    Want to turn off my monitor
    monitorpower-saving
    27 Posts 9 Posters 27.2k Views 7 Watching
      robmcc83
      One interesting thing I like about the second way is it seems easy :) lol.
      Would it be possible to say have the screen come on 6-9am in the morning Monday to Friday then come on again 4-10pm as everyone out at work or school during the day. Than say set it so that its on 8am till 10pm on a saturday and sunday when everyone is usually about.
      • cruunnerrC Offline
        cruunnerr
        Sure, this is possible. For the beginning it seems easy, because u needn’t any optional hardware :)
        For your understanding how cronjobs works u should note the following:
        * * * * * user executive_command
        │ │ │ │ └──── Weekday (0-7, Sunday is 0 or 7)
        │ │ │ └────── Month (1-12)
        │ │ └──────── Day (1-31)
        │ └────────── Hour (0-23)
        └──────────── Minute (0-59)
        So for your special wish ^^it should look like this:
        # /etc/crontab: system-wide crontab
        # Unlike any other crontab you don't have to run the `crontab'
        # command to install the new version when you edit this file
        # and files in /etc/cron.d. These files also have username fields,
        # that none of the other crontabs do.
        SHELL=/bin/sh
        PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
        # m h dom mon dow user  command
        17 *    * * *   root    cd / && run-parts --report /etc/cron.hourly
        25 6    * * *   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily )
        47 6    * * 7   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.weekly )
        52 6    1 * *   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.monthly )
        0 6,16  * * 1,2,3,4,5   root  /home/pi/monitor_on.sh
        0 9,22  * * 1,2,3,4,5   root  /home/pi/monitor_off.sh
        0 8     * * 6,7   root  /home/pi/monitor_on.sh
        0 22    * * 6,7   root  /home/pi/monitor_off.sh
        Or if you don’t want to create the *.sh files u can also just type the directly command.
        Like this:
        0 6,16  * * 1,2,3,4,5   root  /usr/bin/tvservice -p
        0 9,22  * * 1,2,3,4,5   root  /usr/bin/tvservice -o
        0 8     * * 6,7   root  /usr/bin/tvservice -p
        0 22    * * 6,7   root  /usr/bin/tvservice -o
        Last thing is the extremely easiest way because u just need to modify the crontab. there is nothing else needed at all.
        Just put these commands in your crontab and u are done ^^
          robmcc83
          That’s brill your a legend, got a few hours to myself tomorrow so armed with all this information and sure be giving this a try see what the outcome is.
          Thank you so much :)
            Mykle1 Project Sponsor Module Developer @Mykle1
            @Mykle1 said in Want to turn off my monitor:
            { exec(‘xset dpms force on’, null); }
            { exec(‘xset dpms force off’, null); }
            These commands do work. I just tested them on my desktop machine with a monitor connected through DVI and a laptop. Displays are immediately turned off (standby) and on. Here’s the laptop.
            https://youtu.be/3ldlUPkw2nM
            R 1 Reply Last reply Reply Quote 2
              robmcc83 @Mykle1
              @Mykle1 that’s cool as :) what are you using for the voice command I love that its brill.
                Mykle1 Project Sponsor Module Developer @robmcc83
                @robmcc83 said in Want to turn off my monitor:
                https://github.com/mykle1/Hello-Lucy
                  Jonae @cruunnerr
                  @cruunnerr i made your tutorial, works like charm! only problem i found is: replaced print “.”, with: print (“.”), Thenks!
                    Jonae @Jonae
                    @Jonae
                    i encounterd another problem, sometimes after display goes ON the resolution is changed. any ideas why?
                    • karsten13K Offline
                      karsten13 @Jonae
                      @Jonae
                      I had similar problems using xrandr for disabling/enabling the monitor.
                      We did a fix in mm for the above problem (coming with next release) but I don’t know if this fixes your problem too.
                      You can find the fix in this PR.
                        Jonae @karsten13
                        @karsten13 said in Want to turn off my monitor:
                        @Jonae
                        Thank you, i updated the file, hope for the best :)
                          Jonae @Jonae
                          so far so good, no problems. so i can call it a fix for me.
