    Want to turn off my monitor
    monitorpower-saving
    27 Posts 9 Posters 27.9k Views 7 Watching
      robmcc83
      Yeah cheers I’m aware of that, it’s just monitor uses 37w whilst on and 2w in standby so I really don’t mind it being in standby at night.
      I think I’m going to look into mmm-remote as trying the other method using vgenmcd power makes my screensaver come back to life even though it’s Been disabled for the last 8 months.
      Is there any tutorials anywhere in setting up mmm-schedule and mmm-remote.
      Cheers all
        robmcc83
        Ok so after trying various ways to get my monitor to turn off I have still been unsuccessful.
        What I am trying now is with a webcam.
        I found in my box of computer bits a Microsoft lifecam hd 3000.
        After a little Google research I can confirm the webcam works with the pi using motion software.
        I also found a site explaining how I can add a start and and event on detection so I set vgencmd display_power 1 as start event and vgencmd display_power 0 as end event but still no luck it just keeps display on but if I enter the command in terminal my display turns on/off as it should.
        Am I going about this in the most awkward way or is there a simple way to get the monitor to sleep using the usb webcam.
        Thanks in advance
          Mykle1 Project Sponsor Module Developer @robmcc83
          @robmcc83
          You could try this for ON
          if (something) {
          exec("/opt/vc/bin/tvservice -o", null); }
          And this for OFF
          { exec("/opt/vc/bin/tvservice --preferred && sudo chvt 6 && sudo chvt 7", null); }
          Or
          { exec('xset dpms force on', null); }
          { exec('xset dpms force off', null); }
          • cruunnerrC Offline
            cruunnerr
            did u try:
            sudo tvservice -o to turn off your Monitor
            sudo tvservice -p to turn on your monitor
            If this isn’t working i think your Monitor or your HDMI Cable are not supporting CEC.
            If this works u have several options.
            For example u can create two *.sh files and make them executable. Put these scripts into cronjob file for time based turning on or off the monitor.
            Or u can use a PIR or a simple Button to do that. Let me give you a small software tutorial for this example:
            Tutorial beginning:
            cd
            nano monitor_on.sh (creates the file)
            write this in this file:
            sudo tvservice -p
            save with “ctrl+x” and say “y” to save the file.
            nano monitor_off.sh
            sudo tvservice -o
            chmod +x monitor_on.sh (to make it executable)
            chmod +x monitor_off.sh
            So now you have two options. Write a python script to automatically start the shell scripts by using a GPIO or just put the Shell scripts into a cronjob.
            Here is the first way:
            nano pir.py (creates a script which executes the *.sh files via PIR or Button)
            write this into the file:
            #!/usr/bin/env python
            import sys
            import time
            import RPi.GPIO as io
            import subprocess
            io.setmode(io.BCM)
            SHUTOFF_DELAY = 119 # in seconds, how long the monitor will be on until next button press or PIR detection
            PIR_PIN = 25       # 22 on the board (this needn't to be a PIR. Can be a button also)
            LED_PIN = 16      # optional
            def main():
                io.setup(PIR_PIN, io.IN)
                io.setup(LED_PIN, io.OUT)
                turned_off = False
                last_motion_time = time.time()
                while True:
                    if io.input(PIR_PIN):
                        io.output(LED_PIN, io.LOW)
                        print ".",
                        sys.stdout.flush()
                        if turned_off:
                            turned_off = False
                            turn_on()
                    else:
                        if not turned_off and time.time() > (last_motion_time +
                                                             SHUTOFF_DELAY):
                            turned_off = True
                            turn_off()
                        if not turned_off and time.time() > (last_motion_time + 1):
                            io.output(LED_PIN, io.HIGH)
                    time.sleep(.1)
            def turn_on():
            	subprocess.call("sh /home/pi/monitor_on.sh", shell=True)
            def turn_off():
            	subprocess.call("sh /home/pi/monitor_off.sh", shell=True)
            if __name__ == '__main__':
                try:
                    main()
                except KeyboardInterrupt:
                    io.cleanup()
            chmod +x pir.py
            You can check if your button works by simply typing python pir.py. Every time u move through the PIR or press the button it will show you some …
            End the test with “ctrl+c”
            now we editing the rc.local to start the script after booting the Pi:
            sudo nano /etc/rc.local
            write this in the file (above the “exit 0”):
            python /home/pi/pir.py &
            after all it should look like this:
            #!/bin/sh -e
            # rc.local
            # This script is executed at the end of each multiuser runlevel.
            # Make sure that the script will "exit 0" on success or any other
            # value on error.
            # In order to enable or disable this script just change the execution
            # bits.
            # By default this script does nothing.
            # Print the IP address
            _IP=$(hostname -I) || true
            if [ "$_IP" ]; then
              printf "My IP address is %s\n" "$_IP"
            fi
            exit 0
            Here comes the second way:
            Next steps we will do as root to be sure it works. Maybe not the best way, but i am just a simple guy, who is still learning the stuff. ^^
            Lets say we want to turn on the monitor every day at 6am and turn off at 8pm:
            sudo nano /etc/crontab (to open the crontab)
            0 6 * * * /home/pi/monitor_on.sh
            0 20 * * * /home/pi/monitor_off.sh
            this should look like this:
            # /etc/crontab: system-wide crontab
            # Unlike any other crontab you don't have to run the `crontab'
            # command to install the new version when you edit this file
            # and files in /etc/cron.d. These files also have username fields,
            # that none of the other crontabs do.
            SHELL=/bin/sh
            PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
            # m h dom mon dow user  command
            17 *    * * *   root    cd / && run-parts --report /etc/cron.hourly
            25 6    * * *   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily )
            47 6    * * 7   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.weekly )
            52 6    1 * *   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.monthly )
            0 6     * * *   root      /home/pi/monitor_on.sh
            0 20    * * *   root      /home/pi/monitor_off.sh
            I wrote this just out of my head so i hope i didn’t forget anything.
