    My Magic "Mirror" Desk Display
    18 Posts 6 Posters 18.3k Views 10 Watching
      Ashaman @BerkSmash1984
      @BerkSmash1984 I’m in the process of setting up mine, and seeing how you organized yours gave me lots of ideas! 👍
      Mine takes time though, because so far I’ve only added custom modules I make myself. 😅
      Need to start implementing more premade modules. 😂
      Is MMM-Pages working for you?
      I tried to use it the first week I was new to MM and had problems, so I’m currently using MMM-Carousel.
      S BKeyportB BerkSmash1984B 3 Replies Last reply Reply Quote 0
        sdetweil @Ashaman
        @Ashaman see my Pages fork readme for an easier way(IMHO) to define the pages (no code change)
        https://github.com/sdetweil/MMM-pages
        • BKeyportB Offline
          BKeyport Module Developer @Ashaman
          @Ashaman … custom modules you made yourself? Elitist! 🤣🤣🤣
          • E Offline
            Egnos
            Hi @BerkSmash1984 and congratulations for the MM and for the organization of the pages!
            I have a question for you: could you share the config for the “MMM-ISS-Map” module? I tried reading the developer’s instructions but I didn’t understand much…
            Thanks!
            BerkSmash1984B 1 Reply Last reply Reply Quote 0
              Ashaman @BKeyport
              @BKeyport Why? I needed to display data from my own datasets and API not supported in existing modules, kinda had to make them myself then? I do it to learn more coding.
              BKeyportB 1 Reply Last reply Reply Quote 1
              • BKeyportB Offline
                @Ashaman I was just teasing. In fact, every module I built myself is for that exact reason…
                • N Offline
                  nickthebeer
                  That’s really cool, you’ve inspired me to do something similar in my office as there’s things only I care about (my wife would kill me if she saw my Strava info 🤣).
                  • BerkSmash1984B Offline
                    BerkSmash1984 @Ashaman
                    @Ashaman I sent you a DM, but pretty sure I worked @sdetweil on getting it to work via Discord. Definitely try his fork!
                      BerkSmash1984 @Egnos
                      @Egnos You bet, here you go!
                        sdetweil @BerkSmash1984
                        @BerkSmash1984 my MMM-Pages fork only updates the doc… didn’t change any code
                          BerkSmash1984 @sdetweil
                          @sdetweil Understood, I know I reached out to you on Discord and you helped me get it setup using classes as an easier way to define the pages in the config, but don’t remember anything beyond that. I did sent @Ashaman a DM though with my config to help him
                          • E Offline
                            Egnos @BerkSmash1984
                            @BerkSmash1984
                            One question: in “mapUrl” excluding the (x, y) coordinates, how did you compose the url?
                            Many thanks!
                              @Egnos I did not, that is from the module itself, but is a configurable item. Take a look at the MMM-ISS-Map-src.js file located in /MagicMirror/modules/MMM-ISS-Map:
                              Note that you can change “light_all” and other configurable style options to those supported by CARTO basemaps.
                              See:
                              https://github.com/CartoDB/basemap-styles
                              In my testing with my MagicMirror setup, “light_all” looks best, but def check out the other styles to see what meets your needs!
                              • E Offline
                                Thanks @BerkSmash1984 for the detailed information!
                                Which version of Raspbian do you run in your RPI?
                                  @Egnos Bullseye Release 11
                                  • BerkSmash1984B BerkSmash1984 referenced this topic on
