    [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer
    160 Posts 6 Posters 219.2k Views 6 Watching
    • evroomE Offline
      evroom
      @cr4z33 said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
      I ran the update and now I get continuous PLAY without interruption,
      Can you explain what you mean by this ?
      Do you see the play symbol, but no stream ?
      And a stupid question, but I made this mistake just now:
      Do you do DB-PLAY or DB-START ?
      I did DB-START and it did not work, obviously.
      But before I found out it took a while.
      MagicMirror version: 2.37.0
      • evroomE Offline
        evroom
        @Cr4z33
        Can you add
        --genlog
        to your config.js omxargs string ?
        Like this:
        omxargs: ' --genlog --win 0,625,590,957 -o both ',
        The restart mm, select a service and do DB-PLAY.
        There should be a file generated:
        /home/pi/MagicMirror/omxplayer.log
        If not try to find it:
        $ sudo find / -name omxplayer.log
        It should have contents like this:
        pi@MagicPi:~ $ head -25 /home/pi/MagicMirror/omxplayer.log
        19:45:37 T:18446744073580839086   DEBUG: DllBcm: Using omx system library
        19:45:37 T:18446744073580840432   DEBUG: DllOMX: Using omx system library
        19:45:37 T:18446744073580841193   DEBUG: DllAvFormat: Using libavformat system library
        19:45:37 T:18446744073580843380   DEBUG: DBus connection succeeded
        19:45:37 T:18446744073580844574   DEBUG: Keyboard: DBus connection succeeded
        19:45:37 T:18446744073580844794   DEBUG: OMXThread::Create - Thread with id 1857024480 started
        19:45:37 T:18446744073580844987   DEBUG: DllAvUtilBase: Using libavutil system library
        19:45:37 T:18446744073580845018   DEBUG: DllAvCodec: Using libavcodec system library
        19:45:37 T:18446744073580845043   DEBUG: DllAvFormat: Using libavformat system library
        19:45:37 T:18446744073580846429   DEBUG: COMXPlayer::OpenFile - avformat_open_input http://192.168.178.47:8001/1:0:1:6DCA:44D:1:C00000:0:0:0:
        When no log file is generated, then I am out of options.
        AxLed is also using a non 80 port (90), so that can’t be it.
          AxLed Module Developer
          @evroom said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
          I do see a white box on top of the Mirror, but I do not see the text.
          Can it be it is white text over a white background ?
          There is something wrong with the MM css of notifications on some MM versions, its not my module, i think there are already solutions in the forum.
          AxLED
          • Cr4z33C Offline
            Cr4z33 @evroom
            @AxLed
            			module: 'MMM-Dreambox',
            			position: 'bottom_left',
            			disabled: false,
            			header: 'Vu+ Duo²',
            				apiBase: 'http://vuplusip:port',
            				omxargs: ' --genlog --win 320,180,1600,900  -o both ',
            				refreshInterval: 1000 * 30, //refresh every 30 seconds
            				apiabout: '/web/about',
            				apiservices: '/web/getallservices',
            				apiepgnow: '/web/epgnow?bRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.favourites.tv%22%20ORDER%20BY%20bouquet',
            				apizap: '/web/zap?sRef=',
            				apiTimerlist: '/web/timerlist',
            				apiServicelistplayable: '/web/servicelistplayable?sRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.favourites.tv%22%20ORDER%20BY%20bouquet',
            				apibouquet: 0, //bouquet, if there is more than one under apiservices (/web/getallservices), important apiepgnow and apiServicelistplayable have to match to the selected bouquet
            				listmax: 10
            Exactly.
            I see the play triangle symbol on screen, but then there’s no streaming going on and yes I play DB-PLAY (not DB-START).
            Adding --genlog apparently does generate no log.
            I ran sudo find / -name omxplayer.log indeed, but it gave
            find: ‘/run/user/1000/gvfs’: Permission denied.
            I checked that directory in the file manager and it was empty…
            • evroomE Offline
              evroom
              Then it means that omxplayer, so your stream, is not being started.
              Perhaps @AxLed can log something in the pm2 log when omxplayer is supposed to be called (the the exact command line).
              • evroomE Offline
                evroom
                @Cr4z33
                Btw, tried your config and it works using my IP and port 80.
                Just to be sure, can you change your web IF HTTP port to 80 and try it again ?
                And you do restart your MM after every change, right ?
                I think you do, but just to rule it out.
                • Cr4z33C Offline
                  Cr4z33 @evroom
                  @evroom thanks for your suggestion, but honestly I don’t want to change to default port.
                  Even if it was working I don’t feel save because I use the Vu+ through DDNS service when I am out of home. ;)
                  • evroomE Offline
                    evroom
                    I just tested port 137.
                    Works just fine.
                    As expected, but you never know.
                    • Cr4z33C Offline
                      Cr4z33 @evroom
                      @evroom hmm I wonder what the hell can it be then? :smiling_face_with_open_mouth_cold_sweat:
                      MPEG2 License is OK, normal command line omxplayer streaming is OK, I am out of ideas too… :confounded_face:
                      Can you send me please by private chat the WHOLE module config you are using?
                      Let’s see if there’s any difference in it.
                        @Cr4z33
                        Is the IP of your VU receiver from internal Lan or external (DDNS)?
