    MMM-TouchNavigation, A Touch Activated Profile/Layout Changer
    touchnavigationmodulelayoutprofilebuttonswitch
    43 Posts 9 Posters 54.8k Views 10 Watching
    • T
      tosti007 Module Developer @shashank
      @shashank and what is your config for the touchnavigation? I also uploaded an example config file that should work in the repository
      If there is anything don’t hesitate to contact me!
      ProfileSwitcher, TouchNotifications
        shashank @tosti007
        @tosti007 This is my config.js
        { module: ‘alert’,},
        	{ module: "updatenotification", position: "top_bar" },
                module: "MMM-ProfileSwitcher",
        			includeEveryoneToDefault: true,
                module: "MMM-TouchNavigation",
                position: "bottom_center",
                classes: "default everyone",
                    buttons: {
                        "default": {
                            symbol: "ban"
                        "Brian": {
                            text: " Brian",
                            symbol: "paper-plane"
                        "Lisa": {
                            text: "Lisa"
                module: "clock",
                classes: "everyone",
                position: "top_left"
                module: "clock",
                classes: "default",
                position: "middle_center",
                    analogShowDate: false,
                    displayType: "analog"
                module: "helloworld",
                classes: "Lisa",
                position: "lower_third"
                classes: "Brian"
        T 1 Reply Last reply
        • T
          @shashank Oh damnit, I made a terrible mistake while testing. Turns out that I was using the developer branch while testing. In the developer branch they fixed pointer events from fullscreen region not passing down onto the underlaying modules. So when you used my module it did not send the pointer events to the buttons. I made a new commit to my module so it should be fixed if you pull the changes (goto MMM-TouchNavigation folder and do git pull). However you cannot use this module in fullscreen mode now. If you desire to do so let me know and I will go more in depth on how to solve this issue. Thank you for letting me know!
          • T
            @all IMPORTANT NOTE: Unfortunatly setting this module to full screen does not work. The menu floats in the top left corner and you cannot press any buttons! I might be able to fix this, but since there is no audience currently wanting this feature I will wait for the new MagicMirror version (where this issue will be fixed). Let me know if you want to have it full screen aswell and I will see what i can do!
            Edit: thanks to @broberg this issue was solved :)
            B 1 Reply Last reply
              broberg Project Sponsor @tosti007
              @tosti007 add z-index: -1 or 0 to the region fullscreen above, it blocks everything beneath so it can’t be clicked ( or add z-index: 2 to the module div)
              T 2 Replies Last reply
              • T
                tosti007 Module Developer @broberg
                @broberg yea I thought that would work too, however when I set z-index to -1 on region fullscreen nothing much happened. I will try that z-index of 2 on the module dif aswell
                • T
                  @broberg Only setting region fullscreen to 0 worked. Not entirely sure tho. Anyways ty for the tip! Updated my module :)
                    shashank @tosti007
                    @tosti007 hi, after git pull, module working great, Thanks for your quick response , keep rocking…
                      shashank @tosti007
                      @tosti007 , Any possibility of using JPG photos of users instead of symbols in the TouchNavigation module, this will give a good interaction with the mirror
                      • T
                        @shashank you are welcome :) and about the images: yes I think that would be most definitely possible. However then the button size might become a problem if it’s too big, but I can give it a try.
                          shashank @tosti007
                          @tosti007 hi, other modules are ovelapping on to Touch Profile , how to move touch profile icons to extreme bottom or top
                          • T
                            @shashank a way would be to change the z-index in teh css file to a higher number, I will have a look at it
                            • strawberry 3.141S
                              strawberry 3.141 Project Sponsor Module Developer @tosti007
                              @tosti007 when you just change the zindex the modules are still overlapping
                              you could create a class left center and right and then classes for top middle bottom and let the user decide which position it has like bottom right
                              • T
                                @shashank I am not able to reproduce the error, could you tell me what your config looks like?
                                @strawberry-3-141 would be a neat feature. However you can already do that by setting the position of the module different?
                                • strawberry 3.141S
                                  @tosti007 nevermind i thought i read that you should put it in fullscreen_above, but that was probably another module sry
                                  • T
                                    tosti007 Module Developer @strawberry 3.141
                                    @strawberry-3.141 no problem, for fullscreen it would work
                                    • SnilleS
                                      Snille Module Developer
                                      Different look for this module, just wanted to share :)…
                                      Grayscale:
                                      Or in color:
                                      It’s only the pictures that differ from the gray or color ones.
                                      You have to use your own pictures of course. :)
                                      In the config.js:
                                      	module: 'MMM-TouchNavigation',
                                      	position: 'bottom_left',
                                      		picturePlacement: "right",
                                      		minWidth: "40px",
                                      		direction: "column",
                                      		buttons: {
                                      			"Name1": {
                                      				img: "http://www.your-picture.com/name1-Gray.png",
                                      				width: 60,
                                      				height: 60
                                      			"Name2": {
                                      				img: "http://www.your-picture.com/name2-Gray.png",
                                      				width: 60,
                                      				height: 60
                                      			"Name3": {
                                      				img: "http://www.your-picture.com/name3-Gray.png",
                                      				width: 60,
                                      				height: 60
                                      In my custom.css:
                                      /* Touch Buttons */
                                      .navigation-button {
                                          margin: 5px;
                                          padding: 0px 0px;
                                          border: 2px solid #FFF;
                                          border-radius: 0px;
                                          border-radius: 50%;
                                      .navigation-picture {
                                          margin: 0px 0px;
                                          border-radius: 50%;
                                      .navigation-menu {
                                          align-items: flex-start;
                                      /* ----- End ----- */
                                      Update: Just noticed that the buttons got “stretched” if something else was displayed in the same region. So I added the “.navigation-menu” part in the css.
                                      If you have the buttons on the right side, use: “flex-end” instead of “flex-start”.
                                      Enjoy! :)
                                      T S 2 Replies Last reply
                                      • T
                                        tosti007 Module Developer @Snille
                                        @Snille it’s looking great! I really like what you did with the shape of the buttons! Thank you for sharing :D It’s awesome to hear people using my module and coming up with their own versions
                                        SnilleS 1 Reply Last reply
                                        • SnilleS
                                          Snille Module Developer @tosti007
                                          @tosti007 Thank you! Now it fits perfectly with the MM-Hide-All module. :)
                                          • T
                                            @Snille yes it does go well with it
