    Execute bash command/Turn off GPIO (LED) from mirror
    11 Posts 5 Posters 2.8k Views 4 Watching
    • wishmaster270W Offline
      wishmaster270 Module Developer @MMRIZE
      @MMRIZE
      Or https://github.com/Tom-Hirschberger/MMM-Notification-To-Command
      • BKeyportB Offline
        BKeyport Module Developer @wishmaster270
        @wishmaster270 @MMRIZE I figured one of you wizards already figured it out. I had forgotten about the all modules notification, and then I would have realized all the pieces are already there.
        • BKeyportB Offline
          FWIW, MMM-Notification-To-Command is exactly what I was aiming for.
          • BKeyportB BKeyport has marked this topic as solved on
            Ray @BKeyport
            @BKeyport you might want to look at raspberry pi 5 I use it to turn LEDs on and off
            I also use believers are not Dragon NaturallySpeaking which is pretty cool because I can write a letter and also turn LEDs on and off just by voice
            • BKeyportB Offline
              BKeyport Module Developer @Ray
              @Ray pinctrl 17 op dl does the work behind the scenes, I just needed a way to call it from the mirror, which I got with MMM-Notification-to-command.
                Ray @BKeyport
                @BKeyport another way I also do it is I use GoogleAssistant
                and then use what they call a recipe these recipes you can make yourself on my recipe I have turned the lights on
                so as long as I have my microphone on and link to the mirror I can turn the lights on and off
                https://wiki.bugsounet.fr/MMM-GoogleAssistant