                        AxLED
                        • Cr4z33C Offline
                          Cr4z33 @AxLed
                          @AxLed it’s an internal LAN IP address.
                          • Cr4z33C Offline
                            Cr4z33
                            @AxLed I tried @evroom 's module config, but it keeps not streaming.
                            • evroomE Offline
                              evroom
                              @Cr4z33
                              Try this:
                              $ cd ~/MagicMirror/modules/MMM-Dreambox/
                              $ cp -p node_helper.js node_helper.js.orig
                              $ vi node_helper.js
                              Locate:
                              exec('omxplayer '
                              Append this line:
                              console.log('DB-PLAY(1): omxplayer '+self.config.omxargs+self.trimPort(self.config.apiBase)+':8001/'+payload[0]);
                              Locate next:
                              exec('omxplayer '
                              Append this line:
                              console.log('DB-PLAY(2): omxplayer '+self.config.omxargs+self.trimPort(self.config.apiBase)+':8001/'+payload[0]);
                              $ pm2 restart mm
                              $ pm2 logs
                              Select a service and play that service:
                              http://< MM_IP >:8080/remote?action=NOTIFICATION&notification=DB-SERVICE-NEXT
                              http://< MM_IP >:8080/remote?action=NOTIFICATION&notification=DB-PLAY
                              In pm2 logs should appear:
                              0|mm  | DB-PLAY(1): omxplayer  --genlog --vol -6000 --win 0,625,590,957 --live http://192.168.178.47:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
                              or:
                              0|mm  | DB-PLAY(2): omxplayer  --genlog --vol -6000 --win 0,625,590,957 --live http://192.168.178.47:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
                              In my case I see DB-PLAY(2).
                              If you see nothing then it is back to the drawing board.
                              Need to see what works and what not and where in the code.
                              Cr4z33C 3 Replies Last reply Reply Quote 0
                              • Cr4z33C Offline
                                Cr4z33 @evroom
                                @evroom thanks I will try later today.
                                • Cr4z33C Offline
                                  Cr4z33 @evroom
                                  @evroom there are two instances of
                                  exec('omxplayer '
                                  one at line 40 and one at line 45.
                                  What shall I do?
                                  • evroomE Offline
                                    evroom
                                    What shall I do?
                                    After both lines you need to put the console.log line, one with (1) and one with (2), see my post:
                                    Locate:
                                    exec('omxplayer '
                                    Append this line:
                                    Locate next:
                                    exec('omxplayer '
                                    Append this line:
                                    • Cr4z33C Offline
                                      Cr4z33 @evroom
                                      Nothing reported into PM2 logs. :persevering_face:
                                      • evroomE Offline
                                        evroom
                                        @Cr4z33
                                        That explains the missing stream.
                                        You are not getting to the DB-PLAY routine.
                                        To me it looks like you have an issue with MMM-Remote-Control.
                                        For example, I almost always get success, provide the IP is right, but the notification can be wrong
                                        {"status":"success"}
                                        Can you try this:
                                        $ cd /home/pi/MagicMirror/modules/MMM-Remote-Control
                                        $ git pull
                                        $ git status
                                        $ npm install
                                        And then restart mm and try again.
                                        You can also put a debug line in the DB-STOP call and do
                                        http://< MM_IP >:8080/remote?action=NOTIFICATION&notification=DB-STOP
                                        $ vi node_helper.js
                                                        if (notification === "DB-STOP") {
                                        console.log('DB-STOP: stop the stream');
        exec('pkill omxplayer', null);
                                        If you do not see this in the pm2 logs, then MMM-Remote-Control seems to be the culprit or the communication between the 2 modules.
                                        But as it works for both AxLed and me …
                                        • Cr4z33C Offline
                                          Cr4z33 @evroom
                                          @evroom oh wait what version of MMM-Remote-Control are you using? 🤔
                                          The original developer (cannot remember the name sorry) one or the new one made by shbatm?
                                          evroomE 1 Reply Last reply Reply Quote 0
                                            @evroom said in [MMM-Dreambox]:
                                            @Cr4z33 and @evroom
                                            You were pretty busy in debugging so far, somehow i had a similar idea as evroom.
                                            You can do an git pull in your MMM-Dreambox folder for the dev branch, i added some debugging informations.
                                            $ cd /home/pi/MagicMirror/modules/MMM-Dreambox
                                            $ git pull
                                            Maybe “zap” or the “zap” Url isnt working.
                                            @Cr4z33 can you please update and post the logs, the should look like
                                            Debug MMM-Dreambox: omxplayer  --win 320,180,1600,900  -o both http://dm800se.fritz.box:8001/1:0:19:2B5C:41B:1:FFFF014A:0:0:0:
                                            Debug MMM-Dreambox: zapstate:zap
                                            or
                                            Debug MMM-Dreambox: omxplayer  --win 320,180,1600,900  -o both http://dm800se.fritz.box:8001/1:0:1:CBB2:2710:F001:FFFF0000:0:0:0:
                                            You can also try to reduce the arguments like mine above to --win 320,180,1600,900 -o both.
                                            I use MMM-Remote-Control of Jopyth.
                                            AxLED
                                            • 6
                                            • 7
                                            • 8
                                            • 7 / 8
