    MMM-CalendarExt3Agenda
    224 Posts 30 Posters 434.5k Views 32 Watching
    • BKeyportB
      So, here’s my final config in CSS -
      * CalendarExtende3 Agenda */
      .CX3A .event .description {
        display: none;
      .CX3A .event .headline .symbol.noSymbol::after {
        content: '';
      .CX3A .cellBody .fullday {
        display: flex;
        justify-content: flex-start;
        flex-wrap: wrap;
      .CX3A .cellBody .fullday .event {
        color: var(--calendarColor);
        background-color: gray;
        max-width: 100%;
        padding: 0px 0px;
      .CX3A .cellBody .fullday .event .title {
        color: inherit;
        overflow: unset;
        white-space: unset;
        text-overflow: unset;
      .CX3A .cellBody .fullday .event .headline :not(.title) {
        display: inline-block;
      .CX3A .cellBody .fullday .event .headline .time {
        display: none;
      .CX3A .event .time {
        width: 55px; /* adjust for your entire CSS harmony */
        text-align: right;
      .CX3A .event .location {
        display: none;
      .CX3A::after {
        height: 0;
      Results in:
      • luisestradaL
        luisestrada @BKeyport
        @BKeyport said in MMM-CalendarExt3Agenda:
        @MMRIZE at least you have good taste and follow the bluejays. :P
        I cannot agree more with that :)
          MMRIZE
          Updated
          1.1.0 (2022-08-17)
          • ADDED : miniMonth calendar
          • FIXED : some minor bugs fixes and code refactoring
          BKeyportB 1 Reply Last reply
          • BKeyportB
            BKeyport Module Developer @MMRIZE
            @MMRIZE ya know, I hate that you’re so efficient in getting stuff like this to work natively, without external code. geezer.gif
            M 1 Reply Last reply
              MMRIZE @BKeyport
              @BKeyport
              :D
              I just want to get a similar look with Fantastical App on MagicMirror because I majorly am using that app in my real world. ;)month.5.png
              • BKeyportB
                OK, Seriously - do you want to do two things:
                1. Setup your minical to show by itself, without an agenda.
                2. Allow it to expand to multiple months like my MMM-Minimonth
                If so, I’m seriously considering dropping the module, as I’m getting very frustrated in porting away from moment.js - and frankly, I’m to the point of dropping out - I’d rather concentrate on other things.
                  MMRIZE @BKeyport
                  @BKeyport
                  Not at all.
                  That mini cal belongs to agenda. I don’t have interesting standalone. And 3 months view? I never use that kind in real world. Basically, i will not build what I won’t use. So don’t worry.
                  • BKeyportB
                    @MMRIZE z’arright.
                    • BKeyportB
                      @MMRIZE hey, Having trouble with a transform, I’ve noticed.
                      In redoing my CSS (reason for finding bug posted on github), I noticed my transformer isn’t quite working like I want.
                      this works:
                      eventTransformer: (ev) => {
                      	if (ev.title.search("⚾") > -1)
                      	ev.title = ev.title.replace("⚾","");
                      	return ev
                      However, I would also like to take out the space after the baseball, so that these events line up with the rest of the events that don’t try and get fancy and put emoji into the title.
                      two attempts I’ve made: ev.title.replace("⚾ ",""); and ev.title.replace("⚾ ",""); totally disable to the transform. Suggestions?
                        sdetweil @BKeyport
                        if (ev.title.search(“⚾”) > -1)
                        ev.title = ev.title.replace(“⚾”,“”);
                        return ev
                        so, lets make a little node script to test outside the transform
                        xxx.js
                        let title= " put in your chars"
                        console.log(title.replace(“… etc”,“”)
                        save and then run
                        node xxx.js
                        then u can play with it
                        til you get what you expect
                        • BKeyportB
                          @sdetweil Found it, ended up being a special char, likely a tab or something stupid. cut and paste saves the day.
                          • BKeyportB
                            Three things I wanna change that I can’t figure out.
