    [MMM-GoogleSheets] Display Google Sheets data on your MagicMirror
    15 Posts 4 Posters 3.3k Views 5 Watching
      santex
      Sorry, i followed all the necessary step and i’m getting this for the googlesheet
      [ERROR] [MMM-Google-Sheets] ERROR There was an error with the request. This URL should work in your browser: https://script.google.com/macros/s/AKfycbxvminqCe-gLNZp6X8VlhNLeVmtefpdDYgZaWIBslM27JYxML3K7fS2tec7BsGB_hSILw/exec?sheet=Sheet1&range=A1:B6
      [2025-01-17 18:11:23.273] [ERROR] Full Error Message:
      [2025-01-17 18:11:23.298] [ERROR] TypeError: fetch failed
      at node:internal/deps/undici/undici:12502:13
      at processTicksAndRejections (node:internal/process/task_queues:95:5)
      at runNextTicks (node:internal/process/task_queues:64:3)
      at listOnTimeout (node:internal/timers:540:9)
      at process.processTimers (node:internal/timers:514:7)
      at async Class.socketNotificationReceived (/home/omiworld/MagicMirror/modules/MMM-GoogleSheets/node_helper.js:27:24) {
      [cause]: AggregateError [ETIMEDOUT]:
      at internalConnectMultiple (node:net:1117:18)
      at internalConnectMultiple (node:net:1185:5)
      at Timeout.internalConnectMultipleTimeout (node:net:1711:5)
      at listOnTimeout (node:internal/timers:575:11)
      at process.processTimers (node:internal/timers:514:7) {
      code: ‘ETIMEDOUT’,
      [errors]: [ [Error], [Error] ]
        sdetweil @santex
        @santex did you try the link provided in the error info?
          santex @sdetweil
          YES i did. it gave me this
          Sorry, unable to open the file at this time.
          Please check the address and try again.
          Get stuff done with Google Drive
          Apps in Google Drive make it easy to create, store and share online documents, spreadsheets, presentations and more.
          Learn more at drive.google.com/start/apps.
            sdetweil @santex
            @santex ok, so the link doesn’t work…
            did you do the right setup of the sheet name?
              santex @sdetweil
              @sdetweil yes i did
                santex @sdetweil
                i follow all the steps, as indicated in the module
                  sdetweil @santex
                  @santex see this link
                  https://forum.magicmirror.builders/post/119206
                    santex @sdetweil
                    thank you. i have followed this i dont find the solution
                      sdetweil @santex
                      @santex then the best option is to open an issue on the module github page to engage the author
                        santex @sdetweil
                        @sdetweil ok, i have also done that
