    Want to turn off my monitor
    monitorpower-saving
    27 Posts 9 Posters 27.6k Views 7 Watching
      robmcc83
      Cheers for the replies everyone all is noted :)
      For now think I’ll keep searching the net for a way to have the monitor on during the day and sleep at night.
      I have found one site that shows how to do it but want to make a backup image first incase I break anything lol.
      I do like the idea of a pir. Are they easy to setup if I cannot get on with the way I’m currently looking for.
      Cheers
      • randomnoiseR Offline
        randomnoise
        For simple time based screen on & off check https://github.com/ianperrin/MMM-ModuleScheduler
        randomnoiseR 1 Reply Last reply Reply Quote 0
          randomnoise @randomnoise
          Sorry, should say you combine with the remote control module to send screen off notifications.
            robmcc83
            So I’ve been looking through the net and have found I can use vcgencmd display_power 0 to turn off my monitor and the same again to power 1 to turn it back on, it also explains it can be run as a cron job but I’ve never done one of them so not to sure.
            Would it all be possible to hook up a push button switch to the gpio and have them commands somehow turn the display off and on.
              doubleT Module Developer
              Don’t forget that the monitor will still be on, it’s just in standby, still consuming power. The Pi can’t switch the power of the monitor itself off.
                robmcc83
                Yeah cheers I’m aware of that, it’s just monitor uses 37w whilst on and 2w in standby so I really don’t mind it being in standby at night.
                I think I’m going to look into mmm-remote as trying the other method using vgenmcd power makes my screensaver come back to life even though it’s Been disabled for the last 8 months.
                Is there any tutorials anywhere in setting up mmm-schedule and mmm-remote.
                Cheers all
                  robmcc83
                  Ok so after trying various ways to get my monitor to turn off I have still been unsuccessful.
                  What I am trying now is with a webcam.
                  I found in my box of computer bits a Microsoft lifecam hd 3000.
                  After a little Google research I can confirm the webcam works with the pi using motion software.
                  I also found a site explaining how I can add a start and and event on detection so I set vgencmd display_power 1 as start event and vgencmd display_power 0 as end event but still no luck it just keeps display on but if I enter the command in terminal my display turns on/off as it should.
                  Am I going about this in the most awkward way or is there a simple way to get the monitor to sleep using the usb webcam.
                  Thanks in advance
                    Mykle1 Project Sponsor Module Developer @robmcc83
                    @robmcc83
                    You could try this for ON
                    if (something) {
                    exec("/opt/vc/bin/tvservice -o", null); }
                    And this for OFF
                    { exec("/opt/vc/bin/tvservice --preferred && sudo chvt 6 && sudo chvt 7", null); }
                    Or
                    { exec('xset dpms force on', null); }
                    { exec('xset dpms force off', null); }
                    • cruunnerrC Offline
                      cruunnerr
                      did u try:
                      sudo tvservice -o to turn off your Monitor
                      sudo tvservice -p to turn on your monitor
                      If this isn’t working i think your Monitor or your HDMI Cable are not supporting CEC.
                      If this works u have several options.
                      For example u can create two *.sh files and make them executable. Put these scripts into cronjob file for time based turning on or off the monitor.
                      Or u can use a PIR or a simple Button to do that. Let me give you a small software tutorial for this example:
                      Tutorial beginning:
                      cd
                      nano monitor_on.sh (creates the file)
                      write this in this file:
                      sudo tvservice -p
                      save with “ctrl+x” and say “y” to save the file.
                      nano monitor_off.sh
                      sudo tvservice -o
                      chmod +x monitor_on.sh (to make it executable)
                      chmod +x monitor_off.sh
                      So now you have two options. Write a python script to automatically start the shell scripts by using a GPIO or just put the Shell scripts into a cronjob.
