    MMM-Tado - Tado API Login no longer working (403 error) — any fix?
    17 Posts 7 Posters 4.0k Views 9 Watching
      sdetweil @JoeFranz
      @JoeFranz oh, i see
      are you sure this new module is installed instead of the one you were trying?
      J C 2 Replies Last reply Reply Quote 0
        JoeFranz @sdetweil
        @sdetweil I’ve now reinstalled it from this site. I can’t find the URL in the logs.
          sdetweil @JoeFranz
          @JoeFranz how are you displaying the logs?
            JoeFranz @sdetweil
            @sdetweil pm2 logs MagicMirror
              sdetweil @JoeFranz
              @JoeFranz probably need more lines
              pm2 logs MagicMirror --lines=100
                JoeFranz @sdetweil
                @sdetweil said in MMM-Tado - Tado API Login no longer working (403 error) — any fix?:
                OK, the URL is now displayed :-)
                I’ll try it out, thanks!
                  chichi1887 @sdetweil
                  @sdetweil Hi i reinstall the hole MM Software and use the daydy16 Tado Version but from the beginning with alle the config i became this error 8857d2f8-4886-4377-ba64-0f68710eaec6-image.png what i do wrong
                    chichi1887 @chichi1887
                    i Spend now 4 Nights with Chatgpt without Outcome. Only the handle Version change the Bearer works great.
                      det @chichi1887
                      @chichi1887 said in MMM-Tado - Tado API Login no longer working (403 error) — any fix?:
                      Did you find a solution?
                      Thank you.
                      • N Offline
                        nero32 @det
                        @det I have the same problem.
                          mishu28nmv
                          This is my solution. Just install the https://github.com/daydy16/MMM-Tado
                          In the config file:
                          		module: 'MMM-Tado',
                          		position: 'bottom_left', // This can be any of the regions.
                          		updateInterval: 900000 // miliseconds-15minutes-96times per day < 100
                          After you launch your Mirror with “node --run start”, you receive in the terminal this:
                          MMM-Tado: Device authentication required. Please visit the following URL:
                          https://login.tado.com/oauth2/device?user_code=XXXXXX
                          You put that URL in your browser and submit the code. That’s it.
                          Hope it helps!
