    Execute bash command/Turn off GPIO (LED) from mirror
    11 Posts 5 Posters 3.7k Views 4 Watching
    • BKeyportB
      BKeyport Module Developer
      I’m looking for a quick and dirty way to turn off an LED once the mirror fully loads - basically getting around the slowness in Electron from all the random little errors on startup and waiting for systems that will never start.
      I don’t care if it’s a quick module I build myself, or something else.
      I’m assuming it can be done with all the abilities to read system info etc - just not sure how to do it myself.
      Thanks!
      R 1 Reply Last reply
      • bugsounetB
        bugsounet Banned
        tip: try to use gpiozero ;)
        BKeyportB 1 Reply Last reply
        • BKeyportB
          BKeyport Module Developer @bugsounet
          @bugsounet I actually have the bash command I need to run. Just the part of interfacing through the Mirror is what I need help with.
          bugsounetB M 2 Replies Last reply
          • bugsounetB
            bugsounet Banned @BKeyport
            ah sorry, so exec your code it when all modules are started.
            with ALL_MODULES_STARTED incoming system notification, you can send a notification to node_helper for exec your bash script
            For execute it in node_helper, you can use exec command of child_process library
            See:
            • system notification: about all system notification
            • sendSocketNotification for send a notification to node_helper
            • socketNotificationReceived for read notification in node_helper
              MMRIZE @BKeyport
              @BKeyport
              MMM-NotificationTrigger for that purpose.
              wishmaster270W 1 Reply Last reply
              • wishmaster270W
                wishmaster270 Module Developer @MMRIZE
                @MMRIZE
                Or https://github.com/Tom-Hirschberger/MMM-Notification-To-Command
                • BKeyportB
                  BKeyport Module Developer @wishmaster270
                  @wishmaster270 @MMRIZE I figured one of you wizards already figured it out. I had forgotten about the all modules notification, and then I would have realized all the pieces are already there.
                  • BKeyportB
                    FWIW, MMM-Notification-To-Command is exactly what I was aiming for.
                    • BKeyportB BKeyport has marked this topic as solved on
                      Ray @BKeyport
                      @BKeyport you might want to look at raspberry pi 5 I use it to turn LEDs on and off
                      I also use believers are not Dragon NaturallySpeaking which is pretty cool because I can write a letter and also turn LEDs on and off just by voice
                      • BKeyportB
                        BKeyport Module Developer @Ray
                        @Ray pinctrl 17 op dl does the work behind the scenes, I just needed a way to call it from the mirror, which I got with MMM-Notification-to-command.
                          Ray @BKeyport
                          @BKeyport another way I also do it is I use GoogleAssistant
                          and then use what they call a recipe these recipes you can make yourself on my recipe I have turned the lights on
                          so as long as I have my microphone on and link to the mirror I can turn the lights on and off
                          https://wiki.bugsounet.fr/MMM-GoogleAssistant