                            1. I would like the all day events that don’t wrap (“Yard Waste”) to stretch across the window (grey bar).
                            2. I would like times to not wrap.
                            3. I would like times to right align, so that the events are in a nice straight line.
                            custom CSS and screenshot attached. I’m in top_center.
                            Thanks!
                            /* offset top center to fit for large right and small left */
                            .region.top.center {
                              left: 62%;
                              transform: translateX(-50%);
                              text-align:center;
                            /* CalendarExt3Agenda */
                            /* Set CX3a to size, etc. */
                            .CX3A {
                              font-size: 20px;
                              min-width: 300px;
                              max-width: 430px;
                              max-height: 900px;
                              overflow-y: unset;
                              text-align: left;
                              position: relative;
                              color: white;
                            /* Hide useless descriptions, you wanna know, load your calendar */
                              display: none;
                            /* Hide useless locations, you wanna know, load your calendar */
                              display: none;
                            /* Set up custom full day look */
                              max-width: 100%;
                              padding: 0px 0px;
                            /* make fullday events overflow onto next line */
                              color: inherit;
                              overflow: unset;
                              white-space: unset;
                            /* Add the icon to full day events
                            .CX3A .cellBody .fullday .event .headline {
                            /* get rid of the icon for blanks  */
                              content: '';
                            /* fullday keep the times hidden */
                              display: none;
                            /* Change the dash to a colon, get rid of spare space */
                            .CX3A .event .startTime::after {
                              content: ':';
                            /* Adjust time space */
                              font-size: unset;
                            /* Remove End time */
                            .CX3A .event .endTime {
                              display: none;
                            /* Adjust how tall app is */
                            .CX3A .agenda {
                              position: relative;
                              max-height: 900px;
                              overflow-y: hidden;
                            /* Fade eliminator */
                            .CX3A .agenda::after {
                              position: absolute;
                              bottom: 0;
                              left: 0;
                              height: 20%;
                              width: 100%;
                              content: ' ';
                              background-image: unset;
                              MMRIZE @BKeyport
                              Append below into your custom.css
                              .CX3A {
                                width: 300px; /* to test text-wrapping */
                                width: 100%;
                                content: '';
                              .CX3A .event .title {
                                order: 1;
                                width: 180px; /* Adjust for your region width. Here I am using fixed value to make things simple */
                                flex-grow: 1;
                              .CX3A .event .symbol {
                                order: 1;
                              .CX3A .event .time.startTime {
                                order: 2;
                                width: 90px;  /* Adjust for your region width. Here I am using fixed value to make things simple */
                                text-align: right;
                              .CX3A .event .headline {
                                justify-content: space-between;
                              • BKeyportB
                                @MMRIZE nearly perfect. Thanks! (I’m tweaking minor things from this)
                                • H
                                  hogedir
                                  Hi to all !
                                  I just installed the module MMM-CalendarExt3Agenda which looks like very good but i’m lost in the config file ! i have an error.
                                  Here is my setup :
                                  I’ve done 2 tests of config.js:
                                  TEST1 :
                                  config.js with
                                  module: “MMM-CalendarExt3Agenda”,
                                  position: “top_left”,
                                  Result : TEST OK, the module is shown.
                                  TEST2 :
                                  When I add t config.js
                                  title: “My Agenda”,
                                  instanceId: “basicCalendar”,
                                  locale: ‘de-DE’,
                                  firstDayOfWeek: 1,
                                  startDayIndex: -1,
                                  endDayIndex: 10,
                                  calendarSet: [‘us_holiday’,],
                                  /* default/calendar module configuration */
                                  module: “calendar”,
                                  broadcastPastEvents: true, // <= IMPORTANT to see past events
                                  url: “webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics”,
                                  name: “us_holiday”, // <-- specify calendar name
                                  color: “skyblue”, // <-- if you don’t want to get color, just remove this line.
