    Execute bash command/Turn off GPIO (LED) from mirror
    11 Posts 5 Posters 2.8k Views 4 Watching
    • bugsounetB Offline
      bugsounet Banned @BKeyport
      ah sorry, so exec your code it when all modules are started.
      with ALL_MODULES_STARTED incoming system notification, you can send a notification to node_helper for exec your bash script
      For execute it in node_helper, you can use exec command of child_process library
      See:
      • system notification: about all system notification
      • sendSocketNotification for send a notification to node_helper
      • socketNotificationReceived for read notification in node_helper
        MMRIZE @BKeyport
        @BKeyport
        MMM-NotificationTrigger for that purpose.
        • wishmaster270W Offline
          wishmaster270 Module Developer @MMRIZE
          @MMRIZE
          Or https://github.com/Tom-Hirschberger/MMM-Notification-To-Command
          • BKeyportB Online
            BKeyport Module Developer @wishmaster270
            @wishmaster270 @MMRIZE I figured one of you wizards already figured it out. I had forgotten about the all modules notification, and then I would have realized all the pieces are already there.
            • BKeyportB Online
              FWIW, MMM-Notification-To-Command is exactly what I was aiming for.
              • BKeyportB BKeyport has marked this topic as solved on
                Ray @BKeyport
                @BKeyport you might want to look at raspberry pi 5 I use it to turn LEDs on and off
                I also use believers are not Dragon NaturallySpeaking which is pretty cool because I can write a letter and also turn LEDs on and off just by voice
                • BKeyportB Online
                  BKeyport Module Developer @Ray
                  @Ray pinctrl 17 op dl does the work behind the scenes, I just needed a way to call it from the mirror, which I got with MMM-Notification-to-command.
                    Ray @BKeyport
                    @BKeyport another way I also do it is I use GoogleAssistant
                    and then use what they call a recipe these recipes you can make yourself on my recipe I have turned the lights on
                    so as long as I have my microphone on and link to the mirror I can turn the lights on and off
                    https://wiki.bugsounet.fr/MMM-GoogleAssistant
