    MM startup problem after update
    42 Posts 3 Posters 11.1k Views 4 Watching
      manu85340 @sdetweil
      @sdetweil Hi Stan, I’m happy to read you (every time I have problems :-)) here are the screenshots of what you asked me to do
        sdetweil @manu85340
        @manu85340 fun
        try this
        pm2 stop all
        npm install electron@31.1.0
        then npm start
          manu85340 @sdetweil
          @sdetweil I’m stuck at this level
            manu85340 @sdetweil
              sdetweil @manu85340
              @manu85340 but what about npm start??
                manu85340 @sdetweil
                @sdetweil I get this message when I run npm start
                  sdetweil @manu85340
                  @manu85340 ok, show output of
                  uname -a
                    manu85340 @sdetweil
                      sdetweil @manu85340
                      @manu85340 did you do the electron install I provided?
                      if so can you do it again and show me the output?
                      if you do all this over ssh, then you have text you can copy/paste instead of pics. which are hard to read
                        manu85340 @sdetweil
                        @sdetweil ok sorry for the screenshots
                        pi@MagicMirror:~ $ pm2 stop all
                        [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
                        [PM2] [mm](0) ✓
                        │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                        │ 0  │ mm                 │ fork     │ 685  │ stopped   │ 0%       │ 0b       │
                        pi@MagicMirror:~ $ cd ~/MagicMirror
                        pi@MagicMirror:~/MagicMirror $ npm install electron@31.1.0
                        npm ERR! code EBADENGINE
                        npm ERR! engine Unsupported engine
                        npm ERR! engine Not compatible with your version of node/npm: magicmirror@2.28.0
                        npm ERR! notsup Not compatible with your version of node/npm: magicmirror@2.28.0
                        npm ERR! notsup Required: {"node":">=20"}
                        npm ERR! notsup Actual:   {"npm":"9.8.1","node":"v18.18.0"}
                        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-07        -01T13_05_28_653Z-debug-0.log
                          sdetweil @manu85340
                          @manu85340 ok, upgrade didn’t upgrade nodejs…
                            @manu85340 also show output of
                            lsb_release -a
                            bet it shows buster
                              manu85340 @sdetweil
                              pi@MagicMirror:~ $ lsb_release -a
                              No LSB modules are available.
                              Distributor ID: Raspbian
                              Description:    Raspbian GNU/Linux 10 (buster)
                              Release:        10
                              Codename:       buster
                              pi@MagicMirror:~ $
                                manu85340 @sdetweil
                                @sdetweil do you need installers/update.log by email?
                                  sdetweil @manu85340
                                  @manu85340 ok. script forces node 18 on buster. hang on. I’ll debug
                                  could u give me output of command n
                                  it might say unknown
                                  or give a list
                                    manu85340 @sdetweil
                                    @sdetweil I typed “n” and there is nothing
                                      sdetweil @manu85340
                                      @manu85340 ok,
                                      do
                                      sudo npm I-g n
                                      sudo n 20
                                      then node -v
                                        manu85340 @sdetweil
                                        pi@MagicMirror:~ $ sudo npm I-g n
                                        Unknown command: "I-g"
                                        To see a list of supported npm commands, run:
                                          npm help
                                        pi@MagicMirror:~ $ sudo n 20
                                          installing : node-v20.15.0
                                               mkdir : /usr/local/n/versions/node/20.15.0
                                               fetch : https://nodejs.org/dist/v20.15.0/node-v20.15.0-linux-armv7l.tar.x        z
                                             copying : node/20.15.0
                                        node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not foun        d (required by node)
                                        /usr/local/bin/node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3        .4.26' not found (required by /usr/local/bin/node)
                                           installed :  (with npm )
                                        pi@MagicMirror:~ $ node -v
                                        pi@MagicMirror:~ $ node-v
                                        -bash: node-v : commande introuvable
                                        pi@MagicMirror:~ $
                                          sdetweil @manu85340
                                          @manu85340 grr… that was the problem finding the c++ lib for buster.
                                          let me research, be a couple hours
                                            manu85340 @sdetweil
                                            @sdetweil OK thanks to you
