    MMM-CalendarExt3Agenda
    224 Posts 30 Posters 434.5k Views 32 Watching
    • BKeyportB
      BKeyport Module Developer @MMRIZE
      @MMRIZE Enjoy your vacation! Shouldn’t even be checking in… :)
        MMRIZE @BKeyport
        @BKeyport
        Frankly says, I don’t like this kind of style, but your wish. :D
        .CX3A .cellBody .fullday .event {
          color: var(--calendarColor);
          background-color: unset;
          max-width: 100%;
        .CX3A .cellBody .fullday .event .title {
          color: inherit;
          overflow: unset;
          white-space: unset;
          text-overflow: unset;
        .CX3A::after {
          height: 0;
        .CX3A .cellBody .fullday .event .headline :not(.title) {
          display: inline-block;
        .CX3A .cellBody .fullday .event .headline .time {
          display: none;
        .CX3A .event .time {
          width: 35px; /* adjust for your entire CSS harmony */
          text-align: right;
        BKeyportB 1 Reply Last reply
        • BKeyportB
          @MMRIZE at least you have good taste and follow the bluejays. :P
          M luisestradaL 2 Replies Last reply
            MMRIZE @BKeyport
            @BKeyport
            title wrapping example
            BKeyportB H 2 Replies Last reply
            • BKeyportB
              @MMRIZE Works great, Thanks!
              • BKeyportB
                So, here’s my final config in CSS -
                * CalendarExtende3 Agenda */
                .CX3A .event .description {
                  display: none;
                .CX3A .event .headline .symbol.noSymbol::after {
                  content: '';
                .CX3A .cellBody .fullday {
                  display: flex;
                  justify-content: flex-start;
                  flex-wrap: wrap;
                  background-color: gray;
                  max-width: 100%;
                  padding: 0px 0px;
                  color: inherit;
                  overflow: unset;
                  white-space: unset;
                  display: none;
                  width: 55px; /* adjust for your entire CSS harmony */
                  text-align: right;
                .CX3A .event .location {
                  display: none;
                .CX3A::after {
                  height: 0;
                Results in:
                • luisestradaL
                  luisestrada @BKeyport
                  @BKeyport said in MMM-CalendarExt3Agenda:
                  I cannot agree more with that :)
                    MMRIZE
                    Updated
                    1.1.0 (2022-08-17)
                    • ADDED : miniMonth calendar
                    • FIXED : some minor bugs fixes and code refactoring
                    • BKeyportB
                      @MMRIZE ya know, I hate that you’re so efficient in getting stuff like this to work natively, without external code. geezer.gif
                      M 1 Reply Last reply
                        MMRIZE @BKeyport
                        @BKeyport
                        :D
                        I just want to get a similar look with Fantastical App on MagicMirror because I majorly am using that app in my real world. ;)month.5.png
                        • BKeyportB
                          OK, Seriously - do you want to do two things:
                          1. Setup your minical to show by itself, without an agenda.
                          2. Allow it to expand to multiple months like my MMM-Minimonth
                          If so, I’m seriously considering dropping the module, as I’m getting very frustrated in porting away from moment.js - and frankly, I’m to the point of dropping out - I’d rather concentrate on other things.
                            MMRIZE @BKeyport
                            @BKeyport
                            Not at all.
                            That mini cal belongs to agenda. I don’t have interesting standalone. And 3 months view? I never use that kind in real world. Basically, i will not build what I won’t use. So don’t worry.
                            • BKeyportB
                              @MMRIZE z’arright.
                              • BKeyportB
                                @MMRIZE hey, Having trouble with a transform, I’ve noticed.
                                In redoing my CSS (reason for finding bug posted on github), I noticed my transformer isn’t quite working like I want.
                                this works:
                                eventTransformer: (ev) => {
                                	if (ev.title.search("⚾") > -1)
                                	ev.title = ev.title.replace("⚾","");
                                	return ev
                                However, I would also like to take out the space after the baseball, so that these events line up with the rest of the events that don’t try and get fancy and put emoji into the title.
                                two attempts I’ve made: ev.title.replace("⚾ ",""); and ev.title.replace("⚾ ",""); totally disable to the transform. Suggestions?
                                  sdetweil @BKeyport
                                  if (ev.title.search(“⚾”) > -1)
                                  ev.title = ev.title.replace(“⚾”,“”);
                                  return ev
                                  so, lets make a little node script to test outside the transform
                                  xxx.js
                                  let title= " put in your chars"
                                  console.log(title.replace(“… etc”,“”)
                                  save and then run
                                  node xxx.js
                                  then u can play with it
                                  til you get what you expect
                                  • BKeyportB
                                    @sdetweil Found it, ended up being a special char, likely a tab or something stupid. cut and paste saves the day.
