    [MMM-GoogleSheets] Display Google Sheets data on your MagicMirror
    21 Posts 5 Posters 7.3k Views 6 Watching
      ryandwilliams Module Developer @ryandwilliams
      UPDATE: Version 3 (November 2024)
      • Scrolling data is now supported (you can define how much data to show and customize the scrolling behavior to meet your needs). Check out the README for more info. Gif example: MMM-GoogleSheets-Scroll.gif
        santex
        Sorry, i followed all the necessary step and i’m getting this for the googlesheet
        [ERROR] [MMM-Google-Sheets] ERROR There was an error with the request. This URL should work in your browser: https://script.google.com/macros/s/AKfycbxvminqCe-gLNZp6X8VlhNLeVmtefpdDYgZaWIBslM27JYxML3K7fS2tec7BsGB_hSILw/exec?sheet=Sheet1&range=A1:B6
        [2025-01-17 18:11:23.273] [ERROR] Full Error Message:
        [2025-01-17 18:11:23.298] [ERROR] TypeError: fetch failed
        at node:internal/deps/undici/undici:12502:13
        at processTicksAndRejections (node:internal/process/task_queues:95:5)
        at runNextTicks (node:internal/process/task_queues:64:3)
        at listOnTimeout (node:internal/timers:540:9)
        at process.processTimers (node:internal/timers:514:7)
        at async Class.socketNotificationReceived (/home/omiworld/MagicMirror/modules/MMM-GoogleSheets/node_helper.js:27:24) {
        [cause]: AggregateError [ETIMEDOUT]:
        at internalConnectMultiple (node:net:1117:18)
        at internalConnectMultiple (node:net:1185:5)
        at Timeout.internalConnectMultipleTimeout (node:net:1711:5)
        at listOnTimeout (node:internal/timers:575:11)
        at process.processTimers (node:internal/timers:514:7) {
        code: ‘ETIMEDOUT’,
        [errors]: [ [Error], [Error] ]
          sdetweil @santex
          @santex did you try the link provided in the error info?
            santex @sdetweil
            YES i did. it gave me this
            Sorry, unable to open the file at this time.
            Please check the address and try again.
            Get stuff done with Google Drive
            Apps in Google Drive make it easy to create, store and share online documents, spreadsheets, presentations and more.
            Learn more at drive.google.com/start/apps.
              sdetweil @santex
              @santex ok, so the link doesn’t work…
              did you do the right setup of the sheet name?
                santex @sdetweil
                @sdetweil yes i did
                  santex @sdetweil
                  i follow all the steps, as indicated in the module
                    sdetweil @santex
                    @santex see this link
                    https://forum.magicmirror.builders/post/119206
                      santex @sdetweil
                      thank you. i have followed this i dont find the solution
                        sdetweil @santex
                        @santex then the best option is to open an issue on the module github page to engage the author
                          santex @sdetweil
                          @sdetweil ok, i have also done that
                            UPDATE: Version 4 (February 2026)
                            • Checkboxes and dropdowns are now supported. Additionally, they are interactive (if you change a checkbox or dropdown on the mirror, it will make that same change on the spreadsheet. This should allow for fully-customizable self-built modules and advanced spreadsheet interaction!
                            Example Image (all of the checkboxes and dropdowns are editable and link back to the spreadsheet):
                            W 1 Reply Last reply Reply Quote 2
                            • W Offline
                              wimThoelke @ryandwilliams
                              dear @ryandwilliams ,
                              thanx for updating the module. unfortunately, it breaks the display of my GoogleSheet, i.e. it is not loading anymore. If i go back to commit “25685e9” it works fine again. In the magicmirror logs i cannot find any ERROR or WARNING.
                              i am happy to support fixing the issue, in this case i would need some instructions which data to provide.
                                ryandwilliams Module Developer @wimThoelke
                                @wimThoelke thanks for the reply! What steps did you take to update the module? Did you pull the new repo as well as update the Google Apps Script library (currently version 34)?
                                It’s also worth noting that when you make a big change to Google Apps Script, the time to load can significantly increase the first time you run the module. For example during my testing, when I did an update the module took ~25-30 seconds to load the very first time, but after the first time it only took 2-3 seconds on subsequent refreshes.
                                If there is no error then I think it may be a loading problem or it may be because you did not update the Google Apps Script. The module should always error if something goes wrong (this might be a special situation I’m happy to help you debug).
                                I think it might be best to transfer this conversation over to github so I can help you with your problem. Can you open an issue so we can talk about it more?
                                • W Offline
                                  @ryandwilliams
                                  thanx for your quick reply and offer to support.
                                  i did a simple git pull. no touches to Google Apps Script library, since i am not very familiar with it and prefer to go step-by-step to isolate root casues.
                                  i will raise the issue on github, so we can continue there.
                                    @wimThoelke I responded to you on github, but just in case anyone stumbles on this thread in the future - you need to update both the module (via git pull) and the Google Apps Script library version (instructions in the readme).
                                    • W Offline
                                      just for reference, link to github issue to follow up:
                                      https://github.com/ryan-d-williams/MMM-GoogleSheets/issues/72
