    MM startup problem after update
    42 Posts 3 Posters 6.5k Views 4 Watching
      manu85340
      Hello, I updated the new MM with the script from @sdetweil (as I usually do) everything went well but after the sudo reboot the screen remains stuck on the operating system page raspberry but the MM does not start, I tried to do
      pm2 stop al
      l and then
      pm2 start all
      but still nothing happens on the pi screen! thank you in advance for your help, the script is as follows, I passed it after doing a pm2 stop all
      bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
      • BKeyportB Offline
        BKeyport Module Developer @manu85340
        @manu85340 did you get a all black screen? There’s some background stuff that needs node/npm upgraded. If you updated before around 6 hours prior to your post, run the command again.
          manu85340 @BKeyport
          @BKeyport No I didn’t have a black screen, I ran the script I didn’t get an error message I updated about 2 hours ago, I updated again the update an hour ago but MM still does not want to start I don’t understand why thank you for your help
            sdetweil @manu85340
            @manu85340 logs
            pm2 stop all
            npm start
            pm2 logs --lines=50
            also might tell us
            I’ve seen some troubles w pm2 lately not on pi os, but maybe here too now
              @manu85340 also try this
              sudo npm install -g pm2@latest
              pm2 update
              sudo reboot
                manu85340 @sdetweil
                @sdetweil Hi Stan, I’m happy to read you (every time I have problems :-)) here are the screenshots of what you asked me to do
                  sdetweil @manu85340
                  @manu85340 fun
                  try this
                  pm2 stop all
                  npm install electron@31.1.0
                  then npm start
                    manu85340 @sdetweil
                    @sdetweil I’m stuck at this level
                      manu85340 @sdetweil
                        sdetweil @manu85340
                        @manu85340 but what about npm start??
                        • 1 / 5