                                    • BKeyportB
                                      Three things I wanna change that I can’t figure out.
                                      1. I would like the all day events that don’t wrap (“Yard Waste”) to stretch across the window (grey bar).
                                      2. I would like times to not wrap.
                                      3. I would like times to right align, so that the events are in a nice straight line.
                                      custom CSS and screenshot attached. I’m in top_center.
                                      Thanks!
                                      /* offset top center to fit for large right and small left */
                                      .region.top.center {
                                        left: 62%;
                                        transform: translateX(-50%);
                                        text-align:center;
                                      /* CalendarExt3Agenda */
                                      /* Set CX3a to size, etc. */
                                      .CX3A {
                                        font-size: 20px;
                                        min-width: 300px;
                                        max-width: 430px;
                                        max-height: 900px;
                                        overflow-y: unset;
                                        text-align: left;
                                        position: relative;
                                        color: white;
                                      /* Hide useless descriptions, you wanna know, load your calendar */
                                        display: none;
                                      /* Hide useless locations, you wanna know, load your calendar */
                                        display: none;
                                      /* Set up custom full day look */
                                        max-width: 100%;
                                        padding: 0px 0px;
                                      /* make fullday events overflow onto next line */
                                        color: inherit;
                                        overflow: unset;
                                        white-space: unset;
                                      /* Add the icon to full day events
                                      .CX3A .cellBody .fullday .event .headline {
                                      /* get rid of the icon for blanks  */
                                        content: '';
                                      /* fullday keep the times hidden */
                                        display: none;
                                      /* Change the dash to a colon, get rid of spare space */
                                      .CX3A .event .startTime::after {
                                        content: ':';
                                      /* Adjust time space */
                                        font-size: unset;
                                      /* Remove End time */
                                      .CX3A .event .endTime {
                                        display: none;
                                      /* Adjust how tall app is */
                                      .CX3A .agenda {
                                        position: relative;
                                        max-height: 900px;
                                        overflow-y: hidden;
                                      /* Fade eliminator */
                                      .CX3A .agenda::after {
                                        position: absolute;
                                        bottom: 0;
                                        left: 0;
                                        height: 20%;
                                        width: 100%;
                                        content: ' ';
                                        background-image: unset;
                                        MMRIZE @BKeyport
                                        Append below into your custom.css
                                        .CX3A {
                                          width: 300px; /* to test text-wrapping */
                                          width: 100%;
                                          content: '';
                                        .CX3A .event .title {
                                          order: 1;
                                          width: 180px; /* Adjust for your region width. Here I am using fixed value to make things simple */
                                          flex-grow: 1;
                                        .CX3A .event .symbol {
                                          order: 1;
                                        .CX3A .event .time.startTime {
                                          order: 2;
                                          width: 90px;  /* Adjust for your region width. Here I am using fixed value to make things simple */
                                          text-align: right;
                                        .CX3A .event .headline {
                                          justify-content: space-between;
                                        • BKeyportB
                                          @MMRIZE nearly perfect. Thanks! (I’m tweaking minor things from this)
                                          • H
                                            hogedir
                                            Hi to all !
                                            I just installed the module MMM-CalendarExt3Agenda which looks like very good but i’m lost in the config file ! i have an error.
                                            Here is my setup :
                                            I’ve done 2 tests of config.js:
                                            TEST1 :
                                            config.js with
                                            module: “MMM-CalendarExt3Agenda”,
                                            position: “top_left”,
                                            Result : TEST OK, the module is shown.
                                            TEST2 :
                                            When I add t config.js
                                            title: “My Agenda”,
                                            instanceId: “basicCalendar”,
                                            locale: ‘de-DE’,
                                            firstDayOfWeek: 1,
                                            startDayIndex: -1,
                                            endDayIndex: 10,
                                            calendarSet: [‘us_holiday’,],
                                            /* default/calendar module configuration */
                                            module: “calendar”,
                                            broadcastPastEvents: true, // <= IMPORTANT to see past events
                                            url: “webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics”,
                                            name: “us_holiday”, // <-- specify calendar name
                                            color: “skyblue”, // <-- if you don’t want to get color, just remove this line.
                                            broadcastPastEvents: true, // <-- need to broadcast past events
                                            maximalNumberOfDays: 30, // <-- how old events would be broadcasted
                                            maximumEntries: 100, // <-- assign enough number to prevent truncating new events by old events.
                                            symbol: ‘camera’, // <-- when you want to display simbol. If you don’t want, just set as symbol:[],
                                            RESULT : error (black screen) and when i do a tail -50 /home/pi/.pm2/logs/MagicMirror-error.log I don’t see nothing special
                                            Can someone help please?
                                            M H 2 Replies Last reply
                                            • 11
                                            • 12
                                            • 1 / 12