                                  broadcastPastEvents: true, // <-- need to broadcast past events
                                  maximalNumberOfDays: 30, // <-- how old events would be broadcasted
                                  maximumEntries: 100, // <-- assign enough number to prevent truncating new events by old events.
                                  symbol: ‘camera’, // <-- when you want to display simbol. If you don’t want, just set as symbol:[],
                                  RESULT : error (black screen) and when i do a tail -50 /home/pi/.pm2/logs/MagicMirror-error.log I don’t see nothing special
                                  Can someone help please?
                                  M H 2 Replies Last reply
                                    MMRIZE @hogedir
                                    @hogedir
                                    I cleaned your config to test.
                                    • Your quotation mark and double quotation mark seem not standard ASCII code. (It sometimes happens when you copy the codes from Text Editor, which is not for coding.)
                                    • The last bracket ] for calendars and } of module config seem missing but I think it was just a mistake when you posted the code here.
                                    Anyway, after cleaning, it works for me.
                                      module: "MMM-CalendarExt3Agenda",
                                      position: 'top_left',
                                      title: 'My Agenda',
                                        instanceId: 'basicCalendar',
                                        locale: 'de-DE',
                                        firstDayOfWeek: 1,
                                        startDayIndex: -1,
                                        endDayIndex: 10,
                                        calendarSet: ['us_holiday'],
                                      module: 'calendar',
                                          url: 'webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics',
                                          color: 'skyblue',
                                          symbol: 'camera',
                                      sdetweil @MMRIZE
                                      @MMRIZE the quotation marks will get mangled if not wrapped in a code block. the forum code treats it as document text
                                      if u edit it, it’s correct but copy paste from here produces wird type quotes…
                                      • H
                                        hogedir @hogedir
                                        @MMRIZE thank you very much !
                                        Now i have an issue. I try to connect a FRAMAGENDA calendar to your super module.
                                        Framagenda is a nextcloud like agenda. So, it needs an authentification (it’s not a direct .ics).
                                        Here is the config.js with the calendar and MMM-calendarextAgenda module config :
                                        			url: "https://framagenda.org/remote.php/dav/calendars/calendar_1/test",
                                        			auth: {
                                        			    user: 'myuser28632HG4',
                                        			    pass: 'HDDBG5nSvdjgBVFBVDFFV',
                                        			    method: 'basic',
                                        			name: "test", // <-- specify calendar name
                                        			color: "skyblue", // <-- if you don't want to get color, just remove this line.
                                                symbol:[],
                                          title: "My Agenda",
                                            instanceId: "basicCalendar",
                                            locale: 'FR',
                                            firstDayOfWeek: 1,
                                            startDayIndex: -1,
                                        		endDayIndex: 10,
                                            calendarSet: [''],
                                        Result : the module works now but there is not Appointment showed, nothing is get from my framagenda calendar.
                                        Where can i see why it doesn’t dump my calendar ? a log file ?
                                          sdetweil @hogedir
                                          @hogedir please put your config info in a code block
                                          paste
                                          select the text you just pasted
                                          and pish the button on the top , looks like this
                                          • H
                                            hogedir
                                            I have the connection now after multiple tests to understand the issue.
                                            but i think I found a bug in your module @MMRIZE.
                                            If I connect to a very simple calendar with 5 appoinments => result : it shows the calendar in the MM without any problem.
                                            If i connect to the same calendar but imported with much more information in it (i dumped my other calendar to it which doesn’t work with your module) => it shows NO APPOINTMENT AVAILABLE.
                                            It’s possible the french accent we use in france could be the source of the problem, Or too much info in the ics broke the connection?
                                            The special caracter like , : ! are ok ? or long sentence ? in the title of the appointment ?
                                            other question : what are the others symbols than camera ?
                                            How it works to affect the correct symbol to the right appointment? I don’t understand this feature.
                                            ==>>Where can i see the log file about your module especially please?
                                            thanks a lot
                                            W 1 Reply Last reply
                                            • 11
                                            • 12
                                            • 2 / 12
