    MMM-TouchNavigation, A Touch Activated Profile/Layout Changer
    touchnavigationmodulelayoutprofilebuttonswitch
    43 Posts 9 Posters 53.8k Views 10 Watching
      shashank @tosti007
      @tosti007 , Any possibility of using JPG photos of users instead of symbols in the TouchNavigation module, this will give a good interaction with the mirror
      • T Offline
        tosti007 Module Developer @shashank
        @shashank you are welcome :) and about the images: yes I think that would be most definitely possible. However then the button size might become a problem if it’s too big, but I can give it a try.
        If there is anything don’t hesitate to contact me!
        ProfileSwitcher, TouchNotifications
          shashank @tosti007
          @tosti007 hi, other modules are ovelapping on to Touch Profile , how to move touch profile icons to extreme bottom or top
          T 2 Replies Last reply Reply Quote 0
          • T Offline
            @shashank a way would be to change the z-index in teh css file to a higher number, I will have a look at it
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @tosti007
              @tosti007 when you just change the zindex the modules are still overlapping
              you could create a class left center and right and then classes for top middle bottom and let the user decide which position it has like bottom right
              • T Offline
                @shashank I am not able to reproduce the error, could you tell me what your config looks like?
                @strawberry-3-141 would be a neat feature. However you can already do that by setting the position of the module different?
                  @tosti007 nevermind i thought i read that you should put it in fullscreen_above, but that was probably another module sry
                  • T Offline
                    tosti007 Module Developer @strawberry 3.141
                    @strawberry-3.141 no problem, for fullscreen it would work
                    • SnilleS Offline
                      Snille Module Developer
                      Different look for this module, just wanted to share :)…
                      Grayscale:
                      Or in color:
                      It’s only the pictures that differ from the gray or color ones.
                      You have to use your own pictures of course. :)
                      In the config.js:
                      	module: 'MMM-TouchNavigation',
                      	position: 'bottom_left',
                      	classes: "default everyone",
                      		picturePlacement: "right",
                      		minWidth: "40px",
                      		direction: "column",
                      		buttons: {
                      			"Name1": {
                      				img: "http://www.your-picture.com/name1-Gray.png",
                      				width: 60,
                      				height: 60
                      			"Name2": {
                      				img: "http://www.your-picture.com/name2-Gray.png",
                      				width: 60,
                      				height: 60
                      			"Name3": {
                      				img: "http://www.your-picture.com/name3-Gray.png",
                      				width: 60,
                      				height: 60
                      In my custom.css:
                      /* Touch Buttons */
                      .navigation-button {
                          margin: 5px;
                          padding: 0px 0px;
                          border: 2px solid #FFF;
                          border-radius: 0px;
                          border-radius: 50%;
                      .navigation-picture {
                          margin: 0px 0px;
                          border-radius: 50%;
                      .navigation-menu {
                          align-items: flex-start;
                      /* ----- End ----- */
                      Update: Just noticed that the buttons got “stretched” if something else was displayed in the same region. So I added the “.navigation-menu” part in the css.
                      If you have the buttons on the right side, use: “flex-end” instead of “flex-start”.
                      Enjoy! :)
                      T S 2 Replies Last reply Reply Quote 1
                      • T Offline
                        tosti007 Module Developer @Snille
                        @Snille it’s looking great! I really like what you did with the shape of the buttons! Thank you for sharing :D It’s awesome to hear people using my module and coming up with their own versions
                        SnilleS 1 Reply Last reply Reply Quote 0
                        • SnilleS Offline
                          Snille Module Developer @tosti007
                          @tosti007 Thank you! Now it fits perfectly with the MM-Hide-All module. :)
                          • T Offline
                            @Snille yes it does go well with it
                              shashank @Snille
                              @Snille hi, i could not able to get pictures on the MM, below is my config and i completely deleted TouchNavigation.css contents and pasted your Custom.css contents
                                          module: "MMM-TouchNavigation",
                              			    minWidth: "40px",
                              		buttons: {
                              				"Sun": {
                              				img: "/home/pi/MagicMirror/Sun.png",
                              				width: 60,
                              				height: 60
                              			"Moon": {
                              				img: "/home/pi/MagicMirror/Moon.png",
                              				width: 60,
                              				height: 60
                              0_1485139242710_upload-29e5e55f-31ad-44ba-97a9-681a1f2f82b9
                              T SnilleS 2 Replies Last reply Reply Quote 0
                              • T Offline
                                @shashank it’s not able to find the images. Try changing the path. For me (on Windows) images only worked when I placed them in a sub folder in MM and used as path foldername/imagename. So try changing the way you write the path or try placing them in a sub folder
                                • SnilleS Offline
                                  Snille Module Developer @shashank
                                  @shashank Hi! You should not need to delete the TouchNavigation.css file at all. It shall remain, you just have to add the css things in the MagicMirror/css/custom.css nothing else. The module itself shall remain “untouched”, then later on you will not have update problems. :) Also, I did only change what’s needed to be changed in the custom.css there are still settings in the TouchNavigation.css file that may be needed. Regarding the pictures, I’m not sure, as someone else mentioned I think you may need to create a sub-folder for them. But I never tested to have the pictures “locally”. Sorry.
                                  • T Offline
                                    @Snille thank you for pointing out about the css file, I read over that!
                                    @shashank what @Snille says is right. The css file should remain as it is and you should put his css in css/custom.css file
                                    • G Offline
                                      GorramRob
                                      Hi! Thanks for writing this! I’m trying to get it running but am having some troubles. I have a handful of modules listed as ignored in the profile switcher module (including the clock so at least something should be showing all the time) but as soon as I enable the TouchNavigation module all I see is a black screen. No modules are displayed/visible.
                                      I double checked the MODULE_DATA from the remote-control module, it appears all the modules are loading correctly. Any thoughts on what might be going on?
                                      • T Offline
                                        tosti007 Module Developer @GorramRob
                                        @GorramRob hmmm that’s fairly odd. Try doing a fresh clone and make sure that your config file it right. Did you add the touchnavigation to the ignore modules aswell, is ne spelling correct (case sensitive) and is the ignoremodules config an array? In the meantime I will have another look at the module trying to figure out what might be wrong.
                                        • G Offline
                                          GorramRob @tosti007
                                          @tosti007 Huh… I’m not sure what was going on but I cloned a new copy of it and everything seems to be working fine. I thought I had done that before, but maybe not. Thank you for replying so quickly!
                                          • T Offline
                                            After the new update of the MagicMirror framework and this issue I updated the css. This means that you can finally use the fullscreen positions for this module!
                                            • 2 / 3
