    MMM-TouchNavigation, A Touch Activated Profile/Layout Changer
    touchnavigationmodulelayoutprofilebuttonswitch
    43 Posts 9 Posters 54.8k Views 10 Watching
    • T
      tosti007 Module Developer @Snille
      @Snille yes it does go well with it
      If there is anything don’t hesitate to contact me!
      ProfileSwitcher, TouchNotifications
        shashank @Snille
        @Snille hi, i could not able to get pictures on the MM, below is my config and i completely deleted TouchNavigation.css contents and pasted your Custom.css contents
                    module: "MMM-TouchNavigation",
                    position: 'bottom_left',
        	        classes: "default everyone",
        				picturePlacement: "right",
        			    minWidth: "40px",
        		        direction: "column",
        		buttons: {
        				"Sun": {
        				img: "/home/pi/MagicMirror/Sun.png",
        				width: 60,
        				height: 60
        			"Moon": {
        				img: "/home/pi/MagicMirror/Moon.png",
        				width: 60,
        				height: 60
        0_1485139242710_upload-29e5e55f-31ad-44ba-97a9-681a1f2f82b9
        T SnilleS 2 Replies Last reply
        • T
          tosti007 Module Developer @shashank
          @shashank it’s not able to find the images. Try changing the path. For me (on Windows) images only worked when I placed them in a sub folder in MM and used as path foldername/imagename. So try changing the way you write the path or try placing them in a sub folder
          • SnilleS
            Snille Module Developer @shashank
            @shashank Hi! You should not need to delete the TouchNavigation.css file at all. It shall remain, you just have to add the css things in the MagicMirror/css/custom.css nothing else. The module itself shall remain “untouched”, then later on you will not have update problems. :) Also, I did only change what’s needed to be changed in the custom.css there are still settings in the TouchNavigation.css file that may be needed. Regarding the pictures, I’m not sure, as someone else mentioned I think you may need to create a sub-folder for them. But I never tested to have the pictures “locally”. Sorry.
            T 1 Reply Last reply
            • T
              @Snille thank you for pointing out about the css file, I read over that!
              @shashank what @Snille says is right. The css file should remain as it is and you should put his css in css/custom.css file
              • G
                GorramRob
                Hi! Thanks for writing this! I’m trying to get it running but am having some troubles. I have a handful of modules listed as ignored in the profile switcher module (including the clock so at least something should be showing all the time) but as soon as I enable the TouchNavigation module all I see is a black screen. No modules are displayed/visible.
                I double checked the MODULE_DATA from the remote-control module, it appears all the modules are loading correctly. Any thoughts on what might be going on?
                • T
                  tosti007 Module Developer @GorramRob
                  @GorramRob hmmm that’s fairly odd. Try doing a fresh clone and make sure that your config file it right. Did you add the touchnavigation to the ignore modules aswell, is ne spelling correct (case sensitive) and is the ignoremodules config an array? In the meantime I will have another look at the module trying to figure out what might be wrong.
                  G 1 Reply Last reply
                  • G
                    GorramRob @tosti007
                    @tosti007 Huh… I’m not sure what was going on but I cloned a new copy of it and everything seems to be working fine. I thought I had done that before, but maybe not. Thank you for replying so quickly!
                    • T
                      After the new update of the MagicMirror framework and this issue I updated the css. This means that you can finally use the fullscreen positions for this module!
                      • cowboysdudeC
                        Fine module Sir… I’ll be playing with this very soon ;)
                        • T
                          Hello everybody! I made a new module that is basically a rewrite of this one, but it allows for custom notifications. You can find more info about it here. MMM-TouchNotifications has the same features as MMM-TouchNavigation (the one you are looking at now).
                          Reply Quote 2
                          • SnilleS
                            @tosti007 Darn you! :) Now I have to start using this instead!! Thank you, need to get my mirror up and running again so I can reconfigure it (building frame for the moment). :)
                            • T
                              @Snille well you don’t have to, it’s just an option :P both still work. The other just allows for more possiblies but does take some more configuration than this module
                                Binog
                                Hey, can someone please help, or just post their config file?
                                1.: I have this, and it does not show anything:
                                and
                                2.: What does the payload has to look like? that seems incorrect,… !?
                                           position: "bottom_right",
                                           classes: 'default you me',
                                   			minWidth: "30px",
                                   			direction: "row",
                                   			//border-radius: "1px",
                                   			//border-radius: "50%",
                                   			buttons: {
                                   				"me": {
                                   					img: "http://file to jpg",
                                   					width: 40,
                                   					height: 40,
                                   					profilename: "me",
                                   					text: "me",
                                   				"You": {
                                   					img: "https://file to .jpg",
                                   					width: 40,
                                   					height: 40,
                                   					NOTIFICATION: {
                                   						payload: {
                                   							//this.sendNotification('CURRENT_PROFILE', 'You')
                                   						profilename: "You",
                                • T
                                  tosti007 Module Developer @Binog
                                  Hello @Binog,
                                  As fully described here you do not need to set something like profilename. The profile name is defined in the string before the : (like the first "me" after buttons).
                                  It’s not possible to have a custom notification. For that you would have to look at this module.
                                    Binog
                                    Thanks for explaining,
                                    Is the Syntax, the same?
                                    I realized,. my module is TouchNavigation thow the installed module in modules ist TouchNavigations,… face-palm
                                    • KamiSchamiK
                                      KamiSchami
                                      Hi, suddenly the border of my buttons are black. I no longer know whether I have adjusted something. Where can i search? By the way, great module.
                                      Real programmers never work 9 to 5. If they are around at 9 AM, it’s because they were up all night.
                                      • 2 / 3
