    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.7m Views 33 Watching
      sdetweil @Manu85
      @Manu85 ok, i think this is what you want
      1. add
      classes:"forecast",
      the the weather forecast , after the module:“weather”, line
      1. then add this to custom.css
      .forecast .weathericon {
          font-size: 125%;
      you can change the font-size bigger too
      refresh the mm page
      M M 2 Replies Last reply Reply Quote 0
        manu85340 @sdetweil
        @sdetweil ok thanks I’ll try that when I get home
          Manu85 @sdetweil
          @sdetweil I added in js.config
          classes:"forecast",
          after the line:
          module: "MMM-OneCallWeather",
          then in custom css:
          .forecast .weather-icon {
               font-size: 125%;
          I refreshed but it doesn’t change anything…
            sdetweil @Manu85
            @Manu85 sorry, darn using the default calendar again… hang on
            this TOPIC is about default calendar and weather
              sdetweil @Manu85
              @Manu85 in custom.css
              .MMM-OneCallWeather .weather-icon  img {
                  max-width: 64px !important;
                Manu85 @sdetweil
                @sdetweil I’m sorry, it’s my fault, I mixed up the topics…but I didn’t know how to make another topic and let it be you who answers me!
                I modified the custom and it works, thanks again for that
                  Manu85 @sdetweil
                  @sdetweil I still need you, in the weather module there are “bubbles” with the wind speed inside, but the numbers are not centered, I made screenshots of the console and I saw where I can change the position however I am unable to put this in my custom css, can you help me please?
                    sdetweil @Manu85
                    @Manu85 so, you need to make the selector clause
                    all the stuff before the {
                    you know it starts w the module name class (with a leading dot)
                    the bottom of the html pane has a list of the elements tree. the rightmost is the thing u are selected on
                    for your prior post (on my phone again)
                    so you need to find the smallest unique list that makes it work. start from the right
                    and you may have to use !important to force
                    it. css always uses the most specific attributes
                    drawing w my thumb…
                      sdetweil @Manu85
                      @Manu85 topic.
                      you should have been able to create a new topic
                        Manu85 @sdetweil
                        @sdetweil thanks to you I succeeded, I hope I understood the logic well, I will try on other icons to be sure I understand, you are the best
                          Manu85 @sdetweil
                          @sdetweil I put that in my css…
                          .MMM-OneCallWeather .weather-icon  p {
                              top: -65px !important;
                              left: 16px  !important;
                            sdetweil @Manu85
                            @Manu85 awesome!!!
                              sdetweil @Manu85
                              @Manu85 said in Changing icons of the modules Current Weather and Weather Forecast:
                              it’s the same process icons or text…
                                Manu85
                                @sdetweil I thought it was going to be simple…but no… I would like to enlarge the wind speed “bubble” because at the moment there is one number but when there are two for example 35 then it will exceed
                                I selected this part, is it correct?
                                then in the table I have this, with “img” at the bottom like for the weather icons and I don’t know what to put in css.custom to choose only this part, I tried many things but without success before giving you ask for help again
                                on the right I have this
                                  sdetweil @Manu85
                                  @Manu85 sorry I do not know.
                                  M 3 Replies Last reply Reply Quote 0
                                    Manu85 @sdetweil
                                    @sdetweil ok, thanks again for all your help, I’ll try again
                                      Manu85 @sdetweil
                                      @sdetweil It’s good I found it, thank you again for your help
                                        Manu85 @sdetweil
                                        @sdetweil for information and for other people I put in my custom.css, thank you for your help
                                        .weather-icon > span > img {
                                              height: 72px; /* to adjust the size of the "wind bubble*/
                                          Manu85 @Manu85
                                          thanks to @KristjanESPERANTO for his help
                                          • S svenpisa referenced this topic on
                                          • 12
                                          • 13
                                          • 14
                                          • 15
                                          • 16
                                          • 15 / 16
