    MMM-Tado - Tado API Login no longer working (403 error) — any fix?
    17 Posts 7 Posters 2.4k Views 9 Watching
      chichi1887
      Hi everyone,
      I hope it’s okay to write in English – it’s not my native language, so please excuse any mistakes 😊
      I’m currently having issues with the MMM-Tado module. It used to work fine, but now I’m constantly getting the following error:
      Error: Request failed with status code 403
      “error”: “forbidden”,
      “error_description”: “Please migrate: https://support.tado.com/en/articles/8565472-how-do-i-authenticate-to-access-the-rest-api”
      After testing my credentials directly via PowerShell and curl, I found out that Tado has disabled the old OAuth/password login flow, which the current MMM-Tado modules seem to rely on.
      I tried multiple forks, updated everything, checked my credentials, even tested the API manually – but the result is always the same: 403 Forbidden.
      MagicMirror logs show this over and over:
      MMM-Tado: Not all data present
      So I believe the module is no longer compatible with the latest Tado authentication system.
      ❓Has anyone already fixed this issue or found a workaround?
      Maybe someone already updated the module or uses another approach (like a proxy, Home Assistant, or a newer fork)?
      Thanks a lot in advance 🙏
      And again – sorry for my English! 😅
      • mumblebajM Online
        mumblebaj Module Developer @chichi1887
        @chichi1887 I have seen that the node-tado-client npmjs package has been updated to v1.0.0 to cater for the new OAuth2 flow. I would suggest opening an issue on the module Github page for the module developer to fix.
          mishu28nmv @mumblebaj
          https://github.com/WouterEekhout/MMM-Tado/issues/18
          There is a fix from an user. Maybe give it a try 😁
            JoeFranz @mishu28nmv
            @mishu28nmv
            What exactly do I need to do to get MMM-Tado working again? I searched the logs for the URL that should be generated, but couldn’t find anything.
              sdetweil @JoeFranz
              @JoeFranz did you look at the fork
              https://github.com/daydy16/MMM-Tado
                JoeFranz @sdetweil
                @sdetweil I read it, but I can’t find the URL in the logs… :-(
                  sdetweil @JoeFranz
                  @JoeFranz oh, i see
                  are you sure this new module is installed instead of the one you were trying?
                  J C 2 Replies Last reply Reply Quote 0
                    JoeFranz @sdetweil
                    @sdetweil I’ve now reinstalled it from this site. I can’t find the URL in the logs.
                      sdetweil @JoeFranz
                      @JoeFranz how are you displaying the logs?
                        JoeFranz @sdetweil
                        @sdetweil pm2 logs MagicMirror
