    MMM-Image-On-Notification
    16 Posts 4 Posters 7.0k Views 5 Watching
    • ejay-ibmE Offline
      ejay-ibm Project Sponsor Module Developer
      Hello all,
      I’d like some help to develop a module to display particular local images depending on a notification received.
      I have developed a few gif images to display an AI face with different attitudes.
      1- Standby ( Mouth closed, head move, eyes looking here -and there…)
      https://drive.google.com/open?id=1zff5H4RN9azpUpuUj_9scDhCgeMgZI73
      2- Talk ( Mouth talking, with other face animations )
      3- (why not) Sing/dance ( head banging) ( Still working on that one as it needs more facial expression )
      well, that’s my idea but any images from a sequential given list could be sync with any notification received to the user choice.
      I walked around a few image modules but couldn’t find one that handles notifications.
      Is someone interested in developing it?
      Thank you
      Ejay
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @ejay-ibm
        @ejay-ibm I’m not sure which modules you checked out, but there are a lot of modules listening on notifications from other modules.
        Basically the elements you need are:
        • a module variable that stores the image name
        this.image = 'talking.gif'
        • a notification handler that changes the current image
        notificationReceived(notification, payload) {
          if (notification === 'SOME NOTIFICATION') {
            this.image = 'looking.gif';
        • a render function that displays the image
        getDom() {
          const wrapper = document.createElement('div');
          const image = document.createElement('img');
          image.src = 'somepath' + this.image;
          wrapper.appendChild(image);
          return wrapper;
        I think this should give you an idea how to solve it
        • ? Offline
          A Former User
          Making new module is somewhat not difficult and clear thing.
          But I think how it could be done with existing modules by combination
          1. MMM-HTMLBox (https://github.com/eouia/MMM-HTMLBox)
            It can insert static HTML on MM surface.
            So, it can show image also;
            module: "MMM-HTMLBox",
            position:"top_left",
              width: "200px",
              height: "200px",
              refresh_interval_sec: 0, // you should not refresh, because content will be back to default value.
              content: `< img id="MY_ANIMATION" src="default.gif" />`,
          1. MMM-notificationTrigger (https://github.com/eouia/MMM-NotificationTrigger)
            Well, this module is not designed for this purpose, However I found it could be possible.
            module: 'MMM-NotificationTrigger',
              triggers:[
                  trigger: "CHANGE_IMG_1",
                  fires: [
                      fire:"DUMMY",
                      payload: (payload) => {
                        var img = document.getElementById("MY_ANIMATION")
                        img.src = "img1.gif"
                        return payload
                  trigger: "CHANGE_IMG_2",
                  fires: [
                      fire:"DUMMY",
                        img.src = "img2.gif"
                        return payload
          When CHANGE_IMG_1 (or anything you want) notification is received, this will emit DUMMY notification, but this is not important.
          In payload callback function(it will be evaluated when the notification DUMMY be bursted), src of img will be changed.
          I didn’t test. :D just thinking.
          ejay-ibmE 1 Reply Last reply Reply Quote 1
          • ejay-ibmE Offline
            ejay-ibm Project Sponsor Module Developer @Guest
            @sean Thank ( Again Sean)
            I’m getting the following error :
            config.js:40 Uncaught TypeError: Cannot set property 'src' of null
                at Object.payload (config.js:40)
                at Class.notificationReceived (MMM-NotificationTrigger.js:62)
                at sendNotification (main.js:95)
                at Object.sendNotification (main.js:498)
                at Class.sendNotification (module.js:368)
                at Class.socketNotificationReceived (MMM-Hotword.js:85)
                at module.js:246
                at r.<anonymous> (socketclient.js:25)
                at r.emit (index.js:83)
                at r.onevent (index.js:83)
            config.js 40 is :
            38           payload: (payload) => {
            39            var img = document.getElementById("MY_ANIMATION")
            40              img.src = "/home/pi/MagicMirror/jarvis-standby2.gif"
            41              return payload
            Any Idea ? Let me know if you need me to report this directly in git issues.
            • ? Offline
              A Former User @ejay-ibm
              @ejay-ibm
              Where is your default.gif?(#MY_ANIMATION)?
              ejay-ibmE 1 Reply Last reply Reply Quote 0
              • ejay-ibmE Offline
                @sean
                Right I was missing the first module .
                Now this is what I’m getting
                I feel stupid to not be able to debug such simple thing, but I’m sure you will figure out the error faster than me …
                  sdetweil @ejay-ibm
                  @ejay-ibm its ok, this is a tricky one… the forum has a problem with content that starts with the '< ’ symbol,
                  so to make it show, we have to put a space after it… so… in your content:, take the space out after that < symbol
                  • ejay-ibmE Offline
                    Thank you @sdetweil That look better
                    Now I think it’s my last issue . The path …
                    I’m getting :
                    jarvis-standby2.gif:1 GET http://localhost:8080/jarvis-standby2.gif 404 (Not Found)
                    If the images is placed in /home/pi/MagicMirror/jarvis-standby2.gif
                    not sure what’s wrong and what is the “expectation” with the path …
                      sdetweil @ejay-ibm
                      @ejay-ibm the default path for the localhost server is /home/pi/MagicMirror,
                      if you do
                      ls /home/pi/MagicMirror/jarvis-standby2.gif -laF
                      do you get a proper display out?
                      linux/pi is case sensitive..
                      • ejay-ibmE Offline
                        ejay-ibm Project Sponsor Module Developer @sdetweil
                        @sdetweil said in MMM-Image-On-Notification:
                        yup
                        i@ejaypi:~/MagicMirror$ ls /home/pi/MagicMirror/jarvis-standby2.gif -laF
                        -rw-r–r-- 1 pi pi 8735111 mars 1 19:58 /home/pi/MagicMirror/jarvis-standby2.gif
                        • ejay-ibmE Offline
                          I found
                          src=“modules/MMM-HTMLBox/jarvis-standby2.gif”
                          that works …
                          thank you
                            sdetweil @ejay-ibm
                            @ejay-ibm actually looks like the base is
                            /home/pi/MagicMirror/modules
                            code in app/server.js
                            var directories = ["/config", "/css", "/fonts", "/modules", "/vendor", "/translations", "/tests/configs"];
                            sets up listening on those folders
                            • ejay-ibmE Offline
                              Thank you @Sean & @sdetweil
                              This is the draft result. I still have to work on the talking image. that one is a quick test.
                              https://drive.google.com/open?id=1G34tJ-1trMCK1yEJK0C6gIw3Nx3O8X8Q
                              As you can see the animation is triggered a bit early.
                              As I discussed with you Sean This is why I would need an additional notification between HOTWORD_PAUSE & ASSISTANT_ACTIVATE (I’ll use this notification as well to turn down the volume when user command is given in case any music is played on the mirror )
                              thank you again
                              Ejay
                              • ejay-ibmE Offline
                                @sdetweil I didn’t know that . Thanks I learnt something
                                I’ll use config folder then
                                Ejay
                                  sdetweil @ejay-ibm
                                  @ejay-ibm i would try to stay away from MM folders… create another under modules for your own content
                                  • ejay-ibmE Offline
                                    @sdetweil Yes config/images or modules/images
                                    Both would be ok since not overwritten in case of an update.
                                    Good Idea.
