    Total Newbie 24" MagicMirror (Munich, Germany)
    42 Posts 13 Posters 52.2k Views 13 Watching
    • thedoorsfanaticT
      thedoorsfanatic
      New update with PIR sensor and new modules: Wunderlist to-dos, SoccerLiveScore & fuel prices in a range of a certain distance to my home:
      https://youtu.be/5Cs3pCZamuM
      My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
      • D
        dxfan227
        Looks good, can I ask what kind of glassed you used. For me I want someting a little more Mirror like…your’s looks good but appeakrs not so reflective? A little more like clear acrylic.
        Which PIR module did you use? and With PIR hardware?
        thedoorsfanaticT 1 Reply Last reply Reply Quote 1
        • thedoorsfanaticT
          thedoorsfanatic @dxfan227
          @dxfan227
          Thanks a lot!
          I used Mirropane™ Chrome Spy glas, 4 mm thick, next time I might get 6 mm.
          PIR hardware: https://amzn.to/2YNSxYr
          Module: https://github.com/paviro/MMM-PIR-Sensor
          • thedoorsfanaticT
            thedoorsfanatic
            I integrated two new modules into my MagicMirror:
            • MMM-GoogleFit
            • MMM-GoogleMapsTraffic
            Watch a short video:
            https://youtu.be/Z1bWmxJHmAQ
            German:
            Meinem MagicMirror habe ich zwei neue Module hinzugefügt: Tägliche Schrittanzahl meiner Garmin Fitness Watch und Körpergewicht, synchronisiert über Google Fit. Dazu eine Google Map meiner Umgebung inklusive aktueller Stauanzeige.
            • thedoorsfanaticT
              thedoorsfanatic
              https://youtu.be/VEH_AFpjQgM
              Experimenting with Background Slideshow module on my test monitor before inserting new functions into my Smart Mirror …
              Auf meinem Test-Monitor experimentiere ich mit dem Background Slideshow Modul herum, bevor ich meinem Smart Mirror neue Funktionen hinzufüge …
              • thedoorsfanaticT
                thedoorsfanatic
                https://youtu.be/frFSshaYkjw
                My Smart Mirror will now show the birthdays from my Google Contacts. In addition, the IP of two smartphones is polled every 30 seconds to check when a person was connected to the home network.
                German translation:
                Auf meinem Smart Mirror werden nun auch die Geburtstage aus meinen Google Kontakten angezeigt. Zusätzlich wird alle 30 Sekunden die IP zweier Smartphones abgefragt, um zu checken, wann eine Person mit dem heimischen Netzwerk verbunden war.
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @thedoorsfanatic
                  @thedoorsfanatic Looks nice and clean. Good job on the build.
                  Greetings from Munich
                  • H
                    hayman @thedoorsfanatic
                    @thedoorsfanatic said in Total Newbie 24" MagicMirror (Munich, Germany):
                    .currentweather .wi-day-sunny {
                    content: url(“/css/icons/day.svg”);
                    nicely done will you please send your custom.css files ,thanks
                    thedoorsfanaticT 1 Reply Last reply Reply Quote 0
                    • thedoorsfanaticT
                      thedoorsfanatic @hayman
                      @hayman
                      What exactly do you wanna know?
                      • H
                        @thedoorsfanatic which size do you use and the folders,thanks
                        • thedoorsfanaticT
                          thedoorsfanatic
                          Back in the Lab to test new functions for my Magic Mirror. Today I started working on a German word clock…
                          https://youtu.be/qa2UFx_EEK0
                          FoziF 1 Reply Last reply Reply Quote 1
                          • FoziF
                            Fozi Project Sponsor @thedoorsfanatic
                            @thedoorsfanatic that look great!
                            BTW, I live close to Munich, too😁
                            • thedoorsfanaticT
                              thedoorsfanatic @Fozi
                              @Fozi
                              Thanks, I appreciate it but your MM looks much nicer, I am jealous
                              FoziF 1 Reply Last reply Reply Quote 0
                              • FoziF
                                @thedoorsfanatic Come on, don’t be so humble!
                                • thedoorsfanaticT
                                  thedoorsfanatic
                                  Improving the layout and testing the new German Word Clock function …
                                  https://youtu.be/pRcDmjuu4vU
                                  • kusselinK
                                    kusselin
                                    H, du hast ne PM
                                    Die Bundeligatabelle…hast du das mit diesem Modul hier
                                    MMM-soccer
                                    realisiert?
                                    Gruss
                                    thedoorsfanaticT LordyL 2 Replies Last reply Reply Quote 1
                                    • thedoorsfanaticT
                                      thedoorsfanatic @kusselin
                                      @kusselin
                                      Hi Markus,
                                      die Fussballergebnisse hab ich mit diesem Modul realisiert:
                                      https://github.com/LukeSkywalker92/MMM-SoccerLiveScore
                                      • kusselinK
                                        kusselin
                                        Hi, dachte ich mir schon…hast du meine PN bekommen. Wäre das machbar?
                                        Gruss
                                        • LordyL
                                          Lordy @kusselin
                                          @kusselin Ich will mich nicht einmischen, aber schau Dir das Modul mal an. Davon bin ich überzeugt. https://github.com/master117/MagicMirror-FootballLeagues.git
                                          • FoziF
                                            Fozi Project Sponsor @kusselin
                                            @kusselin Ich werfe mal MMM-MyScoreboard in den Ring.
                                            • 2 / 3
