    Execute bash command/Turn off GPIO (LED) from mirror
    11 Posts 5 Posters 2.8k Views 4 Watching
    • bugsounetB Offline
      bugsounet Banned
      tip: try to use gpiozero ;)
      • BKeyportB Offline
        BKeyport Module Developer @bugsounet
        @bugsounet I actually have the bash command I need to run. Just the part of interfacing through the Mirror is what I need help with.
        bugsounetB M 2 Replies Last reply Reply Quote 0
          bugsounet Banned @BKeyport
          ah sorry, so exec your code it when all modules are started.
          with ALL_MODULES_STARTED incoming system notification, you can send a notification to node_helper for exec your bash script
          For execute it in node_helper, you can use exec command of child_process library
          See:
          • system notification: about all system notification
          • sendSocketNotification for send a notification to node_helper
          • socketNotificationReceived for read notification in node_helper
            MMRIZE @BKeyport
            @BKeyport
            MMM-NotificationTrigger for that purpose.
            • wishmaster270W Offline
              wishmaster270 Module Developer @MMRIZE
              @MMRIZE
              Or https://github.com/Tom-Hirschberger/MMM-Notification-To-Command
              • BKeyportB Offline
                BKeyport Module Developer @wishmaster270
                @wishmaster270 @MMRIZE I figured one of you wizards already figured it out. I had forgotten about the all modules notification, and then I would have realized all the pieces are already there.
                • BKeyportB Offline
                  FWIW, MMM-Notification-To-Command is exactly what I was aiming for.
                  • BKeyportB BKeyport has marked this topic as solved on
                    Ray @BKeyport
                    @BKeyport you might want to look at raspberry pi 5 I use it to turn LEDs on and off
                    I also use believers are not Dragon NaturallySpeaking which is pretty cool because I can write a letter and also turn LEDs on and off just by voice
                    • BKeyportB Offline
                      BKeyport Module Developer @Ray
                      @Ray pinctrl 17 op dl does the work behind the scenes, I just needed a way to call it from the mirror, which I got with MMM-Notification-to-command.
                        Ray @BKeyport
                        @BKeyport another way I also do it is I use GoogleAssistant
                        and then use what they call a recipe these recipes you can make yourself on my recipe I have turned the lights on
                        so as long as I have my microphone on and link to the mirror I can turn the lights on and off
                        https://wiki.bugsounet.fr/MMM-GoogleAssistant