                      Here is the first way:
                      nano pir.py (creates a script which executes the *.sh files via PIR or Button)
                      write this into the file:
                      #!/usr/bin/env python
                      import sys
                      import time
                      import RPi.GPIO as io
                      import subprocess
                      io.setmode(io.BCM)
                      SHUTOFF_DELAY = 119 # in seconds, how long the monitor will be on until next button press or PIR detection
                      PIR_PIN = 25       # 22 on the board (this needn't to be a PIR. Can be a button also)
                      LED_PIN = 16      # optional
                      def main():
                          io.setup(PIR_PIN, io.IN)
                          io.setup(LED_PIN, io.OUT)
                          turned_off = False
                          last_motion_time = time.time()
                          while True:
                              if io.input(PIR_PIN):
                                  io.output(LED_PIN, io.LOW)
                                  print ".",
                                  sys.stdout.flush()
                                  if turned_off:
                                      turned_off = False
                                      turn_on()
                              else:
                                  if not turned_off and time.time() > (last_motion_time +
        SHUTOFF_DELAY):
                                      turned_off = True
                                      turn_off()
                                  if not turned_off and time.time() > (last_motion_time + 1):
                                      io.output(LED_PIN, io.HIGH)
                              time.sleep(.1)
                      def turn_on():
                      	subprocess.call("sh /home/pi/monitor_on.sh", shell=True)
                      def turn_off():
                      	subprocess.call("sh /home/pi/monitor_off.sh", shell=True)
                      if __name__ == '__main__':
                          try:
                              main()
                          except KeyboardInterrupt:
                              io.cleanup()
                      chmod +x pir.py
                      You can check if your button works by simply typing python pir.py. Every time u move through the PIR or press the button it will show you some …
                      End the test with “ctrl+c”
                      now we editing the rc.local to start the script after booting the Pi:
                      sudo nano /etc/rc.local
                      write this in the file (above the “exit 0”):
                      python /home/pi/pir.py &
                      after all it should look like this:
                      #!/bin/sh -e
                      # rc.local
                      # This script is executed at the end of each multiuser runlevel.
                      # Make sure that the script will "exit 0" on success or any other
                      # value on error.
                      # In order to enable or disable this script just change the execution
                      # bits.
                      # By default this script does nothing.
                      # Print the IP address
                      _IP=$(hostname -I) || true
                      if [ "$_IP" ]; then
                        printf "My IP address is %s\n" "$_IP"
                      fi
                      exit 0
                      Here comes the second way:
                      Next steps we will do as root to be sure it works. Maybe not the best way, but i am just a simple guy, who is still learning the stuff. ^^
                      Lets say we want to turn on the monitor every day at 6am and turn off at 8pm:
                      sudo nano /etc/crontab (to open the crontab)
                      0 6 * * * /home/pi/monitor_on.sh
                      0 20 * * * /home/pi/monitor_off.sh
                      this should look like this:
                      # /etc/crontab: system-wide crontab
                      # Unlike any other crontab you don't have to run the `crontab'
                      # command to install the new version when you edit this file
                      # and files in /etc/cron.d. These files also have username fields,
                      # that none of the other crontabs do.
                      SHELL=/bin/sh
                      PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
                      # m h dom mon dow user  command
                      17 *    * * *   root    cd / && run-parts --report /etc/cron.hourly
                      25 6    * * *   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily )
                      47 6    * * 7   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.weekly )
                      52 6    1 * *   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.monthly )
                      0 6     * * *   root      /home/pi/monitor_on.sh
                      0 20    * * *   root      /home/pi/monitor_off.sh
                      I wrote this just out of my head so i hope i didn’t forget anything.
                      Tutorial ending!
                      That is just an example of using a GPIO to turn off and on your monitor via HDMI-CEC.
                      How i said, if your monitor or cable doesn’t support this u need to choose another way (turn a relays on and off to the power supply of the monitor e.g.)
                      edit:
                      sorry @mykle1, did not notice that you already answered, because I already started to write while you answered :D
                      Mykle1M J 2 Replies Last reply Reply Quote 1
                        Mykle1 Project Sponsor Module Developer @cruunnerr
                        @cruunnerr
                        No worries, mate. I hope to learn something from your answer. (which is totally amazing to me)
                        Peace!
