    Mobile app (bachelor thesis)
    116 Posts 31 Posters 200.0k Views 31 Watching
    • L Offline
      lolobyte @strawberry 3.141
      @strawberry-3.141
      Sorry, pm is what?
      The App run only with ios10?
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @lolobyte
        @lolobyte personal message
        it requires at least iOS 8 just wanted to say that 10 people have received the mail by apple
        • morozgrafixM Offline
          morozgrafix Moderator
          Filled out survey this morning. Good luck with your thesis, hope my answers help you. (one thing is that my answer about frequency of config.js modifications may screw up your results, due to me playing around with hacking and developing modules) Would love to get on beta of the iOS app.
          • L Offline
            lolobyte
            @strawberry-3-141
            hi, Your app is successfully loaded from apple.
            Little issue.
            Can you tell me whats wrong here?
            pi@raspi3-MM2:~/MagicMirror/modules/MMM-Mobile $ sudo npm install
            npm WARN lifecycle mmm-mobile@1.0.0~preinstall: cannot run in wd %s %s (wd=%s) mmm-mobile@1.0.0 node scripts/preinstall.js /home/pi/MagicMirror/modules/MMM-Mobile
            mmm-mobile@1.0.0 /home/pi/MagicMirror/modules/MMM-Mobile
            ├─┬ async@2.1.4
            │ └── lodash@4.17.4
            ├── moment@2.17.1
            ├── qr-image@3.2.0
            └── simple-git@1.65.0
            after a git pull
            pi@raspi3-MM2:~/MagicMirror/modules/MMM-Mobile $ sudo git pull
            Aktualisiere 2e56f84..41dd1aa
            Fast-forward
             MMM-Mobile.js        | 5 +++--
             translations/es.json | 3 +++
             2 files changed, 6 insertions(+), 2 deletions(-)
             create mode 100644 translations/es.json
            it remain. Same failure!
              @lolobyte the problem was that his config.js file was locked to root access
              • L Offline
                @strawberry-3.141
                That’s happened since i restored the reformatted config.js. ;-)
                • cowboysdudeC Offline
                  cowboysdude Module Developer @strawberry 3.141
                  @strawberry-3.141 said in Mobile app (bachelor thesis):
                  Everyone should have received an email with the App (Android, Windows Phone).
                  iOS users should receive a second mail from Apple themselves with an invite for beta testing.
                  Never got an email from Apple… so I’m kinda stuck. I installed the mirror app but that’s as far as I can go…
                    cowboysdude Module Developer @in_a_days
                    @in_a_days Mine just put a .032 in my config.js and that was it LOL
                      cowboysdude Module Developer @cowboysdude
                      @cowboysdude said in Mobile app (bachelor thesis):
                      I did get the email…check the ‘junk’ folder… ;)
                      And Thanks to Strawberry it’s up and running!!
                      VERY nice work!! Deserves an A+ for sure!!!
                      • L Offline
                        lolobyte
                        @strawberry-3-141;
                        your new MagicMirror² 1.0.2 (4) for iOS is out and ready for testing. :-) :airplane:
                          I just send out the mails,
                          Everyone should have got an email with instructions.
                          iOS users should have received their mail from Apple about an hour ago.
                          First of all I highly recommend to uninstall the app on your phone before
                          installing the new version to avoid conflicts, because I made changes to
                          the Storage and Pairing System.
                          Don't forget to reinstall the module or updating it.
                          Changelog:
                          - Added config options to the module.
                          - Tour is only skipable when already paired.
                          - Settings added (Multilingual).
                          - Most modules can be installed through the app.
                          - Most modules can be updated through the app.
                          - Most module dependencies can be installed through the app.
                          - Fixed: Config in one line
                          - Fixed: Freezing by trying to sync without connection
                          - Fixed: Overlapping of status bar with skip button in the tour
                            A message that you sent could not be delivered to one or more of its
                            recipients. This is a permanent error.
                            If you got no email by now please contact me
                              I’m sorry, there is a bug in the module, which will override the pairing process each time you start the mirror. I made a bugfix over my phone which hopefully fixes it. Please update the module. It can be that you have to redo the pairing process.
                              • T Offline
                                tosti007 Module Developer @strawberry 3.141
                                @strawberry-3.141 so appart from my hughw ip fail it’s not just me? :O
                                If there is anything don’t hesitate to contact me!
                                ProfileSwitcher, TouchNotifications
                                • K Offline
                                  kurt
                                  Also did it and good luck too !
                                  • K Offline
                                    kurt
                                    Just did it, also good luck!
                                    If you need a beta tester with absolut no programming experience…
                                      plumcraft
                                      Can you resend me by email the link where i can download the app ? (i delete all emails in my spam folder on a daily basis)
                                      thanks
                                        strawberry 3.141 Project Sponsor Module Developer @plumcraft
                                        @plumcraft can you send me your mail address in a private message?
                                          bminer1
                                          I cant get the QR Code to come back up. My app is saying “Cannot Establish Connection to MagicMirror”. I didnt have the IP Address in there so i added it and now i cant get the QR code to come back on.
                                            strawberry 3.141 Project Sponsor Module Developer @bminer1
                                            @bminer1 remove the qr.png and mobile.json in the module directory
                                            • 3 / 6