            Tutorial ending!
            That is just an example of using a GPIO to turn off and on your monitor via HDMI-CEC.
            How i said, if your monitor or cable doesn’t support this u need to choose another way (turn a relays on and off to the power supply of the monitor e.g.)
            edit:
            sorry @mykle1, did not notice that you already answered, because I already started to write while you answered :D
            Mykle1M J 2 Replies Last reply Reply Quote 1
              Mykle1 Project Sponsor Module Developer @cruunnerr
              @cruunnerr
              No worries, mate. I hope to learn something from your answer. (which is totally amazing to me)
              Peace!
                robmcc83
                Thanks this is very useful information that I didn’t know before.
                I have issued the sudo tvservice -o command and it did indeed shut down my monitor.
                But what I am trying at the moment is to have it shutdown and wakeup the monitor with a usb webcam now.
                That’s what I’m struggling with.
                Cheers
                  robmcc83
                  One interesting thing I like about the second way is it seems easy :) lol.
                  Would it be possible to say have the screen come on 6-9am in the morning Monday to Friday then come on again 4-10pm as everyone out at work or school during the day. Than say set it so that its on 8am till 10pm on a saturday and sunday when everyone is usually about.
                    cruunnerr
                    Sure, this is possible. For the beginning it seems easy, because u needn’t any optional hardware :)
                    For your understanding how cronjobs works u should note the following:
                    * * * * * user executive_command
                    │ │ │ │ └──── Weekday (0-7, Sunday is 0 or 7)
                    │ │ │ └────── Month (1-12)
                    │ │ └──────── Day (1-31)
                    │ └────────── Hour (0-23)
                    └──────────── Minute (0-59)
                    So for your special wish ^^it should look like this:
                    SHELL=/bin/sh
                    0 6,16  * * 1,2,3,4,5   root  /home/pi/monitor_on.sh
                    0 9,22  * * 1,2,3,4,5   root  /home/pi/monitor_off.sh
                    0 8     * * 6,7   root  /home/pi/monitor_on.sh
                    0 22    * * 6,7   root  /home/pi/monitor_off.sh
                    Or if you don’t want to create the *.sh files u can also just type the directly command.
                    Like this:
                    0 6,16  * * 1,2,3,4,5   root  /usr/bin/tvservice -p
                    0 9,22  * * 1,2,3,4,5   root  /usr/bin/tvservice -o
                    0 8     * * 6,7   root  /usr/bin/tvservice -p
                    0 22    * * 6,7   root  /usr/bin/tvservice -o
                    Last thing is the extremely easiest way because u just need to modify the crontab. there is nothing else needed at all.
                    Just put these commands in your crontab and u are done ^^
                      robmcc83
                      That’s brill your a legend, got a few hours to myself tomorrow so armed with all this information and sure be giving this a try see what the outcome is.
                      Thank you so much :)
                        Mykle1 Project Sponsor Module Developer @Mykle1
                        @Mykle1 said in Want to turn off my monitor:
                        { exec(‘xset dpms force on’, null); }
                        { exec(‘xset dpms force off’, null); }
                        These commands do work. I just tested them on my desktop machine with a monitor connected through DVI and a laptop. Displays are immediately turned off (standby) and on. Here’s the laptop.
                        https://youtu.be/3ldlUPkw2nM
                        R 1 Reply Last reply Reply Quote 2
                          robmcc83 @Mykle1
                          @Mykle1 that’s cool as :) what are you using for the voice command I love that its brill.
                            @robmcc83 said in Want to turn off my monitor:
                            https://github.com/mykle1/Hello-Lucy
                              Jonae @cruunnerr
                              @cruunnerr i made your tutorial, works like charm! only problem i found is: replaced print “.”, with: print (“.”), Thenks!
                                Jonae @Jonae
                                @Jonae
                                i encounterd another problem, sometimes after display goes ON the resolution is changed. any ideas why?
                                • karsten13K Offline
                                  karsten13 @Jonae
                                  @Jonae
                                  I had similar problems using xrandr for disabling/enabling the monitor.
                                  We did a fix in mm for the above problem (coming with next release) but I don’t know if this fixes your problem too.
                                  You can find the fix in this PR.
                                    Jonae @karsten13
                                    @karsten13 said in Want to turn off my monitor:
                                    @Jonae
                                    Thank you, i updated the file, hope for the best :)
                                      Jonae @Jonae
                                      so far so good, no problems. so i can call it a fix for me.