                          robmcc83
                          Thanks this is very useful information that I didn’t know before.
                          I have issued the sudo tvservice -o command and it did indeed shut down my monitor.
                          But what I am trying at the moment is to have it shutdown and wakeup the monitor with a usb webcam now.
                          That’s what I’m struggling with.
                          Cheers
                            robmcc83
                            One interesting thing I like about the second way is it seems easy :) lol.
                            Would it be possible to say have the screen come on 6-9am in the morning Monday to Friday then come on again 4-10pm as everyone out at work or school during the day. Than say set it so that its on 8am till 10pm on a saturday and sunday when everyone is usually about.
                              cruunnerr
                              Sure, this is possible. For the beginning it seems easy, because u needn’t any optional hardware :)
                              For your understanding how cronjobs works u should note the following:
                              * * * * * user executive_command
                              │ │ │ │ └──── Weekday (0-7, Sunday is 0 or 7)
                              │ │ │ └────── Month (1-12)
                              │ │ └──────── Day (1-31)
                              │ └────────── Hour (0-23)
                              └──────────── Minute (0-59)
                              So for your special wish ^^it should look like this:
                              SHELL=/bin/sh
                              0 6,16  * * 1,2,3,4,5   root  /home/pi/monitor_on.sh
                              0 9,22  * * 1,2,3,4,5   root  /home/pi/monitor_off.sh
                              0 8     * * 6,7   root  /home/pi/monitor_on.sh
                              0 22    * * 6,7   root  /home/pi/monitor_off.sh
                              Or if you don’t want to create the *.sh files u can also just type the directly command.
                              Like this:
                              0 6,16  * * 1,2,3,4,5   root  /usr/bin/tvservice -p
                              0 9,22  * * 1,2,3,4,5   root  /usr/bin/tvservice -o
                              0 8     * * 6,7   root  /usr/bin/tvservice -p
                              0 22    * * 6,7   root  /usr/bin/tvservice -o
                              Last thing is the extremely easiest way because u just need to modify the crontab. there is nothing else needed at all.
                              Just put these commands in your crontab and u are done ^^
                                robmcc83
                                That’s brill your a legend, got a few hours to myself tomorrow so armed with all this information and sure be giving this a try see what the outcome is.
                                Thank you so much :)
                                  Mykle1 Project Sponsor Module Developer @Mykle1
                                  @Mykle1 said in Want to turn off my monitor:
                                  { exec(‘xset dpms force on’, null); }
                                  { exec(‘xset dpms force off’, null); }
                                  These commands do work. I just tested them on my desktop machine with a monitor connected through DVI and a laptop. Displays are immediately turned off (standby) and on. Here’s the laptop.
                                  https://youtu.be/3ldlUPkw2nM
                                  R 1 Reply Last reply Reply Quote 2
                                    robmcc83 @Mykle1
                                    @Mykle1 that’s cool as :) what are you using for the voice command I love that its brill.
                                      @robmcc83 said in Want to turn off my monitor:
                                      https://github.com/mykle1/Hello-Lucy
                                        Jonae @cruunnerr
                                        @cruunnerr i made your tutorial, works like charm! only problem i found is: replaced print “.”, with: print (“.”), Thenks!
                                          Jonae @Jonae
                                          @Jonae
                                          i encounterd another problem, sometimes after display goes ON the resolution is changed. any ideas why?
                                          • karsten13K Offline
                                            karsten13 @Jonae
                                            @Jonae
                                            I had similar problems using xrandr for disabling/enabling the monitor.
                                            We did a fix in mm for the above problem (coming with next release) but I don’t know if this fixes your problem too.
                                            You can find the fix in this PR.
