    MM startup problem after update
    42 Posts 3 Posters 11.4k Views 4 Watching
    • BKeyportB
      BKeyport Module Developer @manu85340
      @manu85340 did you get a all black screen? There’s some background stuff that needs node/npm upgraded. If you updated before around 6 hours prior to your post, run the command again.
        manu85340 @BKeyport
        @BKeyport No I didn’t have a black screen, I ran the script I didn’t get an error message I updated about 2 hours ago, I updated again the update an hour ago but MM still does not want to start I don’t understand why thank you for your help
          sdetweil @manu85340
          @manu85340 logs
          pm2 stop all
          npm start
          pm2 logs --lines=50
          also might tell us
          I’ve seen some troubles w pm2 lately not on pi os, but maybe here too now
            @manu85340 also try this
            sudo npm install -g pm2@latest
            pm2 update
            sudo reboot
              manu85340 @sdetweil
              @sdetweil Hi Stan, I’m happy to read you (every time I have problems :-)) here are the screenshots of what you asked me to do
                sdetweil @manu85340
                @manu85340 fun
                try this
                pm2 stop all
                npm install electron@31.1.0
                then npm start
                  manu85340 @sdetweil
                  @sdetweil I’m stuck at this level
                    manu85340 @sdetweil
                      sdetweil @manu85340
                      @manu85340 but what about npm start??
                        manu85340 @sdetweil
                        @sdetweil I get this message when I run npm start
                          sdetweil @manu85340
                          @manu85340 ok, show output of
                          uname -a
                            manu85340 @sdetweil
                              sdetweil @manu85340
                              @manu85340 did you do the electron install I provided?
                              if so can you do it again and show me the output?
                              if you do all this over ssh, then you have text you can copy/paste instead of pics. which are hard to read
                                manu85340 @sdetweil
                                @sdetweil ok sorry for the screenshots
                                pi@MagicMirror:~ $ pm2 stop all
                                [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
                                [PM2] [mm](0) ✓
                                │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                                │ 0  │ mm                 │ fork     │ 685  │ stopped   │ 0%       │ 0b       │
                                pi@MagicMirror:~ $ cd ~/MagicMirror
                                pi@MagicMirror:~/MagicMirror $ npm install electron@31.1.0
                                npm ERR! code EBADENGINE
                                npm ERR! engine Unsupported engine
                                npm ERR! engine Not compatible with your version of node/npm: magicmirror@2.28.0
                                npm ERR! notsup Not compatible with your version of node/npm: magicmirror@2.28.0
                                npm ERR! notsup Required: {"node":">=20"}
                                npm ERR! notsup Actual:   {"npm":"9.8.1","node":"v18.18.0"}
                                npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-07        -01T13_05_28_653Z-debug-0.log
                                  sdetweil @manu85340
                                  @manu85340 ok, upgrade didn’t upgrade nodejs…
                                    @manu85340 also show output of
                                    lsb_release -a
                                    bet it shows buster
                                      manu85340 @sdetweil
                                      pi@MagicMirror:~ $ lsb_release -a
                                      No LSB modules are available.
                                      Distributor ID: Raspbian
                                      Description:    Raspbian GNU/Linux 10 (buster)
                                      Release:        10
                                      Codename:       buster
                                      pi@MagicMirror:~ $
                                        manu85340 @sdetweil
                                        @sdetweil do you need installers/update.log by email?
                                          sdetweil @manu85340
                                          @manu85340 ok. script forces node 18 on buster. hang on. I’ll debug
                                          could u give me output of command n
                                          it might say unknown
                                          or give a list
                                            manu85340 @sdetweil
                                            @sdetweil I typed “n” and there is nothing
