    MM startup problem after update
    42 Posts 3 Posters 10.0k Views 4 Watching
      sdetweil @manu85340
      @manu85340 logs
      pm2 stop all
      npm start
      pm2 logs --lines=50
      also might tell us
      I’ve seen some troubles w pm2 lately not on pi os, but maybe here too now
        @manu85340 also try this
        sudo npm install -g pm2@latest
        pm2 update
        sudo reboot
          manu85340 @sdetweil
          @sdetweil Hi Stan, I’m happy to read you (every time I have problems :-)) here are the screenshots of what you asked me to do
            sdetweil @manu85340
            @manu85340 fun
            try this
            pm2 stop all
            npm install electron@31.1.0
            then npm start
              manu85340 @sdetweil
              @sdetweil I’m stuck at this level
                manu85340 @sdetweil
                  sdetweil @manu85340
                  @manu85340 but what about npm start??
                    manu85340 @sdetweil
                    @sdetweil I get this message when I run npm start
                      sdetweil @manu85340
                      @manu85340 ok, show output of
                      uname -a
                        manu85340 @sdetweil
                          sdetweil @manu85340
                          @manu85340 did you do the electron install I provided?
                          if so can you do it again and show me the output?
                          if you do all this over ssh, then you have text you can copy/paste instead of pics. which are hard to read
                            manu85340 @sdetweil
                            @sdetweil ok sorry for the screenshots
                            pi@MagicMirror:~ $ pm2 stop all
                            [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
                            [PM2] [mm](0) ✓
                            │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                            │ 0  │ mm                 │ fork     │ 685  │ stopped   │ 0%       │ 0b       │
                            pi@MagicMirror:~ $ cd ~/MagicMirror
                            pi@MagicMirror:~/MagicMirror $ npm install electron@31.1.0
                            npm ERR! code EBADENGINE
                            npm ERR! engine Unsupported engine
                            npm ERR! engine Not compatible with your version of node/npm: magicmirror@2.28.0
                            npm ERR! notsup Not compatible with your version of node/npm: magicmirror@2.28.0
                            npm ERR! notsup Required: {"node":">=20"}
                            npm ERR! notsup Actual:   {"npm":"9.8.1","node":"v18.18.0"}
                            npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-07        -01T13_05_28_653Z-debug-0.log
                              sdetweil @manu85340
                              @manu85340 ok, upgrade didn’t upgrade nodejs…
                                @manu85340 also show output of
                                lsb_release -a
                                bet it shows buster
                                  manu85340 @sdetweil
                                  pi@MagicMirror:~ $ lsb_release -a
                                  No LSB modules are available.
                                  Distributor ID: Raspbian
                                  Description:    Raspbian GNU/Linux 10 (buster)
                                  Release:        10
                                  Codename:       buster
                                  pi@MagicMirror:~ $
                                    manu85340 @sdetweil
                                    @sdetweil do you need installers/update.log by email?
                                      sdetweil @manu85340
                                      @manu85340 ok. script forces node 18 on buster. hang on. I’ll debug
                                      could u give me output of command n
                                      it might say unknown
                                      or give a list
                                        manu85340 @sdetweil
                                        @sdetweil I typed “n” and there is nothing
                                          sdetweil @manu85340
                                          @manu85340 ok,
                                          do
                                          sudo npm I-g n
                                          sudo n 20
                                          then node -v
                                            manu85340 @sdetweil
                                            pi@MagicMirror:~ $ sudo npm I-g n
                                            Unknown command: "I-g"
                                            To see a list of supported npm commands, run:
                                              npm help
                                            pi@MagicMirror:~ $ sudo n 20
                                              installing : node-v20.15.0
                                                   mkdir : /usr/local/n/versions/node/20.15.0
                                                   fetch : https://nodejs.org/dist/v20.15.0/node-v20.15.0-linux-armv7l.tar.x        z
                                                 copying : node/20.15.0
                                            node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not foun        d (required by node)
                                            /usr/local/bin/node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3        .4.26' not found (required by /usr/local/bin/node)
                                               installed :  (with npm )
                                            pi@MagicMirror:~ $ node -v
                                            pi@MagicMirror:~ $ node-v
                                            -bash: node-v : commande introuvable
                                            pi@MagicMirror:~ $
