently playing and I might use it solely as a program guide.
          Will be available though for some testing.
          • A
            Hi, if the to monitors are close together you can still view 2 different shows :-) .
            I checked your 4 feature requests and added 2 of them in the module.
            For the other two i can not promise, if they will be implemented.
            AxLED
            • A
              @evroom
              In your feature request, you wanted to select a bouquet (if there is more than one):
              Okay.
              Let’s say I have the bouquet “MagicMirror (TV)”, could there be an option to use this one, instead of the default “Favourites (TV)” ?
              I assume “Favourites (TV)” is the default.
              Please check the dev branch of my module.
              1. Rename your MMM-Dreambox folder to _MMM-Dreambox (for example)
              2. do a git clone --branch dev https://github.com/Ax-LED/MMM-Dreambox.git in your modules folder
              3. add new parameters to your config.js, as descriped in readme. (see apibouquet and listmax).
              Regards
              AxLED
              • evroomE
                evroom
                Hi @AxLed ,
                Busy trying your updated module.
                I am struggling a bit with it.
                1/ I suppose I set
                apibouquet: 1,
                Is that correct ?
                What does it do ?
                When just enabling, then why not true or false to make it more clear?
                Or do I set it to 1 for bouquet 1 and 2 for 2, etc?
                Please explain.
                2/ The parameter
                listmax: 10,
                is working, but after play or stop, it jumps to the bouquet name.
                3/ On my install, when I do DB-PLAY, it starts the stream twice.
                So, I have 2 omxplayer process-sets and it takes up 2 streams on my Dreambox.
                EDIT: now streaming Das Erste HD. No other process-sets present.
                Perhaps decoding takes to long and omxplayer is respawning.
                4/ Even though I have employer processes, I do not see anything on my screen.
                I think I have a local issue, as I cannot stream decoded content anymore.
                My MPG2 license is still valid.
                Perhaps a performance issue.
                • evroomE
                  evroom
                  Example for observation/issue 3:
                  DB-PLAY:
                  pi        4190  4061  0 19:31 ?        00:00:00 /bin/sh -c omxplayer  --win 0,625,590,957 -o both http://192.168.178.28:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
                  pi        4191  4190  0 19:31 ?        00:00:00 /bin/bash /usr/bin/omxplayer --win 0,625,590,957 -o both http://192.168.178.28:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
                  pi        4214  4191  7 19:31 ?        00:00:00 /usr/bin/omxplayer.bin --win 0,625,590,957 -o both http://192.168.178.28:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
                  pi        4222  4061  0 19:31 ?        00:00:00 /bin/sh -c omxplayer  --win 0,625,590,957 -o both http://192.168.178.28:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
                  pi        4223  4222  0 19:31 ?        00:00:00 /bin/bash /usr/bin/omxplayer --win 0,625,590,957 -o both http://192.168.178.28:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
                  pi        4246  4223 13 19:31 ?        00:00:00 /usr/bin/omxplayer.bin --win 0,625,590,957 -o both http://192.168.178.28:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
                  After a few seconds and when the stream is visible on the screen:
                  pi        4214  4191 10 19:31 ?        00:00:02 /usr/bin/omxplayer.bin --win 0,625,590,957 -o both http://192.168.178.28:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
                  • A
                    @evroom
                    here are some questions:
                    to 1: apibouquet expects a number (integer) and in java it starts with 0. If i use the xml-sample file of /web/getallservices you send me its in your case as follows:
                    0: Favourites (TV)
                    1: Nederland (TV)
                    2: Duitsland (TV)
                    to 2: i cant reproduce this behavior
                    to 3 & 4: try disabling some other modules, to find out if there is a intolerance beetween modules.
                    AxLED
                    • evroomE
                      evroom
                      to 1: thanks. Very clear.
                      to 2: does not happen always, or too fast to detect (I did ps manually).
                      to 3: did this, but does not help. I have think I have an issue that is related to my install only.
                      Thanks for the changes. It makes it more usable.
                      • Cr4z33C
                        Cr4z33 @AxLed
                        @axled I want to give this module another try for some testing, but I still didn’t understand how am I supposed to stream a Dreambox channel in MM? :hushed_face:
                        • Cr4z33C
                          Cr4z33 @AxLed
                          @axled said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
                          @Cr4z33
                          I dont know if it makes sense, to use a favorite list of services/stations/channels that wont fit on the screen of MM, as the list is to long.
                          Start streaming can be done by selecting one service/station/channel (by using yourmmip:8080/remote?action=NOTIFICATION&notification=DB-SERVICE-NEXT for example) and than start streaming by (yourmmip:8080/remote?action=NOTIFICATION&notification=DB-PLAY).
                          Do you have MMM-Remote-Control installed?
                          Se my previous answer to evroom.
                          AxLED
                          WHERE do I have to enter these commands?
                          In a RPI terminal window?
                          In my ie. Windows 10 Internet browser address box?
