    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.6m Views 33 Watching
      sdetweil @Manu85
      @Manu85 sorry, darn using the default calendar again… hang on
      this TOPIC is about default calendar and weather
        sdetweil @Manu85
        @Manu85 in custom.css
        .MMM-OneCallWeather .weather-icon  img {
            max-width: 64px !important;
          Manu85 @sdetweil
          @sdetweil I’m sorry, it’s my fault, I mixed up the topics…but I didn’t know how to make another topic and let it be you who answers me!
          I modified the custom and it works, thanks again for that
            Manu85 @sdetweil
            @sdetweil I still need you, in the weather module there are “bubbles” with the wind speed inside, but the numbers are not centered, I made screenshots of the console and I saw where I can change the position however I am unable to put this in my custom css, can you help me please?
              sdetweil @Manu85
              @Manu85 so, you need to make the selector clause
              all the stuff before the {
              you know it starts w the module name class (with a leading dot)
              the bottom of the html pane has a list of the elements tree. the rightmost is the thing u are selected on
              for your prior post (on my phone again)
              so you need to find the smallest unique list that makes it work. start from the right
              and you may have to use !important to force
              it. css always uses the most specific attributes
              drawing w my thumb…
                sdetweil @Manu85
                @Manu85 topic.
                you should have been able to create a new topic
                  Manu85 @sdetweil
                  @sdetweil thanks to you I succeeded, I hope I understood the logic well, I will try on other icons to be sure I understand, you are the best
                    Manu85 @sdetweil
                    @sdetweil I put that in my css…
                    .MMM-OneCallWeather .weather-icon  p {
                        top: -65px !important;
                        left: 16px  !important;
                      sdetweil @Manu85
                      @Manu85 awesome!!!
                        sdetweil @Manu85
                        @Manu85 said in Changing icons of the modules Current Weather and Weather Forecast:
                        it’s the same process icons or text…
                        • 27
                        • 28
                        • 29
                        • 30
                        • 31
                        • 29 / 31
