    Mobile app (bachelor thesis)
    116 Posts 31 Posters 205.2k Views 31 Watching
    • in_a_daysI
      in_a_days @lolobyte
      @lolobyte
      Looks to me like the config.js rebuild is happening when the user runs npm install, regardless of where I place the MMM-Mobile module.
      lolobyteL cowboysdudeC 2 Replies Last reply
      • lolobyteL
        lolobyte @in_a_days
        @in_a_days
        ohh, reallly.
        But is it necessary to run npm install again?
        in_a_daysI 1 Reply Last reply
        • lolobyteL
          lolobyte
          Has anyone reached a mail from apple?
          • in_a_daysI
            in_a_days @lolobyte
            @lolobyte said in Mobile app (bachelor thesis):
            @in_a_days
            ohh, reallly.
            That is exactly what I am struggling with. I’ve only managed to generate a QR code on screen twice, both times after running the npm install. So basically right now I can only get a QR code after scrambling my config.js file. But it’s totally possible I’m doing something wrong too.
            • strawberry 3.141S
              strawberry 3.141 Project Sponsor Module Developer @in_a_days
              @in_a_days @lolobyte
              There is a preinstall script (which gets executed right before npm install) which reorders the modules by region, but the display module order keeps the same, to enable easy reordering in the app.
              Formatting of the config will reoccur in the next version.
              The only possible way to reshow the qr-code is by deleting the mobile.json file (this will make all pairings obsolete) or you scan the qr image in the module directory.
              About 10 iOS users have installed the app, so if you didn’t receive a mail by apple you can send me your mail again via pm and i will add you to the beta testing.
              Please use github issues as it is the better tracker and overview for others with the same issues as you have done already
              lolobyteL 1 Reply Last reply
              • lolobyteL
                lolobyte @strawberry 3.141
                @strawberry-3.141
                Sorry, pm is what?
                The App run only with ios10?
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @lolobyte
                  @lolobyte personal message
                  it requires at least iOS 8 just wanted to say that 10 people have received the mail by apple
                  • morozgrafixM
                    morozgrafix Moderator
                    Filled out survey this morning. Good luck with your thesis, hope my answers help you. (one thing is that my answer about frequency of config.js modifications may screw up your results, due to me playing around with hacking and developing modules) Would love to get on beta of the iOS app.
                    • lolobyteL
                      lolobyte
                      @strawberry-3-141
                      hi, Your app is successfully loaded from apple.
                      Little issue.
                      Can you tell me whats wrong here?
                      pi@raspi3-MM2:~/MagicMirror/modules/MMM-Mobile $ sudo npm install
                      npm WARN lifecycle mmm-mobile@1.0.0~preinstall: cannot run in wd %s %s (wd=%s) mmm-mobile@1.0.0 node scripts/preinstall.js /home/pi/MagicMirror/modules/MMM-Mobile
                      mmm-mobile@1.0.0 /home/pi/MagicMirror/modules/MMM-Mobile
                      ├─┬ async@2.1.4
                      │ └── lodash@4.17.4
                      ├── moment@2.17.1
                      ├── qr-image@3.2.0
                      └── simple-git@1.65.0
                      after a git pull
                      pi@raspi3-MM2:~/MagicMirror/modules/MMM-Mobile $ sudo git pull
                      Aktualisiere 2e56f84..41dd1aa
                      Fast-forward
                       MMM-Mobile.js        | 5 +++--
                       translations/es.json | 3 +++
                       2 files changed, 6 insertions(+), 2 deletions(-)
                       create mode 100644 translations/es.json
                      it remain. Same failure!
                      • strawberry 3.141S
                        @lolobyte the problem was that his config.js file was locked to root access
                        • lolobyteL
                          @strawberry-3.141
                          That’s happened since i restored the reformatted config.js. ;-)
                          • cowboysdudeC
                            cowboysdude Module Developer @strawberry 3.141
                            @strawberry-3.141 said in Mobile app (bachelor thesis):
                            Everyone should have received an email with the App (Android, Windows Phone).
                            iOS users should receive a second mail from Apple themselves with an invite for beta testing.
                            Never got an email from Apple… so I’m kinda stuck. I installed the mirror app but that’s as far as I can go…
                            • cowboysdudeC
                              cowboysdude Module Developer @in_a_days
                              @in_a_days Mine just put a .032 in my config.js and that was it LOL
                              • cowboysdudeC
                                cowboysdude Module Developer @cowboysdude
                                @cowboysdude said in Mobile app (bachelor thesis):
                                I did get the email…check the ‘junk’ folder… ;)
                                And Thanks to Strawberry it’s up and running!!
                                VERY nice work!! Deserves an A+ for sure!!!
                                • lolobyteL
                                  lolobyte
                                  @strawberry-3-141;
                                  your new MagicMirror² 1.0.2 (4) for iOS is out and ready for testing. :-) :airplane:
                                  • strawberry 3.141S
                                    I just send out the mails,
                                    Everyone should have got an email with instructions.
                                    iOS users should have received their mail from Apple about an hour ago.
                                    First of all I highly recommend to uninstall the app on your phone before
                                    installing the new version to avoid conflicts, because I made changes to
                                    the Storage and Pairing System.
                                    Don't forget to reinstall the module or updating it.
                                    Changelog:
                                    - Added config options to the module.
                                    - Tour is only skipable when already paired.
                                    - Settings added (Multilingual).
                                    - Most modules can be installed through the app.
                                    - Most modules can be updated through the app.
                                    - Most module dependencies can be installed through the app.
                                    - Fixed: Config in one line
                                    - Fixed: Freezing by trying to sync without connection
                                    - Fixed: Overlapping of status bar with skip button in the tour
                                    • strawberry 3.141S
                                      A message that you sent could not be delivered to one or more of its
                                      recipients. This is a permanent error.
                                      If you got no email by now please contact me
                                      • strawberry 3.141S
                                        I’m sorry, there is a bug in the module, which will override the pairing process each time you start the mirror. I made a bugfix over my phone which hopefully fixes it. Please update the module. It can be that you have to redo the pairing process.
                                        tosti007T 1 Reply Last reply
                                        • tosti007T
                                          tosti007 Module Developer @strawberry 3.141
                                          @strawberry-3.141 so appart from my hughw ip fail it’s not just me? :O
                                          If there is anything don’t hesitate to contact me!
                                          ProfileSwitcher, TouchNotifications
                                          • K
                                            kurt
                                            Also did it and good luck too !
                                            • 2 / 6
