    Mobile app (bachelor thesis)
    116 Posts 31 Posters 203.2k Views 31 Watching
      Beh
      Nice! Thanks!
      Gonna try it tonight.
      Where should I report issues? Do you have a GitHub repo for the app?
      strawberry 3.141S 1 Reply Last reply Reply Quote 1
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @Beh
        @Beh issues should be reported here https://github.com/fewieden/MMM-Mobile
        • I
          in_a_days
          Just completed my survey - hope it’s not too late to get involved!
          • L
            lolobyte @strawberry 3.141
            @strawberry-3.141
            Hi, thank you for this.
            Very IMPORTANT!!!
            As i put the Module “MMM-Mobile” at the very last module on the end of the config.js, all my module were started in a new order so that the modules was on different locations.
            My config.js was modified like this sample:
             /* Magic Mirror Config Sample * * By Michael Teeuw http://michaelteeuw.nl * MIT Licensed. */ var config = {        port: 8080, //      address: "192.168.178.45",  ipWhitelist: [ "127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.1/24", ], language: 'de', timeFormat: 24, units: 'metric', modules: [ { module: 'alert', classes: 'small bright', // Add your own styling. Optional. disabled: false, }, { .......
            and so on. That means, the hole config structure was damaged and in one line.
            Has anyone else this issue?
            After restoring the old config.js from the backup that your module was creating, the right module order was again ok.
            After that i put the “MMM-Mobile” module at first module in my config and my mirror works like before.
            I 2 Replies Last reply Reply Quote 1
            • I
              in_a_days @lolobyte
              @lolobyte
              Same issue! Attempting your solution now. Thank you!
              • I
                in_a_days @lolobyte
                @lolobyte
                Looks to me like the config.js rebuild is happening when the user runs npm install, regardless of where I place the MMM-Mobile module.
                L cowboysdudeC 2 Replies Last reply Reply Quote 0
                • L
                  lolobyte @in_a_days
                  @in_a_days
                  ohh, reallly.
                  But is it necessary to run npm install again?
                  • L
                    lolobyte
                    Has anyone reached a mail from apple?
                    • I
                      in_a_days @lolobyte
                      @lolobyte said in Mobile app (bachelor thesis):
                      @in_a_days
                      ohh, reallly.
                      That is exactly what I am struggling with. I’ve only managed to generate a QR code on screen twice, both times after running the npm install. So basically right now I can only get a QR code after scrambling my config.js file. But it’s totally possible I’m doing something wrong too.
                      • strawberry 3.141S
                        strawberry 3.141 Project Sponsor Module Developer @in_a_days
                        @in_a_days @lolobyte
                        There is a preinstall script (which gets executed right before npm install) which reorders the modules by region, but the display module order keeps the same, to enable easy reordering in the app.
                        Formatting of the config will reoccur in the next version.
                        The only possible way to reshow the qr-code is by deleting the mobile.json file (this will make all pairings obsolete) or you scan the qr image in the module directory.
                        About 10 iOS users have installed the app, so if you didn’t receive a mail by apple you can send me your mail again via pm and i will add you to the beta testing.
                        Please use github issues as it is the better tracker and overview for others with the same issues as you have done already
                        • L
                          @strawberry-3.141
                          Sorry, pm is what?
                          The App run only with ios10?
                          • strawberry 3.141S
                            strawberry 3.141 Project Sponsor Module Developer @lolobyte
                            @lolobyte personal message
                            it requires at least iOS 8 just wanted to say that 10 people have received the mail by apple
                            • morozgrafixM
                              morozgrafix Moderator
                              Filled out survey this morning. Good luck with your thesis, hope my answers help you. (one thing is that my answer about frequency of config.js modifications may screw up your results, due to me playing around with hacking and developing modules) Would love to get on beta of the iOS app.
                              • L
                                lolobyte
                                @strawberry-3-141
                                hi, Your app is successfully loaded from apple.
                                Little issue.
                                Can you tell me whats wrong here?
                                pi@raspi3-MM2:~/MagicMirror/modules/MMM-Mobile $ sudo npm install
                                npm WARN lifecycle mmm-mobile@1.0.0~preinstall: cannot run in wd %s %s (wd=%s) mmm-mobile@1.0.0 node scripts/preinstall.js /home/pi/MagicMirror/modules/MMM-Mobile
                                mmm-mobile@1.0.0 /home/pi/MagicMirror/modules/MMM-Mobile
                                ├─┬ async@2.1.4
                                │ └── lodash@4.17.4
                                ├── moment@2.17.1
                                ├── qr-image@3.2.0
                                └── simple-git@1.65.0
                                after a git pull
                                pi@raspi3-MM2:~/MagicMirror/modules/MMM-Mobile $ sudo git pull
                                Aktualisiere 2e56f84..41dd1aa
                                Fast-forward
                                 MMM-Mobile.js        | 5 +++--
                                 translations/es.json | 3 +++
                                 2 files changed, 6 insertions(+), 2 deletions(-)
                                 create mode 100644 translations/es.json
                                it remain. Same failure!
                                • strawberry 3.141S
                                  @lolobyte the problem was that his config.js file was locked to root access
                                  • L
                                    @strawberry-3.141
                                    That’s happened since i restored the reformatted config.js. ;-)
                                    • cowboysdudeC
                                      cowboysdude Module Developer @strawberry 3.141
                                      @strawberry-3.141 said in Mobile app (bachelor thesis):
                                      Everyone should have received an email with the App (Android, Windows Phone).
                                      iOS users should receive a second mail from Apple themselves with an invite for beta testing.
                                      Never got an email from Apple… so I’m kinda stuck. I installed the mirror app but that’s as far as I can go…
                                      • cowboysdudeC
                                        cowboysdude Module Developer @in_a_days
                                        @in_a_days Mine just put a .032 in my config.js and that was it LOL
                                        • cowboysdudeC
                                          cowboysdude Module Developer @cowboysdude
                                          @cowboysdude said in Mobile app (bachelor thesis):
                                          I did get the email…check the ‘junk’ folder… ;)
                                          And Thanks to Strawberry it’s up and running!!
                                          VERY nice work!! Deserves an A+ for sure!!!
                                          • L
                                            lolobyte
                                            @strawberry-3-141;
                                            your new MagicMirror² 1.0.2 (4) for iOS is out and ready for testing. :-) :airplane:
                                            • 2 / 6
