    MMM-TouchAlarm - Your touchable Alarm Clock
    15 Posts 8 Posters 9.6k Views 10 Watching
      JanLoebel Module Developer
      Description
      Hi there,
      I’m using my MagicMirror2 with a small RaspberryPi and the 7" touchscreen. I wanted to add an Alarm Clock which I can enable/disable and are able to set the time via the touch screen. So I’ve created this module.
      Let me know what you think or if you have any feature requests for it :) Special thanks also to @fewieden (https://github.com/fewieden/) for creating the “MMM-AlarmClock”-Module which inspired me a lot :)
      Best regards,
      Jan
      Download
      [card:JanLoebel/MMM-TouchAlarm]
      P Mykle1M justjim1220J 3 Replies Last reply
        PhilReis @JanLoebel
        @janloebel interesting module. Can you add some pictures?
        justjim1220J 1 Reply Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @JanLoebel
          @janloebel
          I have a few laptop alarm clocks using MM. Will it work with the click of a mouse (laptop trackpad) as well?
          • justjim1220J
            justjim1220 Module Developer @Mykle1
            @mykle1
            I have tried it out and YES, it does work with clicking mouse and touchpad
            Jim Hallock - 1995
            Mykle1M 1 Reply Last reply
            • justjim1220J
              justjim1220 Module Developer @JanLoebel
              @janloebel
              Thanks for fixing the snooze button! :winking_face:
              Jim Hallock - 1995
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @justjim1220
                @justjim1220 said in MMM-TouchAlarm - Your touchable Alarm Clock:
                • justjim1220J
                  @mykle1 yep! :winking_face:
                  Jim Hallock - 1995
                  • justjim1220J
                    justjim1220 Module Developer @PhilReis
                    @philreis
                    Here’s some pics of it on my MM…
                    click or touch the bell icon to turn alarm on or off:
                    click or touch the time to set the time for the alarm
                    the set alarm modal
                    click OK button when done
                    Jim Hallock - 1995
                      Great :) Any feature requests or problems so far?
                      • justjim1220J
                        @janloebel
                        Not really, I have been trying to do this with my digital alarm clock for a while now.
                        Even looking at your code isn’t helping me with mine. LOL!
                        Your code is way different and won’t work with mine.
                        Mine is set up to have more than one alarm set at a time.
                        I have a popup modal I have been trying to incorporate, but cannot figure out how to pull the info from the modal to the clock. This is what I have: https://codepen.io/justjim1220/pen/ZVgjQJ
                        Pretty much my only issue. For now, I like yours, so will be using it until I get mine figured out.
                        Jim Hallock - 1995
                        • G
                          gaudouy
                          Hi !
                          I am very interested to manage the alarm clock with touchscreen.
                          Do you have any documentation?
                          Thanks for advance
                          • cowboysdudeC
                            cowboysdude Module Developer @gaudouy
                            @gaudouy
                            https://forum.magicmirror.builders/topic/13911/bedside-table-alarm-clock?_=1623369873273
                            https://forum.magicmirror.builders/topic/695/my-mini-magic-alarm-clock?_=1623369873276
                            All kinds of it… search feature on the forum works pretty good ;)
                              rtkeen
                              I know this topic is a little old, but I just put together my first Alarm Clock using this module. Great work! The one suggestion I would have would be to be able to dismiss the alarm with an “OK” button the same size as the “Snooze” button. At my age, when I get up in the morning, it can be quite a challenge to get my finger on that little “X” in the corner to turn the alarm off. A bigger button would certainly be welcome.
                              Thanks for this great module! You should get it posted on the MagicMirror site! I stumbled across it by searching Google.
                              R 1 Reply Last reply
                                rtkeen @rtkeen
                                I solved my own problem, although I now am not synced with github. I made the bell icon such that it dismissed the alarm, and that’s big enough for me to see and touch once the alarm goes off.
                                  Phoenix
                                  Thank you for this module. I tried the one from fewieden and now it´s perfect. Instesd of a ringtone I play a webradio stream
                                  alarmSoundFile: ‘http://icecast.ndr.de/ndr/ndr1wellenord/flensburg/mp3/128/stream.mp3’,