                          • A
                            @Cr4z33
                            As you have MMM-Remote-Control installed you can test MMM-Dreambox with MMM-Remote-Control first, to make sure it works at all. (Requirement: Your mirror is reachable by browser in the same network). Open browser and enter (without the spaces around &):
                            • http://yourmmip:8080/remote?action=NOTIFICATION & notification=DB-SERVICE-NEXT (for selecting next service)
                            • http://yourmmip:8080/remote?action=NOTIFICATION & notification=DB-SERVICE-PREV (for selecting prev.service)
                            • http://yourmmip:8080/remote?action=NOTIFICATION & notification=DB-PLAY (for start streaming)
                            • http://yourmmip:8080/remote?action=NOTIFICATION & notification=DB-STOP (for stop streaming)
                            Hint: HD Services need MPG License so maybe start with SD services.
                            You can also try the dev branch, as this is the newer one with more functions.
                            AxLED
                            • Cr4z33C
                              Cr4z33 @AxLed
                              @axled thanks got the remote module working, but then when I send the commands (succesfully confirmed by the web page) I see no streaming going on in MM.
                              By the way I choosed to install the dev branch of your module.
                              • A
                                @Cr4z33
                                Can you show me the MMM-Dreambox Part of your config and some logs?
                                Playing does not work, is selecting DB-SERVICE-NEXT (PREV) working?
                                AxLED
                                • Cr4z33C
                                  Cr4z33 @AxLed
                                  @axled this is the config part:
                                  			module: 'MMM-Dreambox',
                                  			header: 'Vu+ Duo²',
                                  			position: 'bottom_left',
                                  			disabled: false,
                                  				apiBase: 'http://*.*.*.*:****',
                                  				omxargs: ' --win 320,180,1600,900  -o both ',
                                  				refreshInterval: 1000 * 30, //refresh every 30 seconds
                                  				apiabout: '/web/about',
                                  				apiservices: '/web/getallservices',
                                  				apiepgnow: '/web/epgnow?bRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.favourites.tv%22%20ORDER%20BY%20bouquet',
                                  				apizap: '/web/zap?sRef=',
                                  				apiTimerlist: '/web/timerlist',
                                  				apiServicelistplayable: '/web/servicelistplayable?sRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.favourites.tv%22%20ORDER%20BY%20bouquet'
                                  I wanted then to paste here the logs and what was happening when sendings commands, but all I get now is
                                  status	"error"
                                  reason	"unknown_command"
                                  info	"original input: {\"action\":\"NOTIFICATION \",\" notification\":\"DB-PLAY\"}"
                                  I feel like I am missing something? :smiling_face_with_open_mouth_cold_sweat:
                                  This is btw the MMM-Remote-Control config part:
                                  			module: 'MMM-Remote-Control',
                                  			// uncomment the following line to show the URL of the remote control on the mirror
                                  			// you can hide this module afterwards from the remote control itself
                                  • A
                                    @Cr4z33
                                    it is not easy to give support, with this less informations.
                                    As you send me .xml files some days ago, i saw some minor errors in your config.js
                                    1. apibouquet and listmax is missing, so module use defaults (apibouquet: 0, listmax: 15)
                                    2. apiepgnow and apiServicelistplayable are wrong, to match to your receiver/xml file you send me the should look as follows:
                                    • apiepgnow: ‘/web/epgnow?bRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.TerrestrialTv.tv%22%20ORDER%20BY%20bouquet’,
                                    • apiServicelistplayable: ‘/web/servicelistplayable?sRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.TerrestrialTv.tv%22%20ORDER%20BY%20bouquet’,
                                    Can you please also answer my question:
                                    To help you further i need some screenshots of the module on your mirror and some logs (pm2 or from the browser by using F12).
                                    AxLED
                                    • Cr4z33C
                                      Cr4z33 @AxLed
                                      @axled sorry for the late reply. :smiling_face_with_open_mouth_cold_sweat:
                                      I’ve installed your module from scratch and now every MMM-Remote-Control command (but streaming) is working.
                                      Honestly I can’t understand what is wrong because before going to use my decoder with your module all Dreambox-like applications worked like a charm.
                                      What if it depends on using a different WebIf port (I am not using the default 80/8080 port)?
                                      And even if why not?
                                      So far every Android Dreambox app (ie. DreamDroid) or Windows channel editor program for Dreambox that I’ve used worked perfectly.
                                      • A
                                        Some ideas:
                                        Start streaming takes up to 15 seconds, did you wait long enough?
                                        Are you streaming SD or HD channels? HD needs mpg license.
                                        Is the play symbol (triangle) shown after sending the command DB-PLAY?
                                        AxLED
                                        • Cr4z33C
                                          Cr4z33 @evroom
                                          @evroom can you please let me chat with you?
                                          Need to ask you something about this module. :)
                                          evroomE 1 Reply Last reply Reply Quote 0
                                          • evroomE
                                            evroom @Cr4z33
                                            @cr4z33
                                            Yes, you can chat with me.
                                            • 6
                                            • 7
                                            • 8
                                            • 3 / 8
